Crikeymike
Thread Tools Rating: Thread Rating: 56 votes, 3.32 average. Display Modes
Old 02-23-2017, 06:16 PM #61
Why do you guys do installs via removing the 2 bolts on the LCA instead of the 1 on the UCA/spindle? is it to save the cv's from being drooped out too far? I've done TONS of setups on my titan (also IFS, also with gayyyy cv's) and the only time i've ever removed the bolt on the ball joint for the LCA is when i upgraded LCA's to Dirt King.
Originally Posted by srsrogerissrs View Post
Recently installed my Dobinson setup
C59-300 springs up front w/ GS59-574 Struts for a total lift of 2.75"
(Stock weight springs with their long travel front struts)
C59-325 springs in the rear w/ GS59-701 shocks for a total lift of 2"
(Stock weight rear springs w/ standard shocks)
Also installed the diff drop kit as well.
-Also installed my Light Racing UCAs and Spacers when I did the suspension.
So far, I've put about 300 miles on the suspension setup and pretty happy with it so far. The installation was pretty smooth and straightforward, no issues there. The nose dive is essentially non-existent. The setup is a bit more firm than stock but I prefer it as it doesn't seem to be as "floaty" as it was before. It's definitely not "harsh" by any means. If I was to describe the setup, it's firm but absorbs a lot of bumps and road imperfections. Definitely pleased with my setup so far and can't wait to take it off-road to see how it does. Mike has been extremely helpful throughout the process and communication with him has been great. Definitely would recommend for anyone who is interested.
Looks perfect. Hoping to set up the wifey's trail like that
Old 02-23-2017, 06:42 PM #62
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
That's what a few people had suggested to me, and when I read up on it, it seemed super easy to me. The cv's stay where they are and the UCA joint on the Total Chaos arms is really big too. With the LCA being able to swing down further, we don't even need a pry bar to get the king strut assembly in or out.
Brake lines don't get touched either and they all stay in place.
There's definitely a few ways to do this install. I'm down for the easiest way!!
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 02-23-2017, 09:56 PM #63
Angelo's Avatar
Angelo Angelo is offline
Angelo will become famous soon enough
Angelo's Avatar
@Dobinsons Mike thanks for the detailed answer and pictures!
Eibach - Dobinsons - Falken - Rigid
Consolidated Lighting Info Thread
Angelo is offline   Reply With QuoteReply With Quote
Old 02-24-2017, 05:14 PM #64
Crikeymike's Avatar
Crikeymike's Avatar
New wheels and tires are now on my KDSS Trail
Wheels are 18 x 9" Fuel Beast
Tires are 285/65R18 Nitto Ridge Grappler
Dobinsons 5th Gen T4R Suspension options - from Exit Offroad-whatsapp-image-2017-02-23-5-48-51-pm-jpg
Old 02-27-2017, 03:51 PM #65
Crikeymike's Avatar
Crikeymike's Avatar
KDSS coil options
Just added the front and rear KDSS coil options into the first post. Here it is again though for anyone interested.
Front Coil Options, with KDSS.
Our front KDSS coils are 5mm on one side to be installed onto the US passenger side (right side) to compensate for KDSS lean. This removes the need for any trim spacer, such as the OME95PF5, which can't be used on our struts anyway.
C59-722 - Stock front end, low height lift, 1.25" lift
C59-724 - Stock front end load, 1.75" lift
C59-726 - 100-220LBS heavy load front weight, 2" lift
C59-448 - Stock front end, comfort option, 3" lift (should be run with long travel struts like 5100's)
Rear Coil Options, with KDSS.
Our KDSS coils are 15mm taller on one side to go onto the US passenger side (right side) to compensate for vehicle lean
C59-723 - Stock rear end, 1.25" lift, offset height coils for KDSS leveling
C59-725 - Stock rear end, 1.75" lift with 3rd row, 2" without, offset height coils for KDSS leveling (similar to C59-325)
C59-727 - 200-400LB heavy rear load weight, 2" lift, offset height coils (similar to C59-327)
C59-729 - 600-800LB super ridiculous heavy rear load weight, 2" lift, offset height coils (similar to C59-329)
Old 03-01-2017, 06:58 PM #66
Crikeymike's Avatar
Crikeymike's Avatar
Hey man, someone else today reminded me of this video (very helpful). You can see how they swing the lower control arm out and don't have to mess with the any of the other joints or brake lines (except removing steering and sway bar out of the way on a 4runner).
https://www.youtube.com/watch?vl=en&...Hg&app=desktop
Old 03-01-2017, 07:52 PM #67
sweet thanks man! that makes sense.
Old 03-06-2017, 07:01 PM #68
Yoderguy's Avatar
Yoderguy Yoderguy is offline
Yoderguy is on a distinguished road
Yoderguy's Avatar
Are you doing any discounts for forum members?
Yoderguy is offline   Reply With QuoteReply With Quote
Old 03-06-2017, 07:06 PM #69
Crikeymike's Avatar
Crikeymike's Avatar
Yes, free admission to all members, and Thursday night is ladies night, free drinks until 9pm.
Just kidding....
I can probably arrange a "tax refund season" special discount, but it would be discussed over PM.
Old 03-06-2017, 07:16 PM #70
Yoderguy's Avatar
Yoderguy's Avatar
Haha I'll wear a dress and see you at 9! And I'll pm ya. Not necessarily in that order...
Old 03-06-2017, 08:34 PM #71
_#1_'s Avatar
_#1_ _#1_ is offline
_#1_ is on a distinguished road
_#1_'s Avatar
I don't mind a little Skittles once in a while, but those colors are throwing me off!
Is there any chance to choose coil color? Like as in... black? Or grey/silver?
Would have been nice if there were a group buy....
2010 Trail - First mod-Right fender dent, Dobinson 3" F+R lift, Diff drop, American Racing Wheels 17x8-0 offset, Generic 1.25 Wheel Spacers, Nitto Ridge Grapplers 285/70/17, Fender liner mod, BMC. To Be Continue...
_#1_ is offline   Reply With QuoteReply With Quote
Old 03-06-2017, 09:36 PM #72
Vinsil's Avatar
Vinsil Vinsil is offline
Vinsil is on a distinguished road
Vinsil's Avatar
Just kidding....
Your killing me Mike! Well.....my wallet that is.PM sent.
'16 TEP. Ecotechne roof rack, BFG 285’s on Method BL's, Dobinsons 3”/2" lift, MT sliders, slimline front bumper Smittybilt winch, Expedition One rear bumper, Indel-B 50 fridge, lots more.
M416 Offroad trailer build in progress, RTT, Compact camping Concepts rack system, 275 BFG’s on FJ steelies, more coming...
Vinsil is offline   Reply With QuoteReply With Quote
Old 03-06-2017, 10:22 PM #73
RIjon RIjon is offline
Banned
RIjon is on a distinguished road
Banned
Ugh..
RIjon is offline   Reply With QuoteReply With Quote
Old 03-06-2017, 10:33 PM #74
Yoderguy's Avatar
Yoderguy's Avatar
Anyone (Mike?) know what the comfort option is referring to on the 3" lift front springs?
Old 03-06-2017, 10:34 PM #75
Yoderguy's Avatar
Yoderguy's Avatar
And why is the 3'' suggested over the 2.5" standard load front springs?
Build assistance - Feedback on suspension choices for my usage. Keith_PDX 5th gen T4Rs 31 05-04-2015 03:13 PM
Suspension Choices MadeInMaine 5th gen T4Rs 8 07-22-2013 08:44 PM
lift spring choices/ tire choices ohnoitsthecops 4th Gen T4Rs 19 02-02-2012 11:32 AM
Battery choices/options for reliability and safety? Clifford 3rd gen T4Rs 26 12-10-2011 03:15 AM
1989 4Runner SR5 **Lots of Options** $4000.00/obo - Orlando, FL vjr021 Classifieds - buy & sell (no commercial ads please) 0 10-13-2008 08:22 AM
