Crikeymike
Thread Tools Rating: Thread Rating: 56 votes, 3.32 average. Display Modes
Old 10-15-2019, 04:47 PM #1711
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Originally Posted by 16RedRunner View Post
Even with the C59-314 you are running your 5100's at second notch?How is the ride the truck looks great!
I felt like 2.5" of lift up front wasn't enough with 2" in the rear - I think it was the right call to go up a notch and get the full 3" up front. Ride is great. Maybe a bit firmer than the stock coils.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 04:57 PM #1712
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Keep in mind, he has a slimline bumper and winch up front, adding some weight.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 03:49 AM #1713
The_Runner The_Runner is offline
The_Runner is on a distinguished road
Originally Posted by Cymon View Post
4 coils x $175 (pair) = $350
2LT front Struts x $145 = $290
2LT rear shocks x $115 = $230
Differential drop = $40
Total Cost 3" LT setup $910 unless you add the adjustable pan hard rod.
All non-LT kits are $790.
I don't believe they sell UCA's so pick your own flavor.
The price on these are very competitive and the reviews I've read so far are almost all positive.
The 4Runner only has two coils you have to pay for. What’s the adjustable pan hard rod though?
The_Runner is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 11:23 AM #1714
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
You need 4 coils (as they are listed b/c that’s what they call springs in Australia). Two to go over the front struts to make the front “coil over” and two to pair with the rear shocks (replace your OEM Springs). An adjustable pan hard rod helps keep the rear axle centered. As you lift your 4runner the geometry changes and can push your rear axle out of alignment (with the OEM fixed length panhard rod. Under 2.5 inches of rear lift you may not notice a difference or need it but over that height it will help lining everything back up.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 10-20-2019, 12:29 PM #1715
dcestnik dcestnik is offline
dcestnik is on a distinguished road
Some notes from mine that might help folks deciding whats needed/not needed on different set ups.
Went 302/505 springs with 700/701 shocks and UCAs. Stock wheels and falken 265/70r17 didnt need spacers with plenty of clearance with UCAs and no rubbing anywhere. Have the diff drop but probably wont install unless CVs start going. Only weight added is RSG sliders. Alignment was dead on and no issues. For install the passenger UCA didnt have enough space between the bushings to fit so had to grind a few millimeters, not sure if that will cause issues later. Also nut to attach abs sensor wire was missing. Other than those two issues everything was pretty easy.
Final result is 4Runner that no longer has the nose dive and sloppy sway but still very comfortable to drive. Noticeably softer than my OME'd tacoma. Drove very well on some bad roads this weekend and should be a nice set up for daily driver during the week and mild off roading on the weekends.
Dobinsons 5th Gen T4R Suspension options - from Exit Offroad-img_20191017_175833039_hdr-jpg  Dobinsons 5th Gen T4R Suspension options - from Exit Offroad-img_20191017_175853031_hdr-jpg
dcestnik is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 06:56 PM #1716
T4R1976 T4R1976 is offline
T4R1976 is on a distinguished road
Went 302/505 springs with 700/701 shocks.
I’m going with the same set up; order delayed because of choosing red coils. Same tires too.
How’s the rake? I’m on the fence about changing the rear coils to the 325s (2 - 2.25”). Just in case I add a heavier fuel tank skid. Would that look odd with 265 tires?
Thanks!
T4R1976 is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 10:32 AM #1717
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
CURRENT SETUP:
c59-302 Front
c59-723 Rear
Decided I'm really not into the rake for several reasons. Least important but, most annoying to me is the way it looks. So, I'm going to accelerate the changes to the front end, and hold off on other armor.
Not really sure which one (everything is a compromise one way or another) but I'm going to put a steel bumper and a winch. Likely C4's hybrid.
@DobinsonsUSA
I rather like the height in the rear and I would like to level the front to match the rear (also compensate for KDSS lean i still have up front).
C59-726 paired with a LT strut like the 5100? Could I keep the front springs (assuming I don't add the steel and winch) on my current setup swap out the struts for 5100's and bring it up a notch or two? What are my options here?
Thanks
Mutant138 is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 10:36 AM #1718
JP421's Avatar
JP421 JP421 is offline
JP421 is a jewel in the rough JP421 is a jewel in the rough JP421 is a jewel in the rough JP421 is a jewel in the rough
JP421's Avatar
Originally Posted by Mutant138 View Post
CURRENT SETUP:
c59-302 Front
c59-723 Rear
@DobinsonsUSA
C59-726 paired with a LT strut like the 5100? Unsure of how to level it out.
Thanks
Just put on a full steel rear bumper with all the addons. That'll level it out.
2019 TRD Off-Road Premium
285 Cooper STT Pros - Tandem Offroad 612 Charlie in bronze
Dobinsons - Front: C59-300, GS59-574 Rear: C59-505, GS59-701 - JBA UCAs
RSG Metalworks Sliders - Angled - RCI Skids
JP421 is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 10:44 AM #1719
Banned
Banned
It's a thought. Could just sag the rear really bad causing me to swap the rear springs and then go back full circle to the same dilemma.
Also I'm going to go custom tube in the rear most likely. I'm not ready to be without my truck ATM.
Old 10-24-2019, 10:44 AM #1720
16RedRunner's Avatar
16RedRunner 16RedRunner is offline
Real Name: Mark
16RedRunner has a spectacular aura about 16RedRunner has a spectacular aura about
Real Name: Mark
Here's a question I have 5100's already.If I went with same setup he has but left the 5100 at 1st notch would I achieve the same look as his? I want a level look with as little rake as possible.
16RedRunner is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 10:53 AM #1721
Crikeymike's Avatar
Crikeymike's Avatar
CURRENT SETUP:
c59-302 Front
c59-723 Rear
@DobinsonsUSA
Thanks
You probably need to add about 1" of lift to the front to make it more level, so however many clip heights that is, about 1/2" above where the coil seat is now will make it about 1" taller in the front. You could do that with your current coils without extra front weight.
Then if/when you do add more weight, yeah, use the 726 coils up front.
Old 10-26-2019, 09:37 AM #1722
Marine0369 Marine0369 is offline
Marine0369 is on a distinguished road
The left side is lower? That's unusual on a vehicle with KDSS
I'll measure today and see how much.
2015 Trail Edition with KDSS. CoverKing Ballistic Seat covers, Husky Floor Liners. Dobinson's 2.5" lift. SPC UCA's. Pelfreybilt front bumper with Baja Designs 30" bar and BD Pro fogs. Toyo AT3 255-70LT17.
Marine0369 is offline   Reply With QuoteReply With Quote
Old 10-26-2019, 11:05 AM #1723
Ehahn84's Avatar
Ehahn84 Ehahn84 is offline
Ehahn84 is on a distinguished road
Ehahn84's Avatar
@DobinsonsUSA
When are you guys gonna have a kit in stock for a KDSS rig? I’m looking for a minimal lift, just want upgraded parts...but everything says sold out.
2017 TRD Off-Road Premium. Magnetic Grey. Dual Odyssey battery setup. Falken Wildpeak AT3W. Diode Dynamics SS3. Rigid Dually Spotties.
Ehahn84 is offline   Reply With QuoteReply With Quote
Old 10-26-2019, 02:10 PM #1724
PAKM4N PAKM4N is offline
Real Name: Pak
PAKM4N is on a distinguished road
Real Name: Pak
Hello! I’m running the c59-729 on my 2015 4runner with king shocks, c4 rear bumper and it’s pretty stiff. You think I should get the 727?
2015 Toyota 4Runner Trail Edition/KDSS, SCS Stealth BR6, C4 rear bumper ,Relentless front bumper ,RCI under armor, 4.88 gears, dual battery, iKamper rtt
PAKM4N is offline   Reply With QuoteReply With Quote
Old 10-26-2019, 03:03 PM #1725
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
You're running the 729 with only a rear bumper?!?! Why such a stiff spring with so little weight?
That seems completely wrong for the application
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Build assistance - Feedback on suspension choices for my usage. Keith_PDX 5th gen T4Rs 31 05-04-2015 03:13 PM
Suspension Choices MadeInMaine 5th gen T4Rs 8 07-22-2013 08:44 PM
lift spring choices/ tire choices ohnoitsthecops 4th Gen T4Rs 19 02-02-2012 11:32 AM
Battery choices/options for reliability and safety? Clifford 3rd gen T4Rs 26 12-10-2011 03:15 AM
1989 4Runner SR5 **Lots of Options** $4000.00/obo - Orlando, FL vjr021 Classifieds - buy & sell (no commercial ads please) 0 10-13-2008 08:22 AM
