Crikeymike
Thread Tools Rating: Thread Rating: 56 votes, 3.32 average. Display Modes
Old 11-17-2019, 02:12 PM #1771
dv061j dv061j is offline
dv061j is on a distinguished road
Just a quick question, my 4runner has KDSS but I went ahead and got the non KDSS rear coil due to Dobinsons availability and my available installation time. I got the spacer pack to help offset the KDSS lean, the spacer goes on the rear Passenger side is that correct?
dv061j is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 10:06 PM #1772
Rightside Up's Avatar
Rightside Up Rightside Up is offline
Rightside Up will become famous soon enough Rightside Up will become famous soon enough
Still loving my @Dobinsons suspension.
Dobinsons 5th Gen T4R Suspension options - from Exit Offroad-73556edc-1b8c-49ae-ab5f-fea71d85b8bf-jpg
2018 ORP Barcelona Red
Dobinsons 2.5”/1.5” lift with springs and shocks.
Diff. Drop.
Pro Comp UCAs.
RSG angled sliders.
Rightside Up is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 03:02 PM #1773
2barevo 2barevo is offline
Real Name: Chris
2barevo is on a distinguished road
Real Name: Chris
Originally Posted by jhguth View Post
Any info on the MRA's? heard they had them at SEMA
@Crikeymike Hi Mike, any more info on this new setup?
2barevo is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 05:27 PM #1774
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Still waiting for all the stock to arrive so that we will be able to sell it for all the major models. But here's the lowdown.
10 stage high speed compression adjustment
20 stage slow speed compression adjustment
15 stage rebound adjustment
On the struts, rebound adjustment is from the top stud, quite simple to get to above the strut tower.
On the shocks, rebound adjustment is in the lower mount.
High and slow speed adjustment is both handled at the reservoir front and rear.
All in all, they look a lot like the standard MRR shocks we have had for some time, but they include full swivel fittings on the reservoir hose, both ends, to avoid it becoming loose and ease of installation and orientation. But with all the adjustment, you could literally tighten them up so much to essentially stop all movement or soften then up to suit it however you like. The range of adjustment is massive which is excellent for those going from no load to heavy loads, or those that want it softer on the highway than while offroad.
4runners will still not use a piggy back mount for the reservoir.
Dobinsons 5th Gen T4R Suspension options - from Exit Offroad-20190621_183113-jpg
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 01:33 PM #1775
a_hartman a_hartman is offline
a_hartman is on a distinguished road
Is there a diagram that has any more detail? I bought a set of KYB top hats to assemble my coilovers and I cannot get enough threads to show to be able to get the nut on - obviously I'm screwin the pooch somewhere!
Alex
a_hartman is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 02:32 PM #1776
Real Name: Chris
Real Name: Chris
Thank you! when you said "4runners will still not use a piggy back mount for the reservoir," did you mean it will be mounted on the chassis vs the strut?
I have KDSS with full metal front bumper and would like to go with the 3" lift. Would you suggest 3" front-heavy duty and 2" rear-heavy duty? I would like to keep it level as much as possible but want to prevent reverse rake when all loaded up in the rear for our trips.
Old 11-19-2019, 04:58 PM #1777
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Will these require periodic rebuilding? If so at what interval?
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 06:56 PM #1778
philmeok's Avatar
philmeok philmeok is offline
philmeok is an unknown quantity at this point
philmeok's Avatar
Usually it does, but not all vehicles lean, and the ones that do don't always lean the same. Plus, you have KDSS which can cause a lean itself if it wasn't managed properly during the installation of the suspension.
Can you elaborate on this a little? I was told if doing a self install for the rear, its suggested to keep a jack under the rear KDSS piston. Do you have anything to add to this? I haven't found much on the site and I'm just trying to get a better understand. Thank you
philmeok is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 07:49 PM #1779
Crikeymike's Avatar
Crikeymike's Avatar
Alex
You can't assemble them without a strut coil compressor. the coils are too long to use the "do it without the compressor tool" installation.
From the bare stud, upwards
Washer
Bushing
Locating washer
Strut plate
Top bushing
Top washer
Top nut
Edit, scroll down on this page to download the sequence diagram
Instructions – Dobinsons Direct
Old 11-19-2019, 07:51 PM #1780
Crikeymike's Avatar
Crikeymike's Avatar
No, not at all. They're built with components to last as long as possible. there are heaps of guys running MRR's for years without a rebuild.
Old 11-19-2019, 07:53 PM #1781
Crikeymike's Avatar
Crikeymike's Avatar
Correct. Reservoirs mount to the frame. Some vehicles have room for a piggyback reservoir. meaning mounted to the shock itself (Jeeps, etc) but they won't fit on 4runners.
Yes, 3" front and 2" rear is what I run on mine with KDSS and just choose the appropriate springs to match the weight you have.
Old 11-19-2019, 07:54 PM #1782
Crikeymike's Avatar
Crikeymike's Avatar
In this thread I have my own version of kdss instructions listed. You would just need to search back and see. There's also plenty of other threads on the forum that break it down.
Old 11-19-2019, 11:15 PM #1783
Washer
Bushing
Locating washer
Strut plate
Top bushing
Top washer
Top nut
Mike
Thank you for the reply! IÂ’m using a compressor. My issue seems to be with the KYB bushing being glued in.
Old 11-20-2019, 12:05 AM #1784
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
Mike
When I just redid my front's a few weeks ago w/ KYB strut mounts I noticed the same thing, just place the washer below it, then the bushing/mount over it
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
Old 11-20-2019, 01:38 AM #1785
Sweet! So you’re saying washer>top mount>bushing>washer>nut.
Does that sound right?
Build assistance - Feedback on suspension choices for my usage. Keith_PDX 5th gen T4Rs 31 05-04-2015 03:13 PM
Suspension Choices MadeInMaine 5th gen T4Rs 8 07-22-2013 08:44 PM
lift spring choices/ tire choices ohnoitsthecops 4th Gen T4Rs 19 02-02-2012 11:32 AM
Battery choices/options for reliability and safety? Clifford 3rd gen T4Rs 26 12-10-2011 03:15 AM
1989 4Runner SR5 **Lots of Options** $4000.00/obo - Orlando, FL vjr021 Classifieds - buy & sell (no commercial ads please) 0 10-13-2008 08:22 AM
