02-02-2017, 02:53 PM
5th Gen toytec lift question
im currently deployed in the middle east and was wanting to put a toytec boss 2.0 lift on my 14 sr5 when I get back. my question is with the TRD rims im going to buy what the biggest size tire I can put on without cutting? I was looking at Falken wildpeak a/ts and Nitto terra grapplers. I appreciate any help, thank you!
02-02-2017, 03:16 PM
well, guess it depends on what kind of trimming. TRD pros have their bumpers trimmed at port to fit the stock tire size on the TRD wheels. So...if you don't want to trim at all, don't run the TRD wheels.
There is also an entire thread that goes over the subject of tire sizes and modifications required.
2016 Trail and half of an early 90s Ford Ranger
02-02-2017, 03:30 PM
Real Name: Jeff
Real Name: Jeff
No trimming at at all? I'd say stick with the 275/70/17's. If you don't mind trimming some 285/70/17's.
I'm glad this question came up though. Haven't seen it before.
3RDGENS.COM
My Video's
'96 Limited - October '08 T4R Of The Month (Sold)
'00 SR5 - Lifted/Supercharged/E-locker
'16 SR5 Barcelona Red
02-02-2017, 03:54 PM
Troner envy... the struggle is real!
02-02-2017, 05:08 PM
I was gunna go with the regular 17' trd 4runner rims
Sent from my SM-G925P using Tapatalk
02-02-2017, 05:51 PM
Real Name: Chris
Real Name: Chris
Exactly... as
@ (none)
was saying. They have a different backspacing, so it's like running stock rims with spacers.
You'll notice in the threads below...
Stock trail/SR5 rims = No rub
TRD or aftermarket = Rub
Lift make very minimal difference because of wheel articulation through the movement of th shock with our wheel wells + IFS. You may not rub on the street but if you get anny flexing off road you will.
Anyone got a pic of BFG KO2 275/70R17 on your 4R without lift?
2016 Trail - 275/75/17s are rubbing - Thought I'd be OK
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
02-02-2017, 09:36 PM
Originally Posted by Cymon
So after reading, my stock rims are 17×7.5 and the TRDs are 17×7... i forgot to mention i was going to put on 1.25' wheel spacers on along with the 3.5' toytec lift. So would i be able to up size my tire with those on without cutting? Mabye 33s or 34s?
02-02-2017, 09:57 PM
Real Name: CJ
Real Name: CJ
Wheel spacers equal cutting, period. I'm still running 265's on 8" wide wheels with spacers on a 2" lift. Had to cut both front fender and mudflaps. I didn't have to cut the flaps until I added the spacers. 33's equate out to 285's and most 285's require cutting even without spacers. And sometimes a body mount chop. Sometimes you just won't know until you stuff them under there.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
02-02-2017, 09:59 PM
Real Name: Dave
Real Name: Dave
Larger Tires
I'm not sure about your wheel size. In 2015 SR5 rims were 17x7. The Trail rims were 17x7.5. For 33 and 34 inch tires you need to check the recommended rim size. The link that CF Machete posted probably has some info on required rim size. They may require 8" or 9" rims.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
02-02-2017, 10:15 PM
Real Name: Chris
Real Name: Chris
Correct, but the backspacing on the Trail wheel is different then the TRD. The TRD is thinner but spaced so it would look like an 8" wheel for appearance (that's why they have to trim TRD Pros at port even with stock 265 70r 17 Nitto Terra Grapplers). So if you were to add a 1.25" spacer to that you would also essentially have to trim as much as you would with a 9" wheel that had OEM backspacing.
Also as
@ DesertCanyons
mentioned most tire manufacturers do not recommend over a 275 70r 17 on a 7" rim. 285's or bigger usually require a 7.5" rim at minimum although there are many on this forum that run 285's on the TRD wheel (they are just outside the recommended manufacturer specs and some places won't mount them).
ARB Breather Mod
02-02-2017, 11:56 PM
While I don't have the Toytec lift on my truck I do have the BFG A/T 285s, Spidertrax spacers and stock wheels. I only had to fart around with the inner fender liner a bit and remove the mud flaps. I'm running the OME setup which I think gave me about 2.5 inches of total lift. Here's a pic for you to judge...
02-03-2017, 12:13 AM
Oh i see- the stock trail rims are 16" rims, right? The trd ones are 17". That means that the tires to fit the TRD rims are generally bigger, while the stock rim size gives a little more tire meat?
02-03-2017, 12:20 AM
Stock trail wheels are 17 x 7.5
TRD Pro Wheels are 17 x 7
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
02-03-2017, 12:51 AM
Real Name: Chris
Real Name: Chris
Nope, all 5th gen wheels are 17" except the limited which are 20".
This is correct. The TRD wheels just have a different backspacing/offset that push them out further.
ARB Breather Mod
02-03-2017, 01:35 PM
If the TRD wheels are pushed out further, then wouldn't that equate to less rubbing
