12-08-2019, 03:38 PM
#1831
Originally Posted by Drebels
Any insight on this..
Only Rear passenger side is sagging. Fronts measure fine and even
No weight in the back. Took everything out. I jacked the car up to let the suspension drop but once down goes back to the same sag.
Shocks show no sign of leaks.
Tire pressure is all same.
What else should I check to see what's going on?
Gas tank is full. Sag is there full or empty
2017 TRDP with C59-325. Springs have been on the car since 2017 Aug.
Sent from my ONEPLUS A6013 using Tapatalk
What are your hub to fender meaurements? How much difference are you seeing?
Do you have KDSS?
Are there any accessories on your 4runner that are more to one side than the other?
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
12-13-2019, 10:47 AM
#1832
Looking to order the kit for my 2019 5th Gen. Anyone aware of any Christmas sales or discount codes?
12-13-2019, 12:21 PM
#1833
If you buy directly you can get a discount!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
12-13-2019, 12:26 PM
#1834
Thanks! I'll email them to see if they have something going on. I was intending to buy it directly from them.
EDIT: Just received a message that they won't be having any specials in the near-term and the best they have right now is a 5% coupon. I'll pass and shop around since I'm in no rush.
12-16-2019, 10:47 PM
#1835
Is it possible to order a Monotube setup without the remote reservoir?
12-16-2019, 11:02 PM
#1836
Hmmm I dont think so. If you want monotubes without reservoirs check bilstein or icon stage 2. Why dont you want the reservoir?
12-16-2019, 11:17 PM
#1837
Actually, Icon stage 2 was exactly what I had in mind. The reason would be to get a monotube shock over the baseline twin tube design but without the RR which i do not foresee needing. I do not intend on going fast over washboards especially for prolonged periods so I don't see fade as a major issue for me and my style of driving that would warrant a RR with its added complexity and cost.
12-17-2019, 01:12 AM
#1838
Ahh ok. Main reason Id want the RRs was for the "shorter" size as the nitro charge is in the RR. Don't really need it though as I've been pretty pleased with the dobby twin tubes. Was originally considering the Icon Stage 2s but decided to save a bit and spend the rest on armor. Haven't felt the need for a monotube or feel there would be an improvement for what I drive in (socal lots of visits to death valley). Only thing I'd change is probably the rear shocks but that was me picking the wrong valved shock for the load I carry.
Hope you find a shock that works out great for you!
12-17-2019, 07:58 AM
#1839
They make a non res mono tube. It’s called an IFP. I wanted them a year ago but I can’t remember if they didn’t have them in the US or if was the cost.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
12-17-2019, 11:28 AM
#1840
Thanks man! Those are exactly what I was hoping they carried as an option. I’ll wait for Mike to come back to see if they sell those here, but having gone through quite a bit of this thread,I don’t think many here have had real world experience with this particular set up though I guess the ride (for what I am looking for) would be quite similar to the mono tube RR shocks...
12-17-2019, 01:17 PM
#1841
Anyone running 505 rear springs on a 4 runner 5th gen? Wondering if your getting on the lower end 1.25” or the higher end of 1.75”?
12-17-2019, 06:56 PM
#1842
Yes, I can order the non resi monotubes but air freight costs would need to be added. Can quote after the holidays when I'm back .
Sent from my SM-G973U using Tapatalk
12-17-2019, 06:58 PM
#1843
It's more common to be on the higher side, as 1.5" would be the minimum lift height on a stock model. All lift heights I list are pretty much the minimum lift height you'll get.
Most in the past on here with 505s quote 1.75" lift with stock weight and 1.5" with 100lbs or a 3rd row seat. Hope this helps.
12-17-2019, 07:21 PM
#1844
Thanks Mike! I'll email you in a few weeks..
12-18-2019, 09:35 AM
#1845
Real Name: Jason
Real Name: Jason
ordered the 2.5/1.5 kit (black shocks/red coils) on black friday. pretty excited and cant wait to get it in. didn't have enough for the uca's but i'll prob end up buying some in January. i'm in no rush to install yet. i just wanted to get on the BF sale.
