Old 10-27-2016, 01:23 PM #1
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
Tie Rod & Lower ball joint
Sooo I have been hearing a very low base hum and I finally could check in bright day light and looks like both end rods and lower ball joints are torn!
Is that normal? I'm at 83k miles. Has anyone had luck with dealer replacing these parts post installing lift?
Driver side:
Passenger side:
Driver side is more severe ....
sadness..
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 10-27-2016, 06:21 PM #2
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
Bump
Dual Battery Thread
Old 10-27-2016, 06:43 PM #3
Yoderguy's Avatar
Yoderguy Yoderguy is offline
Yoderguy is on a distinguished road
Yoderguy's Avatar
Depending on your relationship with your dealership, is what will decide your wallets fate. I have known our service manager for many years of Toyota ownership so I could pull it off. However any stranger comes in with those issues and they're gonna dodge it like a bullet.
I'd put it down to stock height and then roll up clueless if you're trying to save a buck and still under warranty.
Sent from my LG-H811 using Tapatalk
Yoderguy is offline   Reply With QuoteReply With Quote
Old 10-27-2016, 06:44 PM #4
Watchdogg's Avatar
Watchdogg Watchdogg is offline
Real Name: James
Watchdogg is on a distinguished road
Watchdogg's Avatar
Real Name: James
Is it just the boot ripped? You can replace just the boot. The balljoint is another story. I think some guys were told they have to replace the lower control arm as the ball joint is not replaceable. Hope I'm wrong. Can someone else chime in? The tierod ends are easy to replace. You just have to count how many turns it takes to come off and put the new one on the same number of turns. Post lift good luck at the dealer.
Watchdogg is offline   Reply With QuoteReply With Quote
Old 10-27-2016, 07:11 PM #5
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
How do I tell if the ball joint is damaged? Noise? Behavior?
Dual Battery Thread
Old 10-27-2016, 07:14 PM #6
Yoderguy's Avatar
Yoderguy's Avatar
You can do a rough check by lifting the tire off the ground and grabbing at 12 and 6 on the tire and rock up and down. If you feel play or hear a small knock, it's a spent LBJ.
Old 10-27-2016, 07:24 PM #7
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
all those seals damaged not normal.
do they look cut ? torn ? if rotten that would be poor toyota product . other wise may have been damaged by some repair shop .
catrains is offline   Reply With QuoteReply With Quote
Old 10-27-2016, 07:50 PM #8
Watchdogg's Avatar
Real Name: James
Watchdogg's Avatar
Real Name: James
Just looked at mine. Looks like lower ball joint is replaceable. Lift tire off ground and try rocking it top to bottom and side to side. If it's bad you'll feel it. I think a lot of guys getting ready for their camping trip so may be hard to get information for a couple of days.
Old 10-27-2016, 07:53 PM #9
Yoderguy's Avatar
Yoderguy's Avatar
It's easily replaceable, but if you still have toyota care... Get them to take care of it. Here's the link for replacement.
https://r.tapatalk.com/shareLink?url...4&share_type=t
Lower Ball Joint Removal and Installation
Old 10-27-2016, 07:55 PM #10
Antman's Avatar
Antman Antman is offline
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Antman's Avatar
Real Name: Jeff
Like others have stated- tie rods are super easy to replace. Lower control arm a little more difficult/expensive, but still not too bad.
Thing is, if you are hearing a hum, I doubt either of these are the culprit. Loose feeling on the road? Yes. Noise- I doubt it.
Hum is usually a wheel bearing. Jack up each front wheel and spin/look for noise. You can also drive next to a concrete barrier wall with the window down at about 40 mph and the noise from a bad bearing will reflect off the wall. It will be very obvious- squeaking or buzzing. Also, if the noise gets louder while turning one way or the other while driving, it's most likely a bearing.
I've replaced 3 bearing assemblies on mine (one was my fault because I didn't replace the rear seal and it ruined the new bearing in less than a year...)
My .02
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 10-27-2016, 10:19 PM #11
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
@Yoderguy Thanks, this is the e-mail i got back from my dealer after I sent him pictures "Danny cannot do anything until vehicle on premises. The extended warranty will most likely want to send and inspector." So that doesn't look like a viable option.
Problem is, I'm supposed to go out to Death Valley next week so I don't have a lot of time to spend on this.
Best option maybe to take it to a shop and have them replace tie rods and LCA bearings.
OR
Can I wait and deal with this later? Could this lead to a bigger issue on the trails?
Dual Battery Thread
Old 10-27-2016, 10:23 PM #12
Yoderguy's Avatar
Yoderguy's Avatar
Depends on what you'll be doing, mild overlanding or rough terrain/crawling type of stuff. Personally, either way, I'd want it fixed before I went anywhere besides a 10 min drive to work. Is a trip to death valley worth being ruined over a few hundred dollar repair?
Old 10-28-2016, 09:37 AM #13
RPS99SHO's Avatar
RPS99SHO RPS99SHO is offline
RPS99SHO will become famous soon enough
RPS99SHO's Avatar
Man, you've obviously never owned a 3rd gen. Once those boots look like that, those LBJs are replaced, like, yesterday. Have you seen what a LBJ failure looks like?
RPS99SHO is offline   Reply With QuoteReply With Quote
Old 10-28-2016, 12:41 PM #14
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
Thanks for everyone's input... I really appreciate this community
Dual Battery Thread
Old 10-28-2016, 02:33 PM #15
stir_fry_boy's Avatar
stir_fry_boy stir_fry_boy is offline
stir_fry_boy is an unknown quantity at this point
Once they bust the grease out, it's only a matter of time until it fails. Its a good preventative measure to just replace them, only with OEM parts.
I personally think that broken boots on ball joints, CVs, and tie rod ends is the kiss of death to that part.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
stir_fry_boy is offline   Reply With QuoteReply With Quote
Best NON-OEM Lower Ball Joint ( LBJ ) MTD 3rd gen T4Rs 31 10-29-2017 02:43 PM
Lower ball joint nut Stiles97 3rd gen T4Rs 7 07-25-2016 10:59 PM
Lower Ball Joint on its way out? EricHartley 3rd gen T4Rs 14 05-29-2015 02:13 PM
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
Lower ball joint nissanh 3rd gen T4Rs 6 11-09-2013 09:16 PM
