Originally Posted by rennur
Anyone else want to chime in on this?
my guess is the front driver side camber is off. this will cause the drag on the driver side front tire pulling the steering wheel to the left.
another issue which I have seen is dragging brake caliper.
I doubt it is tire pressures since this has idiot operator sensors in the vehicle.
A properly aligned vehicle should pull to the right slightly , on a road with a normal sized crown . not to the left.
place a good amount of chalk on the tire front treads see if the tire tread chalk wears off the treads evenly on both across the full tread . if not then alignment issue.
my experience with dealerships is they do not do alignments on a new warranty vehicle . you must pay for it . which is why I check this out before putting my cash down on it. when the fix it then I do the deal.
