07-27-2017, 08:52 PM
#16
Originally Posted by bkone
Thanks for the detailed instructions. I was able to install the sliders successfully. however I still haven't installed the kdss skid. Can you please share a picture of how the skid looks after you cut the tab off?
I'm too lazy since it's a thousand degrees outside in Phoenix right now. However, as others suggested don't cut the tab. Try hammering it flat (bending it up) and see if the KDSS skid will fit.
See the photo under the step "Remove the two 12mm bolts holding the small KDSS skid plate". That tab between the two bolts at the top of the photo is the tab in question. I had just cut it level with the body of the KDSS skid removing it completely.
2015 4R Trail w/KDSS - 3D Maxpider Kagu Floormats - EliteSport+ Seat Covers - 4th Gen Cargo Net - Philips 921 Reverse Lights - Rigid D2 Driving Amber fogs - H11 HID Philips 4300k low beams - C4 Fab Rock Sliders - Dobinsons C59-724 / C59-599 - Nitto Ridge Grappler 265/70/17 - Spidertrax 1.25" spacers
07-28-2017, 11:34 AM
#17
Real Name: Mark
Real Name: Mark
Great information. Really nice sliders; this post will probably be the motivation I needed to finally bust out my credit card. And the under carriage of your truck is insanely clean.
2013 Trail (KDSS); Wheelers' T1/T13 combo; Camburg UCAs; 275/70/17 BFG KO2s; Hefty Fabworks Sliders; RCI front skid; Katzkin Leather; Baja Designs 30" S8 behind the grill; Satoshi grill; Warn Zeon Platinum installed on a BudBuilt hidden mount; Cobra 75 CB; Plasti Dip here and there.
10-10-2017, 10:41 PM
#18
Anyone know what the current lead time is for their sliders?
10-11-2017, 02:51 PM
#19
Real Name: Justin
Real Name: Justin
As someone with KDSS and in the market for sliders (likely C4, too)--thank you!!
Midnight Black 2017 TRD Off-Road Premium: KDSS, TRD Pro wheels, BFG KO2 265/70/17C, 3M Crystalline 40, Heritage Grille,
ARB CKMTA (Twin Compressor), Shrockworks Smog Pump Relocation, Gobi Stealth, C4 Fab Sliders
10-12-2017, 08:59 AM
#20
When I ordered mine on 9/14, the lead time was 6-8 weeks.
2017 TRD ORP | Icon Stage 2 w/Tube UCA's | Icon Shield Wheels | Nitto Ridge Grapplers | Yaesu FTM-100DR | 20% Tint
10-12-2017, 04:20 PM
#21
Real Name: Caleb
Real Name: Caleb
That's correct, current lead time is still 8 weeks.
Owner/Operator of C4 Fabrication. specializing in custom built Toyota off-road products. www.c4fabrication.com
10-12-2017, 04:49 PM
#22
Thanks for this! Will use this info for this weekend!
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
10-13-2017, 10:55 AM
#23
Sweet, will be ordering mine today. Should still get here 2 months before my gobi.
11-05-2017, 03:28 PM
#24
C4 Sliders install with KDSS
Thanks this was very helpful.
Central NJ
2016 TEP with KDSS in Silver
02-26-2018, 09:38 AM
#25
All done! Now grab a beer to ease your back pain.
Attachment 227397[/QUOTE]
Great job! Thank you for taking the time to help others out.
02-08-2020, 07:29 PM
#26
Thanks for the write up and the tip on the wood shims! That worked like a charm.
My own tip, use a thread tap for the two bolts on the passenger side without existing threads. For the two self tapping bolts, I had to use a 3/8”-16 thread tap to get them to screw in. They wouldn’t tap themselves. No worries though, but might be worth mentioning in the instructions.
Love these sliders. They look amazing.
2020 TRD ORP — MGM, KDSS, Billstein 6112 (2”) front, Billstein 5160 + 1” rear, C4 sliders, 275 WildPeaks, Rago rear window panels, GOBI stealth rack, HID low and LED high beams, SS3 sport yellow fogs, ARB single compressor, rock lights
05-26-2020, 06:47 PM
#27
Interested in getting the RCI sliders with the kick out. Stuck on the 5* vs 20*. I will be putting a RTT up top so I definitely want the rear kick out but not sure the angle. Not really planning to use the sliders as steps other than the RTT access as mentioned however I will be getting an ICON stage 7 suspension upgrade in the near future. Thoughts?
05-26-2020, 06:51 PM
#28
Well if you arent concerned about using it as a step (other than accessing the RTT), just get which looks best to you. Technically the Angled sliders slide easy along rock (as intended) so if you intend to crawl alot, consider getting those.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
05-26-2020, 07:11 PM
#29
I see people getting super involved in putting these sliders on.
I put some RCI sliders on a week ago. No jack stands, no wedges, etc.
Just used my body to hold up the slider, went on perfectly fine.
KDSS side is no big deal, just pry the mount clip a bit and move the slider in place. Grab a bolt and put one in the hold the slider and repeat on the other side.
05-26-2020, 09:21 PM
#30
Not really going to be rock crawling at all; just your occasional trail hick-up but if the need arises I want to be able to protect the asset! What I really don't want is to just have the same look as the original running boards on there now but I also want to make sure the misses can get in and out without 'too' much of a hassle.
