09-19-2019, 12:19 PM
#1681
Banned
Real Name: Tobias Fünke
Banned
Originally Posted by DobinsonsUSA
Usually it does, but not all vehicles lean, and the ones that do don't always lean the same. Plus, you have KDSS which can cause a lean itself if it wasn't managed properly during the installation of the suspension.
Last question. How long do they take to settle fully?
Just wondering when I can redo my alignment and decide if I need to shim or not.
09-19-2019, 12:23 PM
#1682
Usually after a month of driving they would be settled, about 1000 miles.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
09-19-2019, 08:31 PM
#1683
Real Name: Jason Ford (not related to Henry or Harrison)
It's Christmas already! I finally ordered black 302/505 springs for the 2.5/1.5 lift setup. I'm going to pair this with my Bilsteins and a new set of 285 KO2s and the shiny 8.5" Ray10's in brushed copper sitting in my garage. The springs and new shoes should arrive next week. I also verified that I still have lifetime alignment with Firestone so that should save me some bucks on the install. I can't wait!!
A big thank you to Mike @Dobinsons!
2018 4Runner 4x4 SR5P, Super White w/Third Row, 285-KO2's, SCS Ray10’s, Dobinson 302/505 springs with 700/705 gas shocks, Tandem Sliders, TRD Skid, Cold Air Intake
2015 4Runner 4x2 SR5 Premium, 5100’s, KO2's, Super White (sold)
09-19-2019, 10:17 PM
#1684
Called it in and FedEx unlost my package. Shit is heavy as dick I guess I would have tried to loose it too.
Also spoke with Brian in Miami and tried unsuccessfully to get Dobisons USA to switch to UPS citing the documentary Castaway. I don't think he took me seriously.
It's going on this weekend. I'll leave my thoughts then.
Sent from my SM-G930T using Tapatalk
USPS lost a set of Fox 2.5 coilovers for me once. That was FUN.
09-23-2019, 08:53 PM
#1685
So my current set up is TRD pro wheels with stock tires. I have Bilstien 5100 all around and max height on the front and a daystar spacer 1.5 in the rear. I’m also running spidertrax 1.25 spacers. If I want the same lift should I go with 302/505 springs for the 2.5/1.5? I don’t want to buy UCAs. But I would like to upgrade my tires later.
09-24-2019, 10:37 AM
#1686
Yes, those would be the correct coils to use front and rear, as long as it's all stock weight.
09-24-2019, 01:18 PM
#1687
Yes, the runner is stock lbs and I dont have anything heavy inside or hauling a round.
10-02-2019, 12:59 PM
#1688
Sorry for what I'm sure is a very common setup question, but I can't seem to locate the answer.
2015 non kdss and want to run 3" ish front and 2-2.5" rear. (If that makes for a good stance?)
Will have 285 K02s on 17x8, backspace of 4.1, offset -10 (countersteer type x)
Will have SPC UCAs.
Want to avoid BMC if at all possible. Okay with trimming and pushing liners.
Will likely add top rack (gobi or front runner 3/4) - No bumpers intended, no drawers.
Would this be the best kit setup below for a nice stance at the height desired?
FR coil = c59-302
FR shock = gs59-700
R coil = c59-325
R shock = gs59-705
w/ diff drop.
(do these require sway bar relocates?)
cheers!
10-02-2019, 02:13 PM
#1689
Will have SPC UCAs.
FR coil = c59-302
FR shock = gs59-700
R coil = c59-325
R shock = gs59-705
w/ diff drop.
cheers!
Hey bud,
FR coil = c59-302
FR shock = gs59-574
R coil = c59-325
R shock = gs59-705
Use the GS59-574 to get you that 3" to 3.25" up front.
No, sway bar links aren't required, although on the rear they would help put the sway bar back into a stock operating angle to help with articulation a little better.
This will be a good stance, lots of guys on here are running that 3" front and 2" rear setup.
10-02-2019, 02:24 PM
#1690
Hey bud,
FR coil = c59-302
FR shock = gs59-574
R coil = c59-325
R shock = gs59-705
@ caskew13
I have the same setup except have 701 rear shock due to weight from 3rd row, sliders, etc. Been very happy with the setup.... ride and stance. You definitely will need your aftermarket UCA's.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
10-02-2019, 03:32 PM
#1691
Re-did the alignment today after a long off-roading trip. The technician got these numbers. Super pleased with the caster im getting from the UCAs.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
10-02-2019, 03:38 PM
#1692
Hey bud,
FR coil = c59-302
FR shock = gs59-574
R coil = c59-325
R shock = gs59-705
Thanks so much. Any word on BMC with 285s at this lift? Is there a possibility it could settle into needing one after some time?
Originally Posted by matoolie
@ caskew13
Awesome. I may go 701 as well considering the roof rack and possible sliders that I didnt consider until you mentioned it.
No regrets not having adjust-ability in the front?
10-02-2019, 03:43 PM
#1693
I ordered a pair of c59-599 springs yesterday. Also a full set of bilsteins. Planning to go 1.75 setting on the billies up front and 599 rear springs with air lift bags in the back. Super stoked to try out these springs!
10-02-2019, 04:02 PM
#1694
No regrets at all. No need as alignment came out great with UCA's, stance is good, ride is great. Also I am running 285's Wildpeaks and no BMC needed. Little close on the driver's side but OK. FWIW my wheels are are FN Pro's 17x8, 4.5" backspace, 0mm offset.
Michael
10-02-2019, 06:25 PM
#1695
Banned
Banned
Very happy with the setup so far. Prob think about another alignment at some point this month.
