11-17-2019, 02:12 PM
#1771
Just a quick question, my 4runner has KDSS but I went ahead and got the non KDSS rear coil due to Dobinsons availability and my available installation time. I got the spacer pack to help offset the KDSS lean, the spacer goes on the rear Passenger side is that correct?
11-17-2019, 10:06 PM
#1772
Still loving my @Dobinsons suspension.
2018 ORP Barcelona Red
Dobinsons 2.5”/1.5” lift with springs and shocks.
Diff. Drop.
Pro Comp UCAs.
RSG angled sliders.
11-18-2019, 03:02 PM
#1773
Real Name: Chris
Real Name: Chris
Originally Posted by jhguth
Any info on the MRA's? heard they had them at SEMA
@ Crikeymike
Hi Mike, any more info on this new setup?
11-18-2019, 05:27 PM
#1774
Originally Posted by 2barevo
@ Crikeymike
Still waiting for all the stock to arrive so that we will be able to sell it for all the major models. But here's the lowdown.
10 stage high speed compression adjustment
20 stage slow speed compression adjustment
15 stage rebound adjustment
On the struts, rebound adjustment is from the top stud, quite simple to get to above the strut tower.
On the shocks, rebound adjustment is in the lower mount.
High and slow speed adjustment is both handled at the reservoir front and rear.
All in all, they look a lot like the standard MRR shocks we have had for some time, but they include full swivel fittings on the reservoir hose, both ends, to avoid it becoming loose and ease of installation and orientation. But with all the adjustment, you could literally tighten them up so much to essentially stop all movement or soften then up to suit it however you like. The range of adjustment is massive which is excellent for those going from no load to heavy loads, or those that want it softer on the highway than while offroad.
4runners will still not use a piggy back mount for the reservoir.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
11-19-2019, 01:33 PM
#1775
Is there a diagram that has any more detail? I bought a set of KYB top hats to assemble my coilovers and I cannot get enough threads to show to be able to get the nut on - obviously I'm screwin the pooch somewhere!
Alex
11-19-2019, 02:32 PM
#1776
Real Name: Chris
Real Name: Chris
Thank you! when you said "4runners will still not use a piggy back mount for the reservoir," did you mean it will be mounted on the chassis vs the strut?
I have KDSS with full metal front bumper and would like to go with the 3" lift. Would you suggest 3" front-heavy duty and 2" rear-heavy duty? I would like to keep it level as much as possible but want to prevent reverse rake when all loaded up in the rear for our trips.
11-19-2019, 04:58 PM
#1777
Will these require periodic rebuilding? If so at what interval?
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
11-19-2019, 06:56 PM
#1778
Usually it does, but not all vehicles lean, and the ones that do don't always lean the same. Plus, you have KDSS which can cause a lean itself if it wasn't managed properly during the installation of the suspension.
Can you elaborate on this a little? I was told if doing a self install for the rear, its suggested to keep a jack under the rear KDSS piston. Do you have anything to add to this? I haven't found much on the site and I'm just trying to get a better understand. Thank you
11-19-2019, 07:49 PM
#1779
Alex
You can't assemble them without a strut coil compressor. the coils are too long to use the "do it without the compressor tool" installation.
From the bare stud, upwards
Washer
Bushing
Locating washer
Strut plate
Top bushing
Top washer
Top nut
Edit, scroll down on this page to download the sequence diagram
Instructions – Dobinsons Direct
11-19-2019, 07:51 PM
#1780
No, not at all. They're built with components to last as long as possible. there are heaps of guys running MRR's for years without a rebuild.
11-19-2019, 07:53 PM
#1781
Correct. Reservoirs mount to the frame. Some vehicles have room for a piggyback reservoir. meaning mounted to the shock itself (Jeeps, etc) but they won't fit on 4runners.
Yes, 3" front and 2" rear is what I run on mine with KDSS and just choose the appropriate springs to match the weight you have.
11-19-2019, 07:54 PM
#1782
In this thread I have my own version of kdss instructions listed. You would just need to search back and see. There's also plenty of other threads on the forum that break it down.
11-19-2019, 11:15 PM
#1783
Washer
Bushing
Locating washer
Strut plate
Top bushing
Top washer
Top nut
Mike
Thank you for the reply! IÂ’m using a compressor. My issue seems to be with the KYB bushing being glued in.
11-20-2019, 12:05 AM
#1784
Mike
When I just redid my front's a few weeks ago w/ KYB strut mounts I noticed the same thing, just place the washer below it, then the bushing/mount over it
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
11-20-2019, 01:38 AM
#1785
Sweet! So you’re saying washer>top mount>bushing>washer>nut.
Does that sound right?
