Crikeymike
Thread Tools Rating: Thread Rating: 56 votes, 3.32 average. Display Modes
Old 07-02-2020, 02:33 PM #2371
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Originally Posted by Nyte_rnr View Post
This is perfect. Thank you Mike!
Looks like I’ll be going with:
Front - MRA59-A574 (long travel instead of standard, correct?) with C59-314 coils and set the ride height lower until more weight is added.
Rear - MRA59-A701A (standard travel) with C59-325/327/329 coils As needed.
I’m assuming long travel would be unnecessary for the rear in my case since I’m only going up to 2” and KDSS is involved? Just wondering since you recommended long travel for the front for future height adjustments.
That’s all the info I needed to feel confident about this purchase! Thanks for the quick reply
Yes that's correct up front. I do recommend a diff drop kit up front with the long travel struts to avoid CV binding at full extension.
Yeah, on the rear just the regular 701's. The KDSS models can't use long travel rear shocks, as it would lead to a $4000 catastrophe pretty quickly!!
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 03:31 PM #2372
30338 30338 is offline
30338 is on a distinguished road
So if I have Bilstein 5100 shocks, set at the 0" level, and use the C59-300 springs in front I should end up with a 1.75" lift in front? Never done this so wanting confirmation. Thank you
2003 SR5 V8 Silver, 2018 SR5 Magnetic Grey
30338 is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 10:21 AM #2373
Crikeymike's Avatar
Crikeymike's Avatar
For a V6 with stock weight. Yes that's right
Old 07-05-2020, 03:11 PM #2374
macscac's Avatar
macscac macscac is offline
macscac has a spectacular aura about macscac has a spectacular aura about macscac has a spectacular aura about
macscac's Avatar
@Crikeymike
I need some advice.
I would like to raise my rear 1" and replace the stock (rear) strut with something with a little more long travel.
what would you advise?
i have 2018 trdor with KDSS.
This is my current set up.
thank you
Dobinsons c59-314 in front. 3” lift
Front struts GS59-700. Long travel (+1”)
Dobinsons C59-327 in rear. 2.0” lift
Dobinsons UCA59-002k. UCA’s
Stock rear struts
macscac is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 09:37 AM #2375
Ordered those 300s and some 505 for the rear. Can't wait to try them out. Thanks for the help.
Old 07-06-2020, 10:22 AM #2376
Crikeymike's Avatar
Crikeymike's Avatar
Originally Posted by macscac View Post
@Crikeymike
I need some advice.
thank you
Stock rear struts
GS59-701 are the longest shocks you can run with KDSS in the rear.
What's your hub to fender height in the rear? Usually 2.5" is the max height I suggest with KDSS because it can end up giving you a lean that's hard to correct from left to right.
Old 07-06-2020, 12:30 PM #2377
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough Jeff_DML will become famous soon enough
I just installed this setup on my SR5 third row last week,
Measuring from the hub to the fender I gained 2.5" front and rear initially. The rear did seem to settle about by .5 inch so it is current measures 2.5f/2r.
How long does it take to usually settle? My buddy suggested I should try articulating the suspension to get it to settle quicker? Maybe my stock suspension was sagging? had 40k on it.
The way I am measuring I admit is not the most accurate since I am guesstimating the middle of the axle.
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 02:38 PM #2378
Crikeymike's Avatar
Crikeymike's Avatar
Suspension takes about 500 miles to fully settle. Yeah, getting it offroad and cycling thru the suspension will help settle it.
Front should be around 22" and rear 23.5" hub to fender with the parts you have.
If you can't find the middle of the wheel, measure from the bottom lip of the rim to the fender, then deduct the radius of your wheel to find dead center without randomly holding it in the middle.
Old 07-06-2020, 02:47 PM #2379
thanks, you should put the settling info in your OP. I searched around but could not find any info.
I measured 20.5"f/21.5" rear with stock suspension but my driveway is probably not exactly level. Currently measuring 23"/23.5" in the same driveway location.
thanks for the info, will try to cycle the suspension.
Old 07-06-2020, 07:56 PM #2380
pwflaherty87's Avatar
pwflaherty87 pwflaherty87 is offline
pwflaherty87 is on a distinguished road
Got my setup installed. Ride is much improved. 2.5 front and 2 rear looks perfect to me, bigger than it sounds. 285s with 1.25" spacers fit perfectly with a little trimming on the bumper and removing the front mud flaps. No BMC!
Front C59-302 / GS59-700
Rear C59-725 / GS59-70
JBA UCAs
Nitto Ridge Grapplers passenger rated, nice and quiet but difficult to balance.
Overall, thanks to everyone in this thread, especially Mike.
Sent from my SM-G973U1 using Tapatalk
2020 Superwhite TRD ORP
- Dobinsons 302/700 725/701 // JBA UCAs
- 285/70r17 Nitto Ridge Grappler SL // Spidertrax // Trail wheels
- LFD Ruggedized Crossbars // Weathertech // Canvasback
pwflaherty87 is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 08:58 PM #2381
Crikeymike's Avatar
Crikeymike's Avatar
JBA UCAs
Nice!! Looking good!!
Old 07-07-2020, 02:13 AM #2382
macscac's Avatar
macscac's Avatar
my hub to fender is aprox 23" in front and 24" in the rear currently.
will those shocks you recommended give me some additional stretch when im flexing the rear?
I am assuming they will not affect the lift at all
is my current hub to fender that tallest that I can get all around?
thanks!
Old 07-07-2020, 06:49 AM #2383
After 150 miles I am noticing a pretty significant lean to the driver side. I guess I'll let it settle for a while, but I wasn't expecting this much lean with this setup.
Old 07-07-2020, 08:09 AM #2384
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
I've got the same setup as you and had a lean to the drivers side for the first 500 miles or so, was concerned it was the 725's possibly.
After the 500 mile mark, I did the KDSS calibration (opened the shutter valves) and it's sitting perfectly level in the back and an 1/8" off on the front - gas likely affects this.
Question for you, what are your center hub to fender measurements? I got a LOT of lift in the rear (24.5" with the 725s, have confirmed coils are properly seated). The fronts I'm sitting right at 22". No extra weight except sliders and no 3rd row.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 08:31 AM #2385
I'll do a proper measurement tomorrow, need to find some level ground. It was level at first, then I loaded up a couple hundred lbs plus a tank of gas and now I have this dang lean. Even unloaded. I have to go back to the shop to get my tires rebalanced anyway. Maybe I can have them recalibrate the KDSS at the same time? Unless someone here suggests I just wait for 500 miles.
Build assistance - Feedback on suspension choices for my usage. Keith_PDX 5th gen T4Rs 31 05-04-2015 03:13 PM
Suspension Choices MadeInMaine 5th gen T4Rs 8 07-22-2013 08:44 PM
lift spring choices/ tire choices ohnoitsthecops 4th Gen T4Rs 19 02-02-2012 11:32 AM
Battery choices/options for reliability and safety? Clifford 3rd gen T4Rs 26 12-10-2011 03:15 AM
1989 4Runner SR5 **Lots of Options** $4000.00/obo - Orlando, FL vjr021 Classifieds - buy & sell (no commercial ads please) 0 10-13-2008 08:22 AM
