Old 12-15-2016, 05:59 PM #1
SkidPalace's Avatar
SkidPalace SkidPalace is offline
SkidPalace is on a distinguished road
SkidPalace's Avatar
Undercarriage very noisy over light bumps/potholes. Faulty X-REAS?
My 2015 LE with only 9500 miles has been experiencing a lot of banging/clacking over rough road conditions and light potholes.
I had it in to the shop for the 18 month free service and of course the mechanic couldn't hear anything out of the ordinary. All suspension links were tight, no rattles.
This is the first X-REAS equipped truck I have owned and I have read about several instances of costly failures on this forum with most people ditching the X-REAS for standard shocks after the warranty expiration.
I am wondering how does a faulty X-REAS system let you know that is bad? Is it just a leak that gives it away or does it start to make nose or handle poorly?
I am planning to bring it back to them and tell them to find the problem once and for all.
Thanks.
2015 Magnetic Grey Limited with Redwood interior. 275/55r20 Michelin Defender LTX on stock wheels. Daystar 2.5/1.5 puck lift.
Gone but not forgotten: Black 2000 SR5 "Highlander", Supercharged, Black pearl emblems, Factory e-Locker.
SkidPalace is offline   Reply With QuoteReply With Quote
Old 12-16-2016, 12:12 AM #2
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Find a section of road that consistently causes problems . Buy some cheap FRS radios. Use tape or zip ties to key up one of them. Move the FRS around while you drive the same section of road. Keep moving the FRS to isolate the noise.
wcjeep is offline   Reply With QuoteReply With Quote
Old 12-16-2016, 02:12 PM #3
SkidPalace's Avatar
SkidPalace's Avatar
Well it's back in the stealership to have them look at it again. It's like 8 degrees out and I lasted about 2 minutes under the truck to try to inspect it myself.
I'd really like to hear from someone that had a failed X-REAS system to know if the clunking is the shocks or not.
Old 12-17-2016, 03:37 AM #4
SkidPalace's Avatar
SkidPalace's Avatar
I guess not too many people are interested in this topic but, for the record, my X-REAS system is in fact blown with less than 10K miles on the clock.
Parts are ordered by the dealer and a complete system replacement will take place next week under warranty.
Gotta love that Toyota quality.
Old 12-17-2016, 08:11 AM #5
NoLight's Avatar
NoLight NoLight is offline
Real Name: Charlie
NoLight is on a distinguished road
NoLight's Avatar
Real Name: Charlie
Wow 10k glad they are fixing it for ya, but gotta wonder what will happen in the next 10k
Immune, Steve!
NoLight is offline   Reply With QuoteReply With Quote
Old 12-17-2016, 09:13 AM #6
jfm1982 jfm1982 is offline
jfm1982 is on a distinguished road
Did they tell you which part failed?
jfm1982 is offline   Reply With QuoteReply With Quote
Old 12-17-2016, 11:07 AM #7
bcolts bcolts is offline
bcolts is on a distinguished road
Bad luck, but on the bright side you get a new system for free. I'm on my second 4Runner, both with xreas. The first one had 270,000 miles on it and this one currently at 149,000 and no xreas issues with either (probably just jinxed myself). My bro in law has a 2008 he bought new with no xreas issues either. I read plenty of posts on here where people have a different experience and in fact remove the system before "it goes bad". Maybe they are heavy off-roading fans--I'm more interested in a daily driver that can get me through snow or let me occasionally play on the beach--but I am definitely in the pro xreas camp. Don't give up on it yet!
bcolts is offline   Reply With QuoteReply With Quote
Old 12-17-2016, 11:11 AM #8
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
Doubt it's lack of interest, blown Xreas this early doesn't seem to be that common, but it happens. On this forum you will see a very high replacement rate because we just can't help ourselves. I would have assumed the system would have leaked to the point there wasn't much fluid for a clunking noise. If that was the case it also had to drive pretty poorly as well?
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 12-19-2016, 04:19 PM #9
SkidPalace's Avatar
SkidPalace's Avatar
They did not. I will be sure to ask for a visual inspection before they get started.
Old 12-19-2016, 04:33 PM #10
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
It could have been just a large pothole hit at speed. Anything that would blow a regular shock could also screw up XREAS. I have been unlucky to have blown a shock in just a few hundred miles and lucky enough to have shocks go 100K+. It's always a speed/force thing. Now with XREAS you have a bit more componentry that could get damaged too, or it could be bad from the factory although that is fairly rare with the 4Runners.
1engineer is offline   Reply With QuoteReply With Quote
Old 12-19-2016, 04:44 PM #11
SkidPalace's Avatar
SkidPalace's Avatar
That was my thought exactly when I bought the vehicle. I thought it drove nicely compared to my third gen, and compared to the Trail with KDSS and Pro with it's Billys. I hope the replacement parts hold up indefinitely, but I don't expect to own this truck forever like my 2000 that I loved and lost to frame cancer.
Old 12-19-2016, 04:50 PM #12
SkidPalace's Avatar
SkidPalace's Avatar
Yeah, that's the weird thing. I have never seen a single drop of fluid under my truck. It would also be impossible for me to see a small leak, since I completely coat the underside of my truck with Fluid Film to prevent corrosion. As far as poor ride quality, I didn't really notice. It definitely did not bounce or wallow like you would think a car with no shocks would do. Just the noise.
Old 12-23-2016, 01:36 PM #13
SkidPalace's Avatar
SkidPalace's Avatar
Got the truck back yesterday. Looks like they replaced everything. Front and rear shocks, all hard and soft lines and hangers and both center control absorbers.
Never did get a chance to ask the tech what parts failed. Nice to have a quiet cush ride again.
Old 12-23-2016, 02:15 PM #14
Jaxrunnr Jaxrunnr is offline
Jaxrunnr is on a distinguished road
Hmmm, now I'm wondering if mine is faulty. I just purchased a 2016 Limited with 14k miles. Shortly after, I noticed a lot of creaking in the front end and such when applying the breaks and going over bumps etc. I also have some occasional slight chassis vibrations.
Think my Xreas could be faulty?
Jaxrunnr is offline   Reply With QuoteReply With Quote
Old 12-23-2016, 02:39 PM #15
MarkWalker MarkWalker is offline
MarkWalker is on a distinguished road
2012
My previous 4R was an 11 and at about 80k when I had it in for service they told me had a slightly leaky shock. $800-$900. I did not have it repaired as I was preparing to trade the vehicle, which I soon did. That was the only mechanical issue I ever had with the 4R.
If I had kept it, I would have just ripped it all out and gone aftermarket. $800 would be a very good start on a full suspension.
If I get that far (leaky shock) with my '16, XREAS will get replaced. I've got 9k on it now and its been flawless, but this is in 3 months and lots of highway miles. Fingers are crossed for no issues.
MarkWalker is offline   Reply With QuoteReply With Quote
limited edition , noisy suspension , shocks , sway bar , x-reas
Knocking sound when going into small potholes Lug1 3rd gen T4Rs 15 11-29-2015 03:01 AM
faulty ubj from o'riellys 95yotarunner619 3rd gen T4Rs 5 02-27-2015 04:54 PM
NYC Potholes RocknRofl 5th gen T4Rs 20 03-13-2014 01:09 PM
Faulty MAF and before CAT O2 Senors and no light...possible...Yes! 2004TR4-SR5 4th Gen T4Rs 14 10-05-2012 01:26 PM
Noisy & I mean NOISY Fuel Injectors!! Spartan57 Classic T4Rs 4 05-13-2005 10:03 AM
