Old 11-18-2016, 12:25 PM #1
fernie fernie is offline
fernie is on a distinguished road
How to: Install Rock Sliders with KDSS
Thought I'd give back what I can, and document my experience installing rock sliders on a 4Runner equipped with KDSS.
My wrenching experience is limited to oil changes. So the thought of destroying KDSS lines crossed my mind several times. However, if you take your time you can get through this as I did. After driving around with only the passenger slider slider on the truck for a few weeks, I decided I needed to figure this out!
Only documenting the drivers side, as the KDSS lines run down this side of the frame.
Tip for the passenger side - bolt the slider to just one of the holes on the top right corner first when attaching the slider. Next, bolt or thread just one of the holes on the top left corner. Doing this will allow the slider to pivot up more easily so you can align all of the holes on the slider to the frame.
Tools Needed:
  • jack (multiple are helpful)
  • jack stands or blocks or whatever
  • impact wrench (optional but helpful for removing bolts)
  • 12mm socket (1/2 and 3/8 inch came in handy)
  • 13mm socket (1/2 and 3/8 inch came in handy)
  • socket extensions
  • 13mm wrench with swivel or flex ratcheting
  • torque wrench
  • anti-seize
  • wood shims
  • hack saw
Parts Needed:
  • a 4Runner
  • rock sliders (C4 are used in this example)
1. Let's get started -
How to: Install Rock Sliders with KDSS-1_img_0760-jpg
2. Closeup of items needed -
How to: Install Rock Sliders with KDSS-2_img_0761-jpg
3. Using a 12mm socket, remove the drivers side parking brake fastener - (push the brake line up and out of the way)
Also, remove the bolts for each of the two KDSS brackets.
How to: Install Rock Sliders with KDSS-3_img_0762-jpg
4. Remove the three 12mm bolts holding the gas tank skid only in this picture. Do not remove the 3rd bolt in from the left. This is for the fuel tank strap. Leave it alone.
We don't need to remove the gas tank skid completely. It just has to drop down far enough so that we can get the slider in between the frame and the gas tank skid.
Not pictured, but you will also need to remove two more 12mm gas tank skid bolts towards the rear of the 4Runner. After removing these the gas tank skid will hang down low enough to get the slider in. I used the socket extensions to remove these two additional bolts.
How to: Install Rock Sliders with KDSS-4_img_0763-jpg
5. Another picture of the fuel tank strap bolt. Leave this one alone.
How to: Install Rock Sliders with KDSS-5_img_0764-jpg
6. Remove the two 12mm bolts holding the small KDSS skid plate.
How to: Install Rock Sliders with KDSS-6_img_0765-jpg
7. Another angle of the small KDSS skid plate.
How to: Install Rock Sliders with KDSS-7_img_0766-jpg
8. KDSS lines now exposed with the skid removed.
How to: Install Rock Sliders with KDSS-8_img_0767-jpg
2015 4R Trail w/KDSS - 3D Maxpider Kagu Floormats - EliteSport+ Seat Covers - 4th Gen Cargo Net - Philips 921 Reverse Lights - Rigid D2 Driving Amber fogs - H11 HID Philips 4300k low beams - C4 Fab Rock Sliders - Dobinsons C59-724 / C59-599 - Nitto Ridge Grappler 265/70/17 - Spidertrax 1.25" spacers
fernie is offline   Reply With QuoteReply With Quote
Old 11-18-2016, 12:26 PM #2
9. Ensure the gas tank skid is hanging down far enough to move the slider in between for later.
How to: Install Rock Sliders with KDSS-9_img_0768-jpg
10. Prepare a couple of wood shims about 4 inches long or so. Will be easier to work with if not too long since there isn't much room. (ignore the lube for now)
How to: Install Rock Sliders with KDSS-10_img_0769-jpg
11. Insert a wood shim in between one of the brackets. Just enough that it pushes the KDSS bracket away from the frame.
As the slider is pushed up into place, these would shims will be close to falling out on their own.
How to: Install Rock Sliders with KDSS-11_img_0770-jpg
12. Insert a second wood shim on the other remaining KDSS bracket.
How to: Install Rock Sliders with KDSS-12_img_0771-jpg
13. We are now ready to mount the slider to the frame. This was my second go-around at installing these things. Jack stands proved to be very difficult in balancing a 60 pound or so piece of metal. I found cinder blocks with towels placed under to work very well. Height wise, the cinder blocks were perfect.
How to: Install Rock Sliders with KDSS-13_img_0772-jpg
14. I found it easier to work on installing the left side of the slider first (closest to front of 4Runner).
Begin to jack up the slider and carefully get it in between the KDSS lines.
How to: Install Rock Sliders with KDSS-14_img_0773-jpg
15. Attach a 13mm bolt to the bottom left hand corner of the slider. Apply some anti-seize to the bolt if desired. Do not tighten completely.
I only inserted this bolt for now on the left side of the slider. This will allow the slider to pivot when we lift up the right side of the slider. Also it will keep the slider from falling and hitting the lines when working on the right side.
Keep one jack under the slider on the left side to support the weight of it as it pivots.
How to: Install Rock Sliders with KDSS-15_img_0774-jpg
Old 11-18-2016, 12:26 PM #3
16. Using a second jack, slowly start to jack up the right of the slider. Be mindful of whole slider the entire time as it is moving.
How to: Install Rock Sliders with KDSS-16_img_0775-jpg
17. Make sure the slider is pushed back against the frame when jacking it up. This will help ensure it makes it behind the KDSS lines.
How to: Install Rock Sliders with KDSS-17_img_0776-jpg
18. Once the slider is up between the KDSS lines, remove the wood shims if they haven't already fallen out.
How to: Install Rock Sliders with KDSS-18_img_0777-jpg
19. Don't forget about the gas tank skid. Make sure the bottom part of the slider is between the frame and the gas tank skid plate.
How to: Install Rock Sliders with KDSS-19_img_0778-jpg
20. Slider is in.
How to: Install Rock Sliders with KDSS-20_img_0779-jpg
21. Begin to attach all of the supplied 13mm bolts to the remaining holes.
How to: Install Rock Sliders with KDSS-21_img_0782-jpg
Old 11-18-2016, 12:27 PM #4
22. Bolt up the fuel tank skid plate. (not pictured)
23. This part I was not happy about. Perhaps others found a better way. However, the small KDSS skid plate could not be re-attached without some modification. Hence, the hacksaw.
Between the two bolts, the see the metal tab. After installing the slider, this metal tab cannot be inserted as the hole is blocked by the slider. Only way I found to install this KDSS line protector / slider was to cut off the tab. (picture is with the tab showing what to cut)
All done! Now grab a beer to ease your back pain.
How to: Install Rock Sliders with KDSS-img_0754-jpg
Old 11-18-2016, 12:50 PM #5
Brandonium's Avatar
Brandonium Brandonium is offline
Real Name: Brandon
Brandonium will become famous soon enough
Brandonium's Avatar
Real Name: Brandon
Nice write up! Couple of things I had to do when putting on my C4 sliders.
1). I had to entirely unbolt the tank skid. Without doing that it was just too difficult to get the skid to stay in a pulled back position. This may vary between installs but I because so frustrated with it that I just removed it entirely and put it back once the skid was in place.
2). The KDSS line guard near the front would not go back into place once the skid was mounted without me cutting off the tab that went into the frame. Once this tab was removed I was able to place the guard back in place but it did require me to use a few extra washers on the bolt nearest to the front in order to level the guard.
3). There's nothing that you really need to brace once the KDSS lines and the box have the bolts removed. Those lines are so stiff that they barely move even once everything is unbolted.
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
Brandonium is offline   Reply With QuoteReply With Quote
Old 11-18-2016, 01:59 PM #6
Thanks!
Great. Good to know I'm not the only one who had to hack off the tab.
Old 11-18-2016, 08:33 PM #7
Ohio_Steve's Avatar
Ohio_Steve Ohio_Steve is offline
Real Name: Steve
Ohio_Steve is on a distinguished road
Ohio_Steve's Avatar
Real Name: Steve
Nice write up and photos. @Ohio Hawk did his on his own, and then helped with mine, so I took advantage of his experience.
One thing that I think helped move the sliders into place and keep them level was the use of a Craftsman motorcycle lift that I have. You can easily lift it into place and roll it wherever it needs to be without multiple jacks or jack stands. If you have a motorcycle riding body, see if he has something similar.
Steve - Northern Ohio, USA
2021 Toyota LC200 - 2017 Hiker Squareback Trailer - 1958 MGA Roadster
Wandering around on occasion, always lost
Ohio_Steve is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 09:55 PM #8
heron163 heron163 is offline
heron163 is on a distinguished road
great thread - wish I had something like this first time I installed sliders...
heron163 is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 11:14 PM #9
C4 Fabrication's Avatar
C4 Fabrication C4 Fabrication is offline
Real Name: Caleb
C4 Fabrication has a spectacular aura about C4 Fabrication has a spectacular aura about C4 Fabrication has a spectacular aura about
Real Name: Caleb
Thanks for posting up the detailed rite up on the install! Lots of great close up photos and good tips.
The reason we do not have a hole in the forward lower plate where the small KDSS skid plate goes, is because we have actually not even had a KDSS equipped 4runner available to bring in our shop and do an install. We used the same lower mounting plates as we do on the non-KDSS sliders. So we do not have a measurement to work from as to where we could put a hole for the tab.
The easiest way to address this is to just lay the KDSS skidplate on a table or cinder block in your case would work well, and flatten the tab with a hammer. That way the tab doesn't need to go back into a hole, and you don't have to bust out the hack saw or grinder to remove the tab.
Do you mind if we post a link to this thread in our vendor sub forum for others to see?
Owner/Operator of C4 Fabrication. specializing in custom built Toyota off-road products.www.c4fabrication.com
C4 Fabrication is offline   Reply With QuoteReply With Quote
Old 12-05-2016, 11:34 PM #10
Yes, perhaps hammering the tab flat would have been an alternative solution. If I could have slept on it overnight that would make sense, but at the moment the hacksaw was the first option that came to mind after endless hours
No not at all, yes please share from my experience or me learning the hard way!
Old 12-06-2016, 11:10 AM #11
Real Name: Caleb
Real Name: Caleb
No not at all, yes please share from my experience or me leaning the hard way!
Thank you, we attached a link to our install instructions page. We really appreciate it!
Old 04-01-2017, 09:29 PM #12
Señor_Godric's Avatar
Señor_Godric Señor_Godric is offline
Señor_Godric is on a distinguished road
Attachment 227395
Attachment 227397
I can't even put that skid plate back on. Its insane
Señor_Godric is offline   Reply With QuoteReply With Quote
Old 04-01-2017, 11:31 PM #13
greatape's Avatar
greatape greatape is offline
greatape is on a distinguished road
greatape's Avatar
Very nice write up and C4 fabs some very nice sliders from beautiful SD..
Mitakuye Oyasin
greatape is offline   Reply With QuoteReply With Quote
Old 04-02-2017, 01:52 AM #14
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons will become famous soon enough
Real Name: Dave
Installing Domello rock sliders
I had similar experiences installing the Domello rock sliders. I just used a bunch of wood blocks of various thicknesses to prop up the sliders until it was in place. I lifted one end at a time and slid in another block until it was high enough. Once I got a bolt in at each end the rest of them were easy.
With the Domello I did not have to remove the gas tank skid plate and as many other parts. I unbolted the KDSS lines and removed the KDSS line skid plate where the lines wrap under the frame and the skid under the control unit, shown in the photo below.
The hardest part with the Domello sliders was I had to remove the nut holding the KDSS control unit, a machined aluminum block, to the frame and shift the unit out 1/4". The one bolt holding it to the frame is semi-hidden, up on top of the unit. I couldn't get a socket wrench in there and the space above the unit only allowed about a 10 degree turn with each pull of the open end hand wrench. I could have used the ratchet closed end wrenches I have now. It took a long time to remove that nut and slide it back. Later the nut passes through a hole in the Domello sliders made for the KDSS unit.
As you may have noticed, the KDSS skid plate is bolted to the bottom of the KDSS unit so if you really smash the skid plate hard you could shear off that bolt. Makes me want to fabricate a skid plate that only bolts to the frame.
How to: Install Rock Sliders with KDSS-sized6915-jpg
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 07-27-2017, 12:46 PM #15
bkone's Avatar
bkone bkone is offline
bkone is on a distinguished road
bkone's Avatar
Attachment 227395
Attachment 227397
Thanks for the detailed instructions. I was able to install the sliders successfully. however I still haven't installed the kdss skid. Can you please share a picture of how the skid looks after you cut the tab off?
bkone is offline   Reply With QuoteReply With Quote
Rock sliders / Rock rails 4RunnerTrail 5th gen T4Rs 75 02-08-2021 08:57 PM
Savage Off Road Rock Sliders Install (Lots of Pics and a Welding Video) wmeredith 3rd gen T4Rs 16 04-20-2018 11:55 AM
Budbuilt rock sliders work with KDSS? heron163 5th gen T4Rs 7 06-23-2014 12:44 AM
Schrockworks/Rock Road Rock Rail Install ? 36bound 5th gen T4Rs 8 03-23-2012 06:53 PM
