08-02-2018, 08:34 AM
#1051
Thanks, Mike! Appreciate the info.
08-02-2018, 08:50 AM
#1052
Real Name: Nathan
Real Name: Nathan
Originally Posted by Dobinsons Mike
I've been blasted with a lot of questions recently about our suspension offerings for the 5th Gen 4Runners, so I figured it's time to make a specific post about all that we offer. We can lift anywhere from 1.0" to 3.0" with coils and struts/shocks, and we can put together a specific package for whatever you want/need, including the added weight you've added to your vehicle.
Can you get the springs in a different color other than the periwinkle blue? I keep hearing good things about this suspension from the GX470 guys. Even a close friend of mine just put this on his Sequoia.
08-02-2018, 10:00 AM
#1053
I just got mine in red. They also offer black. If you want either of those colors you need to contact them direct and they will send you an invoice.
20x9 +18 offset with 275/60/20 BFG KO's
Bilstein 5100's set at 0
Dobinson springs
C59-302 Front
C59-505 Rear
08-02-2018, 01:11 PM
#1054
Yes we do. There's a breakdown in the first post of this thread that shows each part number and color options. Not every coil we offer though is in multiple colors.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
08-02-2018, 01:13 PM
#1055
Originally Posted by snif6969
@ Dobinsons Mike
Hello Mike, any updates on the Pro coils 2in coils ?
Thanks
No news on those right now, sorry.
08-05-2018, 06:04 PM
#1056
Thanks for the reply, I hope development is still going on
What was the issue with the first test articles ?
TRD Pro 4Runner
All-Pro/Shrockworks Armor
Dobinsons/Dirt King 3in Lift
Rago Fabrication Goodies
08-07-2018, 11:48 AM
#1057
Thanks Mike. I've attached the measurements before and after moving to the 0.85" perch.
5100's at 0" Perch
Pre 8/1/2018 Install
Driver Passenger Lean
Front 36.75 37.25 -0.50
Rear 39.25 39.75 -0.50
Rake 2.50 2.50
5100's at 0.85" Perch
Post 8/1/2018 Install (+.85")
Front 37.25 38.25 -1.00
Rear 38.75 39.75 -1.00
Rake 1.50 1.50
I have the the C59-300's upfront too, and recently moved up to the 0.85" setting.
The Good: Looks much better, and there's no rubbing in the front. Rake is now 1.5" (rear to front)
The Bad: The driver's front raised 0.5" and the passenger front raised 1.0"; therefore the lean is now at 1.0". Also, the couldn't get the alignment within spec, so it's pulling a bit.
So.....I just purchased the adjustable SPC upper control arms, so hopefully this can bring it within spec, and help with the lean.
I'm considering having them move the lift up to the 1.75" perch. I think it would still have some rake to it, I'm just worried about the alignment - but with the new SPC arms, I think I should be ok. Any thoughts??
Originally Posted by arehman11
Anyone with 5100's ever move the spring perch from the lowest setting to the .85" setting? Currently have 300's up front on the stock perch, but wanting to get a little more lift up front. I would assume this would be similar to the height with the Dobinson long travel front struts?
I think 1/2" lean is perfectly normal. Follow this link to learn how to push out the lean: https://www.youtube.com/watch?v=xtURdW66WM4
Both of you are looking at doing the same thing. It would be good if anyone could chime in if they have done that.
Just remember, Bilstein's lift measurements are approximate and were based on stock coils, which are lighter rate than ours, so it's possible that it may lift more than what they say.
2017 T4R Off-Road Premium - White - SCS Ray 10 - 275 KO2 - Dobinson's 2" Lift
08-07-2018, 01:31 PM
#1058
In my haste/excitement/stupidity, I forgot to measure the fender gap before and after. Honestly with the amount of weight that's in it now and the spring preload, I am thinking it's closer to 2.5"-3". It will probably settle some too I think. Ride feels pretty good (was expecting a harsher ride).
I can post my alignment sheet later. Shop said they had a little trouble getting one number in spec but I can't recall what it was. Honestly the alignment specs baffle me and I dont really know much about them.
2x - Front Shocks
GS59-700
Twin Tube, fixed mount (not adjustable), suits 0-2" lift
Front springs (pair)
C59-302
100-220LBS heavy load front weight, 2" lift. 586LB
Rear springs (pair)
C59-327
200-400LB heavy rear load weight, 2" lift. 410/410mm, 18mm wire, 271LB
2x - Rear Shocks
GS59-701
Twin Tube, suits 0-2" lift. 605mm extended, 362mm compressed $190
JUST makes it into the garage
Alignment:
08-07-2018, 03:57 PM
#1059
What's the measured rake?
2x - Front Shocks
GS59-700
C59-302
Rear springs (pair)
C59-327
2x - Rear Shocks
GS59-701
Alignment:
08-13-2018, 01:42 PM
#1060
5100's at 0" Perch
Rake 2.50 2.50
Rake 1.50 1.50
Sorry for the delay, I was out of town for the past 5-6 days for a business trip.
You're in uncharted waters basically by adding preload to our coils with those 5100's, and I think that's why no one else has chimed in with help or opinions. Everyone else is running the appropriate height coil at the lowest clip height. It sounds to me like you're just getting too tall on the front, and you have KDSS too, right? You'll have to work with the KDSS system to get the lean out of it. Perhaps the installers didn't open the valves before working on it, that could easily produce a lean, especially at a taller height.
What are your measurements from the center of the hub to the fenders, front and rear?
08-14-2018, 02:46 PM
#1061
Real Name: Jason
Real Name: Jason
Shout out to Mike...Great customer service from the first time I reached out...
I ordered front 238 coils for a 1" lift in front, but maybe ended up 300s as I got a full 2" on both sides in front. 599s out back gave 1"
08-14-2018, 03:32 PM
#1062
Be best to let it all settle and remeasure after 500 miles. The 238 coils are physically shorter and I noticed it when assembling those. The shorter the coil, the easier it is to mount on a strut.
It's not a 2WD, is it?
08-14-2018, 04:01 PM
#1063
Real Name: Jason
Real Name: Jason
nope, 4wd
08-14-2018, 04:48 PM
#1064
no pics of the new suspension setup yet, but thought i'd share just how tall the C59-677V rear springs are compared to the Toytec Superflex 2" rear springs. ride has been very comfortable paired with king shocks
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
08-15-2018, 07:20 PM
#1065
Here's mine with the 300/505 combo. I had originally posted the install back in April (post #756), but now it's had some time to settle.
