Old 01-03-2017, 10:54 AM #1
walstylez's Avatar
walstylez walstylez is offline
walstylez is on a distinguished road
walstylez's Avatar
Using iPhone w/ USB Audio Out to play music to 2016 Entune Premium System
Hello all, I've only had my 4RTE for a couple of months. Because I'm big on music, I always am looking to get the best signal to my car since I drive a lot. I know that Android phones do not support USB audio out, but I have an old iPhone that I can stream music from. However, when I plug it into the USB port, it recognizes a device and charges it, but when I start Pandora, nothing plays. Am I doing something wrong? I'm not a fan of Apple, but since I have a spare phone anyhow, I figured I'd give it a shot, plus it would free up my phone for other stuff. Any experts out there? Thank you!
2016 4Runner Trail Edition | SET XP Package | 2"/1" Cornfed Leveling Kit | 1.25" Spidertrax Wheel Spacers | All 6K VLED Interior Lighting | Opt7 LED Low/High Beams and Reverse Lights | CompuStar Remote Start and Security System | Opt7 C2 Series 32" CREE LED Light Bar behind Front Grill | Focal 1651ASG Front Speakers powered by Alpine KTP-445U | 12" JL-W1 powered by Alpine MRV-M500
walstylez is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 11:08 AM #2
Storm Runner's Avatar
Storm Runner Storm Runner is offline
Storm Runner is on a distinguished road
I believe you have to connect your phone with bluetooth and also sign in to Pandora through the entune app for it to work. Then you can start the Pandora app on the radio and it will play using your phones connection. At least, that's what I did on mine to get it to work. Pretty sure to play music from your phone through the USB port you'll need to have music downloaded to your phone and use it like a MP3 player.
2016 TEP Super White | ToyTec Ultimate 3" lift | 17x8 -10 Level 8 MK 6 wheels | 255/80/17 Cooper ST Maxx tires
Storm Runner is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 12:23 PM #3
walstylez's Avatar
walstylez's Avatar
Yeah, I can stream music from my Android phone through bluetooth, but I'd prefer the USB audio out since the signal is better. I find it odd that music has to be downloaded to the device in order to use USB audio out...seems like whether or not it's downloaded onto the device or streaming, it shouldn't really matter, right?
Old 01-03-2017, 01:35 PM #4
You could probably get an AUX cord and plug it in to the phone headphone jack and change the source to AUX on the radio.
Old 01-03-2017, 01:42 PM #5
TRUSTYAXE's Avatar
TRUSTYAXE TRUSTYAXE is offline
TRUSTYAXE will become famous soon enough TRUSTYAXE will become famous soon enough
TRUSTYAXE's Avatar
I'm not the expert but IMHU loose the phone and use a thumb drive or hard drive for usb music.
How to use a usb hard drive for music
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
TRUSTYAXE is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 01:48 PM #6
walstylez's Avatar
walstylez's Avatar
Yeah, I have music on a thumb drive now, it sounds great, I just don't download music and I like to hear more current stuff that's on my Pandora station. Also, I just tried the phone again, and the message I actually get is something more like "You have no compatible files on your iPhone that can be played"...so maybe it does have to do with me trying to use Pandora over music that I already own that's downloaded.
Old 01-03-2017, 01:49 PM #7
walstylez's Avatar
walstylez's Avatar
Yes, you can, the AUX cord does work...but from what I read, the USB audio out from a phone has better signal (keeps the signal digital) than an AUX cord. I like to really "hear" my music, I guess.
Old 01-03-2017, 02:00 PM #8
e60ral e60ral is offline
Banned
e60ral will become famous soon enough
Banned
its not playing through usb, its accessing the files and playing them directly. you would avoid ant BT compression this way but aux in will as well. Using either aux in or USB your audio files bitrate will be the limiting factor for your audio quality.
e60ral is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 03:41 PM #9
walstylez's Avatar
walstylez's Avatar
So the bitrate is what matters if you're talking the difference btw AUX and USB? The two inputs won't make a difference quality wise?
Old 01-03-2017, 04:00 PM #10
Banned
Banned
in practical purposes for the bitrates for most media on your phone, yes they will be the same. technically using USB for media stored on your phone shouldhave a slight advantage because the headunit is processing it directly
for something like Pandora (which is 192 kbps on high quality, 128 on regular) you probably won't even notice a difference if you just use BT, so if you want to listen to Pandora I would just use the factory app (which BT streams from the phone, just with a pretty UI)
Old 01-03-2017, 04:19 PM #11
walstylez's Avatar
walstylez's Avatar
Ok, well I know for a fact the songs on my thumb drive come through a lot clearer than when I stream the Pandora app through my Entune system...
Old 01-03-2017, 04:35 PM #12
Banned
Banned
your downloaded file on the thumb drive is probably at least 256 kbps, its supposed to sound better than Pandora but BT streaming isn't the reason why for that case.
Here is the simple answer: If you want Pandora Aux input is your best option (this makes assumptions about the DAC on your phone and the amp on the stereo that i don't have an exact answer for), BT should be pretty close perhaps close enough that you won't notice a difference for Pandora quality.
If you want high quality music you'll need to do something other than Pandora
Old 10-19-2021, 04:05 AM #13
SporCj SporCj is offline
SporCj is on a distinguished road
I also used to have this problem a few months ago. It was too hard to use a USB all the time, though. I'm currently using an app to transfer all the music and photos from my laptop to my phone. Afterward, I used Bluetooth to connect my phone to my car. It's much easier this way since it's completely wireless, which I love. If you were wondering what app I'm using, well, it's called Gemini Photos. You can find the downloading link on How to transfer photos from your PC to your iPhone. I can assure you that it's a total life changer and I highly recommend it.
SporCj is offline   Reply With QuoteReply With Quote
FS - 2016 Premium Entune radio with TRD-P faceplate Ricomondo For Sale: T4R Items 3 01-21-2017 06:19 PM
Missing weather, traffic, low fuel warning in Entune Premium Audio. rblt New Members 2 08-09-2016 05:55 PM
Messing with the '14 EnTune audio system, new splash screen, etc. VolksDragon 5th gen T4Rs 66 03-29-2016 09:27 PM
Trail premium entune system? sf jakey 5th gen T4Rs 27 11-21-2015 12:39 PM
a newbie audio system & iphone question Giannacl Engines / Suspension / Wheels / Tires / Audio / Accessories 8 10-21-2013 08:33 AM
