12-04-2016, 12:21 AM
Disable Rear Window defog /defrost?
Is there any write up on disabling the rear window defroster?
I want the make sure it can't be turned on because it will mess up the tint on the window.
Most cars that I owned I always unplug the element to avoid heating the tinted window.
Just wondering if anyone else has done this?
If not I might do a write up when I do mine.
12-04-2016, 12:25 AM
Is it after-market tint or factory ?
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
12-04-2016, 12:36 AM
Does the window defroster actually get hotter than the sun beating down on it during summer? Inside of my truck will hit 140 degrees here in Vegas. My windows are all tinted on all my vehicles and have never run into an issue. Tint shop said nothing either.
12-04-2016, 01:11 AM
Try the fuse?
Best Regards,
Saker
12-04-2016, 02:33 AM
Unplug it from behind the switch. The fuse may tie in other functions.
12-04-2016, 02:40 AM
Originally Posted by yoderguy
unplug it from behind the switch. The fuse may tie in other functions.
this.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
12-04-2016, 04:38 AM
It's after-market tint.
The lines on the window heat up and cause distortion or bubbling. I'm sure you must see some cars that the rear window looks messed up. That's because the accidentally turned on the defroster.
Originally Posted by Saker
Try the fuse?
I don't want the disable the mirror defroster. The switch is tied into both mirrors and the rear window.
I only want to dis-connect the rear window the prevent damage to the aftermarket tint.
12-04-2016, 05:11 AM
pull the interior panel and get in there and physically disconnect the wire from the glass?
12-04-2016, 08:28 AM
Real Name: Dave
Real Name: Dave
Who did your tint, and where did you get your information? I've been having aftermarket tint done to vehicles for over 20 years, and this has never been an issue. This has been on a Ford Expedition, 3 Hondas, and now our 4 Runners. I'd find another tint installer. I suspect the bubbling and distortion you see are poor quality materials or installation. I use AltaMere in Oklahoma (as a reference) and their work has been great. I just keep scratching it. Hope this helps.
2019 GX460, Nebula Pearl. 2014 LE, Mag Gray (sold).
Stable mates: 2020 Subi Ascent Limited, 2021 TRD O/R Premium Black
12-04-2016, 09:19 AM
Why not just put some duck tape across the button so you don't hit it by mistake?
That's what I did when I had my windows tinted over the summer.
Only 4 days to properly cure though I waited a full week to take the tape off just to make sure it was cured properly...
2016 Toyota 4Runner Limited
Magnaflow catback exhaust, K&N performance air filter, 35% front/20%rear window tint, Diode Dynamics LED bulb swap for the interior, Toyota hood wind deflector, Weathertech side window deflectors and floor liners, Toyota logo blackout kit, BlendMount rearview mirror mount with hard-wired Escort radar detector, and Viper security system with SmartStart remote starter phone app
12-04-2016, 09:31 AM
Banned
Banned
I've always run defroster with aftermarket tint and I've never had an issue and they never told me not to run the rear defroster
Sent from my HTC6525LVW using Tapatalk
12-04-2016, 10:52 AM
Real Name: 3 guesses..........
^^^ agree with both posts, been tinting my vehicles for 20+ years and never had any issues with rear defogger causing bubbling or lifting. If anything tint actually increases defogger efficiency.
I'm coming up on 5 years of ownership, my tint looks as good now as it did the day it was installed. Quality tint, properly applied is key!
'12 SR5, Blizzard Pearl * Factory (style) Fog Light Switch-Fits knock-out! * 30" BD Stealth LED Light Bar, Upper Grill '12 SR5 * Reverse Light Mod-SR5 Factory Bumper * FN f(x) Pro Wheels - Custom Coating * LLumar Paint Protection/Tint, Flowmaster Cat-Back, Bilstein 6112/5160, LR UCA's, AirLift w/Load Control, 285/70/17 Nitto TG, LW's D2S 4.0 HID low beam mod, V-LED Interior/Reverse/LMZ High Beam/Turn Signals/V-6 DRL Lights (all 5000K), Kappa Dash/Doors/Hatch Speakers, CompuStar Remote Start, B&M Trans Cooler, Devil Horn Emblems, XB LED Fogs, Dongle Mod, TRD CAI, DC 270-XP Alt
12-04-2016, 10:58 AM
Try the fuse?
But wouldn't that also disable side mirror defrosters as they are controlled by the same switch
12-04-2016, 11:05 AM
If OP wants to disable, this would be the best way to achieve the outcome he is looking for IMHO.
12-04-2016, 11:16 AM
Real Name: Charles
Real Name: Charles
A) As already said, disconnect and take care of the wires were they attach to the back glass so your side mirror defrosters will still work
B) I think this need is bogus
C) You tinted the back glass? Its already dark...
D) You live in hawaii......how often do you need defrosters?
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
