Old 11-19-2016, 12:27 PM #1
Lindenwood's Avatar
Lindenwood Lindenwood is offline
Lindenwood is on a distinguished road
Lindenwood's Avatar
60" Hi Lift Jack cargo area fitment request?
Hello, all! I have begun collecting wheeling and adventure gear for the new TRDP, and have been digging around for ways to temporarily (but securely) store a hi-lift jack. We are trying to avoid major exterior modifications, but are gatherig up some of the more essential temporary overland options (hi lift in lieu of a winch, Yeti instead of a fridge, an alligator-clamp compressor instead of a permanent one, etc).
Long story short, can anyone with a 60" Hi Lift verify if their jack would fit, lying flat, in the space pictured below (where the tape measure is)? I measured it at 61-63" (the side panels are curved), but I am mostly concerned about the bulkier base and mechanism preventing it from fitting well). I am totally willing to remove the base to make it fit, and re-pin it in place when needed. I do intend to create some form of secure mounting solution for safety. Also, yes, the dogs do sit back there, but we keep a ~3" thick dog pad back there which would cover the jack (so they probably wouldnt even notice).
Thank you!
60" Hi Lift Jack cargo area fitment request?-20161119_100416-jpg
Lindenwood is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 02:34 PM #2
Ol'Baditude's Avatar
Ol'Baditude Ol'Baditude is offline
Real Name: Pat
Ol'Baditude is on a distinguished road
Real Name: Pat
You're going to want to remove the base anyway since it rattles like crazy. My 60 is mounted on the roof rack and it still clearly audible. I just lay it flat under my driver's seat and it stays put.
You'll probably want to get a neoprene cover for the runner works as well, to help deaden the sound of the non-fixed parts rattling around.
As for mounting x-ways in the cargo area, from inner wheel well to inner wheel well is 40" so there should be enough room from wall to wall if it's lifted off the floor a bit and can slide into the cubby on the right. It will definitely be close, and you'll need something solid to mount to, like a drawer system or bolting directly to the floorboards.
Can't imagine the whole thing is going to play well with your dogs though.
2011 Mag Grey SR5 Build & Pics / Front: Walker Evans 2.5" C.O's, AllPro UCA's, TC Spindle Gussets / Rear: Icon 2.0 LT w full MetalTech HD Rear LT Setup, Skyjacker sway links/ Odyssey 34R-PC1500 / Cooper STT Pro LT295 70 R17 E / CountersteerX's / Baja Flat Rack, HighliftX, CVT Mt.Shasta / BudBuilt bumpouts & Aluminum Skids / 10lb PowerTank / ARB Breathers(F&Rdiff,Tcase,Trans) / Shrockworks Front Bumper / Superwinch Talon 9.5 w Viking synthetic / Radio: Yaesu FTM-400DR, Comet 2x4, SBB1,SBB5,SBB7. AND NO FRONT F*CKING SWAYBAR!!!
VE6TXS
Ol'Baditude is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 03:13 PM #3
Lindenwood's Avatar
Lindenwood's Avatar
Indeed, the 61-63" measurement is aft of the wheel wells, and all the way into the lower cubby on the right side. I believe it will likely fit, but I want to make sure before buying one and possibly having to ship it back.
We have the slide-out tray, which appears to be at the right level to allow the jack to rest on it with the top fitting into the cubby on the right side. I expect I will build brackets on either side of the tray to secure the jack.
As far as the dogs go, their pad really is pretty nice haha. I think with the jack being only a few inches from the back hatch, and the 3" pad on top of it, it shouldn't be much in the way. Worst case, I'll wrap it in a towel if I feel like it protrudes into their space enough to create a hazard. But, they are pretty tough, heh. The oldest one used to go wheeling with me in my Samurai, and I'd hit trails rough enough that I had to create a strap in the seat to secure his harness so he wouldn't fly around the cabin!
Attached was him as a puppy! Gosh, I can't believe he's 8 now...
60" Hi Lift Jack cargo area fitment request?-sammy_in_samurai-jpg
Old 11-19-2016, 03:21 PM #4
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
I know it might not be much use but here is my 48" Extreme mounted in the back.
You can see 6" additional on a side is going to be a lot and tight. Also you really need to have more of a permanent mount for it. You don't want to get into an accident or be off road and have that heavy jack get free in the back and become a weapon.
It has since been moved to the rear bumper so it is out of the truck.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 03:39 PM #5
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
A bungee cord from the base to one of the holes on the beam works fine to keep the base from rattling. I bolt mine to the roof rack and it pretty much stays there all summer. Keep a can of silicone spray in the truck to lube it up when/if I need to use it.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 04:54 PM #6
Lindenwood's Avatar
Lindenwood's Avatar
I had actually found a thread where you posted this picture! You and a few other folks posted jacks mounted in the cargo area in one way or another.
And I definitely intend to mount it securely back there, probably running bolts through the floor in one fashion or another.
*edit*
In that thread, it was specifically this post that gave me the idea.
http://www.toyota-4runner.org/922887-post11.html
I suppose I could split the difference and cut a few inches off the top if I had to. (The main reason I want the 60" is for winching, so an extra 10 inches is still at least 20% more actual travel).
Old 11-19-2016, 06:36 PM #7
*edit*
I think that's probably the best mounting spot inside the cab since it will interfere the least. Since I had the drawers putting it on the tailgate side would have made putting things in the back a pain.
Old 11-19-2016, 06:47 PM #8
shearn shearn is offline
Real Name: My kids call me "Old Man"
shearn is on a distinguished road
I have a 60" jack. I use these on the roof rack. Zero issues. And, when I'm home/travelling on highway, it comes right off.
https://www.amazon.com/Hi-Lift-Jack-.../dp/B003CEODQI
2016 MGM KDSS TEP. Bilstens @ 1.75. RCI Sliders. 275/70/17. A little plasti-dip.
shearn is offline   Reply With QuoteReply With Quote
Old 11-19-2016, 10:27 PM #9
Lindenwood's Avatar
Lindenwood's Avatar
Ah, do those fit securely on the factory roof rail?
Old 11-20-2016, 01:06 AM #10
Vinsil's Avatar
Vinsil Vinsil is offline
Vinsil is on a distinguished road
Vinsil's Avatar
Lots of FJ guys said they used them on their factory rails. I'm going to order some, thanks for the link.
'16 TEP. Ecotechne roof rack, BFG 285’s on Method BL's, Dobinsons 3”/2" lift, MT sliders, slimline front bumper Smittybilt winch, Expedition One rear bumper, Indel-B 50 fridge, lots more.
M416 Offroad trailer build in progress, RTT, Compact camping Concepts rack system, 275 BFG’s on FJ steelies, more coming...
Vinsil is offline   Reply With QuoteReply With Quote
Old 11-22-2016, 08:40 PM #11
Sorry I missed these comments. Yes, they fit very well. I wrapped them with duct tape, but probably didn't need to do that.
I have the base toward the back of the vehicle. The whole thing is tilted inward, and the base kind of "rests" on the black plastic roof rack mount. I'll have it on over the weekend and will take a pic.
It really is easy to install and remove. Less than 5 mins.
Old 11-22-2016, 08:46 PM #12
Vinsil's Avatar
Vinsil's Avatar
Nice, pics would be great even though I ordered them already.
FS: Brand New Hi-Lift Jack XT485 48" Hi-Lift X-TREME Jack ($90) Philadelphia PA Alex T4R For Sale: T4R Items 6 01-20-2018 03:23 AM
Image Request cargo area 2014 TheLast13 5th gen T4Rs 8 01-06-2014 03:20 PM
Pic request: post up your pictures of a ~3" suspension lift + 1" body lift. 98LtdT4R 3rd gen T4Rs 4 12-07-2013 11:25 PM
**SOLD** 4Runner Cargo Area Hi-Lift Jack Mounts Rock Slide Classifieds - buy & sell (no commercial ads please) 5 03-24-2010 02:20 PM
Pic request hi-lift jack mounting haddix 3rd gen T4Rs 2 05-13-2009 09:11 AM
