Originally Posted by 4runick
Ok so I'm looking for help. I had wheelers T12 rear springs in the rear for the longest time with only stock weight or offroad weight (spare parts, bottle jack, tools, shackles, cooler: I'm guessing 200lbs). I only have sliders for added constant weight, I'm not into overlandi f but more speed in Baja. I felt like I was under spring because I would get harsh bottom out even with super stiff valving. Also we bought a 3000 lb ten trailer and it caused the 4runner to sag (not for speed off roading I like to do in Baja). I decided to try out the Dobinson c59-327 (2" with 200-400lbs). Now the springs are great for towing but now I feel over sprung just driving around. So I built a drawer system and loaded it up. I'm guessing it's 200lbs tops! Still the problem persists.
Wondering which way to go? I want to stay in that 1.5 to 2.5 lift in the rear for better performance. I'm not looking to have 3" lift because shock performance goes down the drain.
Should I go back to wheelers T12 springs with air bags or go to a Dobinson spring?
I might not see the reply immediately. I'll check but I'm on insta as @4run_nick
Thanks
Hey bud
You've pretty much answered your own question. You have the correct rated springs for the added weight and towing, but you don't like how it is when not towing. You could go down to a softer spring that isn't up to the task and add airbags to fill in that gap between unloaded and loaded. There's not really another choice.
The Dobinsons standard weight rear springs are all 220lbf/in spring rate. If the Wheeler's springs are only 200lbf/in rate, these are slightly firmer.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons |
RCI |
Powerbrake |
Long Range Tanks |
Timbren |
Overland Vehicle Systems
Youtube Channel |
Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
