Crikeymike
Thread Tools Rating: Thread Rating: 56 votes, 3.32 average. Display Modes
Old 11-21-2020, 11:32 AM #2701
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Originally Posted by DSRunner View Post
Hey Mike,
I'm want make sure I'm ordering the correct components. I'm looking for a 2.75"/2" lift. I usually run around with minimal weight except for occasionally camping/overlanding trips (4 times a year). Is this correct for what I'm looking for?
Front: C59-300 (red) + GS59-574 (black)
Rear: C59-325(red) + GS59-705 (black)
Dobinson UCA + Diff Drop
Also, are the Extended Rear Swaybar End Link Kit recommended with this suspension setup even though the GS59-705 are not the long travel?
Thanks!
Yes that is all correct. That will get you that lift height you're looking for.
The sway bar links realign the sway bar to a more neutral position which allows for better articulation. The sway bar at a steep angle can inhibit the flex a bit. Someone on here posted photos with and without a few years ago and he had noticeable difference in flex left to right.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 11-21-2020, 04:48 PM #2702
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
@Crikeymike finally getting around to adding bumpers. Totally owe you for my meltdown last year lmao. Starting in the rear so I ordered c59-327 in black from you.
Have a question about adding the LT front strut and 2” spring in the front to get 3” of lift (kdss). Will the cv’s actually bind at full droop or is adding a diff drop just the manufactures recommendation? What have you seen personally? From everything I’ve read the diff drop barely accomplishes much change in angle and drops your skids.
Thanks mike
Mutant138 is offline   Reply With QuoteReply With Quote
Old 11-22-2020, 11:26 PM #2703
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
TLDR: monotubes cool off much quicker and I'm pretty pleased with the IMS rears!
Finally had a chance today to do some mid-speed runs (30-40mph) over a heavily corrugated/mogul heavy trail. Much more corrugated than anything I've experienced in Death Valley for sure. After a half mile or so section, I took the surface temps of my shocks (twin tubes in front and monotubes in rear). Before getting to the temps, I gotta say I'm really happy I made the switch from 705 valving to the 701 valving (50701 shocks). The rear is SOOO much more controlled now on the rough trails. Yea I can feel more on road but the trade off was worth it for the off road control.
Anyways back to the shock temps.
Always heard that monotube shocks cool off quicker than twintubes. Made sense due to how they are constructed differently but never got to test it till now. Did a mogul heavy trail today and got my rear IMS monotubes up to 235f. Front twintubes were around 155f. Both temps were surface temps so actual fluid temps were likely higher.
After taking a short 6 - 8 min break, the twin tubes dropped to 140f while the IMS monotubes dropped to 175-180f. With these numbers in mind, I'll eventually switch the fronts to IMS when my current ones fail!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 01:27 PM #2704
Crikeymike's Avatar
Crikeymike's Avatar
Thanks mike
Hey man. Nice, upgrade time!!
So the longer travel front GS59-574 max out the CV's at full droop to the point of almost binding under the weight of the vehicle. That's why we recommend a diff drop kit. I was the first to run them in the UCA, and when you rotate the wheel at full droop without a diff drop kit, you can feel the resistance starting there. If the tire had a chance to pull the suspension down a bit further, it would be binding for sure. Adding the diff drop kit made enough difference to reduce that binding.
Whenever people say "this" or "that" about a diff drop kit, they need to ask about the overall travel of the struts. Regular Bilsteins, Dobinsons, OME, etc don't have the full droop that the *574 options do from Dobinsons, and don't need a diff drop.
But also, if you'll never get the wheels in the air (aka jumping or flying fast offroad), then you'll never get the CV's to that binding position most likely.
Old 11-23-2020, 01:28 PM #2705
Crikeymike's Avatar
Crikeymike's Avatar
Nice, that's really good feedback Kevin!!
Old 11-23-2020, 04:36 PM #2706
Banned
Banned
Fair enough. My current ride height up front at 2.5” is acceptable. C59-352 is my next consideration(120lb bumper + winch).
2.5”/2” lift adding an inch of rake with the 327’s I ordered for the rear. This a common setup?
Old 11-23-2020, 05:27 PM #2707
Crikeymike's Avatar
Crikeymike's Avatar
Heaps of guys are running a similar rake setup, about 1.5" of rake when it's all said and done. Good for being able to load up the rear without getting less than level. I think more people are doing 2"/1.5", but it yields the same rake results.
Old 11-25-2020, 06:45 PM #2708
B... B... is offline
B... is on a distinguished road
Originally Posted by B... View Post
Another data point for Dobinsons/Exit Offroad. I messaged Mike on Sunday. He responded Monday. Parts ordered on Tuesday night. Assembled/shipped on Wednesday. Delivered on Monday. Can't beat that!
Parts installed: C59-300 front coils. GS59-700 front struts. C59-599 rear coils. GS59-705 rear shocks.
Parts removed: Bilstein 6112 (busted). Bilstien 5100 rear shocks. OEM rear coils.
Tires: 265/70/17
Current hub to wheel well measurements after 150 miles: 22.50" Front. 23.25" Rear.
Took a nice 120 mile drive today. 100 miles on the hwy at 70-80 mph. 20 miles on the dirt at 30-50 mph. This setup rides great. Two thumbs up.
2,000 mile/new tire update
I've seen minimal, if any settling or loss of lift. Still 100% happy with this setup. My current center of hub to fender measurements are:
Driver Front: 22.25"
Passenger Front: 22.50"
Driver Rear: 23.00"
Passenger Rear: 23.25"
The 265/70/17 BFGs were just a bit too small for this much lift and didn't look right. Stepped it up to a new set of General Grabber A/TX in 275/70/17 yesterday.
B... is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 07:22 PM #2709
Banned
Banned
352's in black for the front just backordered.
2.5"/2" it is.
Exit Off-Road FTW! Get that discount while it lasts people its a good deal!
Old 12-03-2020, 12:46 PM #2710
gantorris gantorris is offline
gantorris is on a distinguished road
How long currently are orders with assembly taking?
2021 Red Venture
gantorris is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 12:55 PM #2711
Crikeymike's Avatar
Crikeymike's Avatar
At least 1 week delay if the parts are in stock. There are hundreds waiting for assembly right now
Old 12-03-2020, 01:11 PM #2712
Thanks for the info, my wife keeps asking if her lift has shipped.
2021 Red Venture
Old 12-03-2020, 02:25 PM #2713
Crikeymike's Avatar
Crikeymike's Avatar
Just tell her it's shipping from Australia and it will take a little while, then she'll stop asking for a few weeks. LOL
Old 12-03-2020, 03:29 PM #2714
Hmm thats odd...mine keeps asking when are we going to get rid of the runner
Old 12-03-2020, 03:53 PM #2715
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
Okay... so I've bee researching again. Currently I am running OME 3" with 885s and 898s (IIRC) both of which don't have the lift they once did. Of course I've added 500ish pounds of junk to the truck over the last couple years. C4 rear bumper w/dual swings, C4 fuel tank skid, RCI aluminum skids, cargo leveling platform, molle panels, etc. Most of the weight is biased to the rear but the front has definitely lost some height as well.
If I were trying to get a 2"-3" lift with an IMS kit, should I start with 314 coils in front and 727 or 729 (I do have KDSS) springs in the rear? I haven't been able to find wire diameter and free length for the 314s yet.
A 302 is very similar in spec to my current set up, which rides okay but could stand to be higher. I'm guessing the 314 is longer than the 302 since they are advertised as the same spring rate. The 352 advertises similar lift at similar loads, but at a lot higher spring rate. So I'm guessing the ride is not as nice on the daily.
Not exactly sure where to land for rear springs. If I take in account my current set up and how much it dropped after adding the bumper, it would push me towards the 729 but, I also remember that it rode a lot better after adding the weight. So do I want to go with a lower rate longer spring...like a 727 or 329?
Grrrr I get in too deep looking at it. When considering load weight, should we consider the load per axle or overall?
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Build assistance - Feedback on suspension choices for my usage. Keith_PDX 5th gen T4Rs 31 05-04-2015 03:13 PM
Suspension Choices MadeInMaine 5th gen T4Rs 8 07-22-2013 08:44 PM
lift spring choices/ tire choices ohnoitsthecops 4th Gen T4Rs 19 02-02-2012 11:32 AM
Battery choices/options for reliability and safety? Clifford 3rd gen T4Rs 26 12-10-2011 03:15 AM
1989 4Runner SR5 **Lots of Options** $4000.00/obo - Orlando, FL vjr021 Classifieds - buy & sell (no commercial ads please) 0 10-13-2008 08:22 AM
