Originally Posted by Jaan
No. I don't drive it much, I do fill it up every fuel stop but it was between 1/4 and 1/2 when I parked it for a week and then the smell happened.
I did fill it up the next day to see if maybe that would work...it still took a couple of days for the smell to go away.
I'm the only person who fills the tank. I never over fill it. I always stop after the click.
no comment on garage parking ....
since you regularly fill it then short use, this can be a damaged fuel vapor system. I would stop filling it to the max. fill to the 3/4 mark. each 1/4 mark is 4.5 gallons when at 1/4 put in 9 gallons .
if your on a trip and then filling to the max is OK, because the fuel will rapidly drop as your on the road. it is amazing how much 20 gallons of gas can expand with a temp swing of 40-50 deg F..
