Old 12-29-2016, 09:53 PM #1
acolle acolle is offline
acolle is on a distinguished road
Questions about the inverter/power outlet in the cargo space...
I'm trying to figure out if I can use a specific Lithium battery charger with the inverter/outlet back in the cargo space.
Here are the charger specifications:
Questions about the inverter/power outlet in the cargo space...-screen-shot-2016-12-29-5-40-18-pm-png
Here is the vehicle info I've pulled the the forums:
Maximum available capacity of the inverter/power outlet
■ While the vehicle is being driven the maximum capacity of the power outlet is always 120 V AC/100W.
■ When the vehicle is stationary the maximum capacity of the power outlet varies depending on the position of the shift lever.
● The maximum capacity is 120 V AC/100 W when the shift lever is in any position other than P or N.
● The maximum capacity is 120 V AC/400 W* when the shift lever is in P or N.
* Maximum capacity of 400 W can only be restored by turning the power outlet main switch off and then on again with the shift lever in P or N.
So from what I'm gathering, and if my brain is working right, I'd be ok @ maximum capacity of 400 W, with the shift lever in P or N, as far a meeting the charger specifications. But I have ZERO idea on how I might verify the Inverter's Output Frequency, Voltage Range or Efficiency?
Any thoughts?
2016 TRD Pro, Super White
acolle is offline   Reply With QuoteReply With Quote
Old 12-29-2016, 10:01 PM #2
Jeremy556's Avatar
Jeremy556's Avatar
What kind of batteries are you charging? It is very inefficient to go DC to AC to DC, can't you get a charger that takes 12v input?
Old 12-29-2016, 10:18 PM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
You can't verify frequency without a scope or frequency meter that will measure 60 cycle range. You can however plug an incandescent (not CFL) light bulb into the socket and see what it looks like. At 50 cycles you might be able to see it flicker. At 60 you shouldn't.
Old 12-29-2016, 10:29 PM #4
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
I think you will be fine, what they "recommend" and what will work are two different things. My fridge is UL listed at 6A, but I don't believe it pulls that much, and it's on the inverter for now. I UL certify control panels at work and they don't use even close to what we are required to put on the schematic. Try it out and report your results.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 12-29-2016, 11:43 PM #5
Charger:
» C750 Rapid Battery Charger | Oregon Cordless
Battery:
» B650E 6.0 Ah Battery Pack | Oregon Cordless
They don't offer a 12V input. So I'm looking to see if I can use the 120V if/when needed.
Old 12-30-2016, 10:05 AM #6
e60ral e60ral is offline
Banned
e60ral will become famous soon enough
Banned
I don't think the factory inverter is pure sine wave, but I may be wrong
Sent from my HTC6525LVW using Tapatalk
e60ral is offline   Reply With QuoteReply With Quote
Old 12-30-2016, 01:37 PM #7
Originally Posted by e60ral View Post
I don't think the factory inverter is pure sine wave, but I may be wrong.
I bet you are right. I'm seeing a lot of speculation that the factory inverter is not pure. But I can't find any confirmed data or specifications on the factory installed parts.
Old 12-30-2016, 02:52 PM #8
flyrv9's Avatar
flyrv9's Avatar
To find out what the sine wave looks like you will need a scope.
Old 12-30-2016, 03:05 PM #9
Foques's Avatar
Foques Foques is offline
Foques is on a distinguished road
Foques's Avatar
Originally Posted by acolle View Post
Charger:
Battery:
that specific combo can and does charge without an issue in my '15 TE
My Photography - My Facebook - Build Thread
Foques is offline   Reply With QuoteReply With Quote
Old 01-02-2017, 01:47 PM #10
Thank you!
Power inverter questions m007allred 3rd gen T4Rs 15 03-14-2019 12:20 PM
After market power inverter + aux in the cargo decker1 4th Gen T4Rs 7 05-26-2014 05:33 PM
screw the inverter.. i want an OUTLET Jc12 3rd gen T4Rs 17 03-05-2012 11:30 PM
A/C Power Switch / Electrical Outlet, and inverter. A/V1 Classifieds - buy & sell (no commercial ads please) 4 09-10-2008 06:29 AM
Power Outlet Inverter YZThumper 4th Gen T4Rs 4 07-22-2005 02:35 PM
