01-17-2021, 01:23 PM
#2761
Originally Posted by NB17Limited
@ My 2017 Limited Xreas started leaking after our cross country trip so I guess it's time to replace it. I was trying to figure out what setup I should get for my rig and got a little lost. I have an SSO slimline front bumper and winch, hopefully RCI sliders soon, and will eventually be custom fabricating a rear "hybrid" bumper with no swingouts or anything. Hoping to keep it under 100 pounds. We do take it on road trips often and have the back loaded with a couple hundred pounds of stuff and an additional hitch carrier with another 200-300 pounds of stuff. Daily driving it though, it has a stroller and a diaper bag in the back. Don't want to lift past 2.5" but would prefer sitting around 1.5-2". What would you recommend?
Geez, that's probably the newest Xreas setup I've heard about leaking. Is Toyota not going to cover to fix it?
Is the suspension still all stock currently?
C59-302 front coils for ~2" with the weight and C59-325 in the back for 1.5-1.75" with rear constant weight installed. Then the 700 front struts and 701 rear shocks, your choice of the 3 different shock types.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
01-17-2021, 07:25 PM
#2762
We've got 67k miles on them. All stock suspension for now. I have a feeling we exceeded the payload capacity on our last trip which may have lead to premature failure. Hitch carrier had closer to 500 pounds, the back was completely stuffed, we had the roof full, and around 500 pounds of people and dogs. I didn't inquire with Toyota because I really don't want it replaced with the same thing if I have the opportunity to upgrade.
Thanks for the info! Order will be placed within the week
01-17-2021, 07:46 PM
#2763
Originally Posted by honda250xtitan
any idea on ship date for the rear 327's? website says available on backorder
Wheelers has the T13 at 196lb. Though I am not sure how that is 12% over stock when stock should be 180sh.
Wheeler's T13 Rear Coil Spring Pair for 10+ 4Runner
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
01-22-2021, 11:40 AM
#2764
Mike, what's the best setup for a TRD OR with no aftermarket front bumper and no load in the back? I'm trying to achieve a 2.5" lift in the front and 1" in the rear. Also when will the UCAs be back in stock?
01-22-2021, 11:47 AM
#2765
Hey man, that's pretty straight forward. 302/599 coils with 700/705 shocks.
Dobinsons 1" to 3.5" Build-A-Kit Toyota 4Runner 2010-21 | Exit Offroad
No date yet on the UCA's. March perhaps but probably April. They're still not made and on the way yet, so we don't have a date.
01-22-2021, 12:08 PM
#2766
In terms of the UCAs, are they maintenance free like the stock UCAs?
01-22-2021, 01:12 PM
#2767
Yes. I have a full detail video of them on my YouTube channel, link in signature.
01-22-2021, 05:51 PM
#2768
Do you have a higher rate spring option for 2021 Pro with winch and bumper? Or should one just use the 1” taller spring listed to help compensate for the compression from additional weight?
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
01-22-2021, 06:47 PM
#2769
The only coil made for those lifts 1" over stock, with no additional weight. It would help offset added weight if your front end squatted when it was added.
02-03-2021, 11:30 AM
#2770
Received a container today and have a limited quantity available of C59-325 in black or red only. Get them while you can!!
Looks like we'll finally be able to fulfill all the backorders waiting on those. A bunch of other parts came in too, but since these coils have been out for 3+ months, wanted to share that info.
Dobinsons C59-325 Rear Coil Springs for Toyota 4Runner and FJ Cruiser
02-04-2021, 06:58 PM
#2771
Not much to add, but I thought I'd post up in this topic since I read the whole thing front to back while I was looking into suspension options! I went with a Dobinsons complete twin tube setup on my 2017 SR5. 1.75-2" lift in front and 1" in the rear. Initially, the rear looked really high (I initially had 2" of lift in the back by my measurements) but the rear has settled perfectly after a few thousand miles.
I'm very very happy with the suspension. It rides SO much better than stock around town and it performs well on rough forest roads. I would post up some glamor shots of the rig but this forum's photo upload system is horrendous! Thanks to Mike for all the great info and solid customer service. I would buy Dobinsons again and again!
02-04-2021, 07:53 PM
#2772
Thanks for the summary and product review bud!!
Yeah, you're not wrong, this site is living in 1998 when it comes to forum software. Hahaha
Also to anyone else that would like to leave a review, you can do that for me here on Google to help others: Google Review - Exit Offroad
02-08-2021, 03:46 PM
#2773
@ Crikeymike
Are UCA’s in stock? If not, ETA?
Michael
02-08-2021, 04:11 PM
#2774
No, been sold out since November.
Some time between now and Christmas, they should be in. We don't have a firm ETA at this time. 2-3 months minimum I'd say
02-08-2021, 04:52 PM
#2775
Were there any 302s and 325s in teal in that shipment? Anxiously awaiting replacing Xreas with Dobinsons
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
