09-08-2022, 12:06 PM
#3151
Originally Posted by bhubs1308
Hey guys. New to the thread and looking for advise. 210 pages of post is a lot to look at so sorry if someone else has already asked this I have a 2022 TRD OFF Road. I have ordered a pretty aggressive set of wheels and want to get the maximum lift capabilities. I will be running 17x9 -38 Black Rhino wheels and 285/70/17 Nitto Ridge Grapplers. After days of back and fourth on lifts, I think Dobinson is the best way to go without having to spend $4k on a King Setup I am looking at the 3.5'' Kit. My question is, If I go with a spring that is made for heavier weight, my brain says logically I'll get slightly more lift if I dont actually have the extra weight. Is this correct? I completely understand that the ride quality will stiffen up and I'm ok with that ( I have driven trucks and jeeps my entire life so I like the heavier feel) But I want to make sure that I would not be doing any damage by having the HD coils without the extra weight. Any advise is greatly appreciated.
Hey bud, welcome to the forum!
Yeah, just like how a coil spring is taller out of the vehicle than when it's installed (unloaded), it will sit taller. Running heavy load springs without a heavy load isn't recommended. The lift height can easily be 1" taller or more without the added weight, and that can put strain on some joints and other parts. It's best to add the coils to suit the weight, or add the extra parts at the same time so that it all works together.
In some cases, some rear coils can't even go in properly without the extra weight and the load on them to sit down properly.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
09-08-2022, 03:04 PM
#3152
Thanks man really appreciate the Insight. Makes total sense. That’s what I was concerned about was damaging other parts by not having the extra weight.
09-10-2022, 05:21 PM
#3153
C59-354
09-12-2022, 09:02 PM
#3154
Hi Mike, it's me again.
I've decided I would like to go the long travel route for my rear. With weld on tire carrier 40lbs, tire and wheel 95lbs, & DIY wood storage box w gear 75lbs. Looking like 210lbs static (went generous with the numbers to be sure). The box is removable but I prefer to have it in there all the time due to "what-ifs."
Is that too much weight for 675v? I don't want to be over lifted in the rear with 677v. I initially was going with 327s before the LT peaked my interest.
352 / 700 IMS up front
675v / 575 IMS in rear with the other supporting mods to make LT work correctly.
| IG: daks.4rnr | 2018 TRD Off Road Premium | Dobinsons 302/505 700/705 | Dobinsons UCA | Shrockworks Angled Sliders | RCI Skids | C4 LoPro | Prinsu 3/4 |
09-13-2022, 09:39 AM
#3155
Hi, again! hahah
Yeah, you can run the 675V's with that weight and would probably be around the 2.5" height mark. It's not too much weight and generally the 677V would be more ideal, but not if you don't want that extra lift height.
09-15-2022, 03:27 PM
#3156
Hi, again! hahah
You sold me on the 677V lol. Thanks man
09-15-2022, 04:14 PM
#3157
Crikeymike won’t steer you wrong
09-17-2022, 09:14 PM
#3158
Truth.
Speaking of, does anyone here have a basic rundown of the how they adjust their MRRs for different situations or if you have a "do all" adjustment (like the number of clicks)? These are my first set with adjustment so just wanted to know if anyone could help me get started and then I can make adjustments as I learn. Thanks
Current: 2018 SR5P XP; Dobinsons c59-314/MRA59-A574(F) c59-505/MRA59-A701(R); Dobinsons PS59-4030 (driver); Dobinsons UCAs, rear sway bar links, and diff drop; Nitto Trail Grap 285/70R17; Bash Fabrication Sliders; Bash Fabrication lo-pro front bumper; Badland Apex 12k winch; Baja Designs Squadron fog lights and 20" S8; Diode Dynamics LED reverse lights; Victory 4x4 crossbars; BPFabricating molle pet barrier; Victory 4x4 front/mid/tcase skids; EVC throttle controller; front sway bar delete; ARB Diff Breather kit; Spidertrax; Total Chaos weld on spindle gussets, BMC with pinch weld mod
09-21-2022, 08:51 PM
#3159
Stupid question time: what’s the significance of the coil seat orientation (I think correct way is both sides with seat notch facing rear)?
I had a shop swap coils on my MRAs, and didn’t notice until reinstalling the passenger side that both struts were put back together with the same orientation. So if I install them as-is, driver would be facing rear and passenger facing front.
I’d rather not go back to that shop to redo it if I can help it.
09-22-2022, 10:44 AM
#3160
It was originally for sway bar clearance, as some vehicles have a sway bar that gets right up close to the strut, and it could contact it if there's not enough clearance. But in all the years I've been selling Dobinsons stuff, it hasn't made a difference that I've noticed if the notch faces forward or rearward. They just need to be that way to keep the coil straight. If the notch faces inwards or outwards, it can bow the coil, allowing the strut body and coil to contact.
It's not worth correcting it if they're facing opposite directions.
09-24-2022, 09:53 PM
#3161
Dobinson lift driveline hitting tank skid
Hello I was seeing if anyone with the Dobinson LT kit has any problems with the driveline hitting there gas tank skid
09-26-2022, 09:34 AM
#3162
I've not seen that before, but it looks like that cross member for your gas tank skid will need to be modified (aka cut down) to gain more driveshaft clearance.
Otherwise I've never seen the driveshaft contact anything with the LT setup.
09-26-2022, 10:35 AM
#3163
I just read there could be some issue, with installing the added weight capable lift prior to adding the weight. Waiting for a custom bumper/winch 220+lbs to be delivered, but went forward with my lift install this weekend - C59-352's and GS59-574's. Also did the diff lift and the swaybar relocate. Any concerns other than a stiff ride?
Also did the rear with a standard weight 2.5", not sure about the Panhard Rod adjustment, but all went together well.
2016 TE - Silver
RRW R2 17x8.5, Yoko Geolander M/T 295/70R17, Prinsu Full Rack, Shrockworks Rock Sliders, Dobinson Snorkel and Lift 3.5"/2.5" and UCA's, C4 Hybrid Front Bumper with BajaDesigns Light bar and Squadrons
09-26-2022, 10:43 AM
#3164
The front would be pretty darn tall then without the added weight. What's the new hub to fender measurements now? Probably 24-24.5" up front if I had to guess.
09-26-2022, 12:50 PM
#3165
23.5". It was 23" before the lift when I had a spacer lift, but it sure feels like a bigger difference.
2016 TE - Silver
