03-06-2018, 08:15 PM
#61
Real Name: Justin
Real Name: Justin
Saw this at my local stealership parts last weekend.
Sorry about the Antman quality.
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
03-06-2018, 08:25 PM
#62
Originally Posted by LandCruiser
I use FJC steelies and Spidertrax.
The dealers in CO know how not to bugger up spa... I mean "hub adapters" when they rotate the tires, and even sell trucks with them installed.
Ooooh, I dig it. Got any good photos of your truck?
2014 Trail - 5100s at .85, 265 KO2s
03-06-2018, 09:01 PM
#63
Real Name: Sparky
Real Name: Sparky
Photobucket nuked my account, but I'll look in my phone.
Here you go, trail tires and snow tires mounted.
Old and (c)rusty.
03-07-2018, 07:55 AM
#64
@ LandCruiser
Man, I like that. Pure utilitarian.
Did you get them from a dealer? What suspension are you running while I'm asking questions?
03-07-2018, 08:01 AM
#65
Real Name: Sparky
Real Name: Sparky
@ LandCruiser
I got the first set from CL for 25 bucks a piece. They are actual dealer take offs and rust like FJ steelies are prone to do.
The second set were from Road Ready wheels. They are "OEM replica" but they have a much nicer paint job. I think they were 60 bucks each. They look more or less like the real thing and it's really hard to screw up steelies.
Lift is just a Toytec Ultimate with Bilstein 5100s and SPC UCAs.
Old and (c)rusty.
04-30-2018, 02:33 PM
#66
Oh H3LL yeah! Those steelies are cool AF.
2018 TRDORP, White/Black, KDSS, RSG Sliders, Husky Mats, Canvasback Cargo Liner, L-Track Tie Down Rails, Smittybilt Beavertail, Portable Single ARB, ProClip A/C Ham Radio Mount, Factory Cargo Cover, Black SpiderTrax Wheel Spacers, K&N Filter/Air Injection Mod, More to follow....
04-30-2018, 03:34 PM
#67
Pretty interesting posting
09-26-2018, 01:33 PM
#68
Originally Posted by YellowRaven
Always have the option to have the stock trail wheels powder coated
I like the way your wheels turned out. Did they need to be sand blasted to remove the original coating before they were powdered coated?
09-26-2018, 01:43 PM
#69
I'm curious as this as well as the overall cost so I can compare. There's only one place near me that does PC and they quoted me $60 wheel plus material cost. Throw in $75 to have the tires removed then reinstalled and I fear by the time tax 9% tax is added in it's going to come within $100 to what a set of FN FX PROs would run. I'm just wondering if it's worth the cost or should I just excessively prep and use Plasti-Dip because I do prefer the TEP/TRDOR wheels over the SEMAs. I think because every single 5th gen in my area that's not a limited has driven down to Nashville and purchased a set from whatever that warehouse is that sells on ebay.
'16 Magnetic Grey Trail Premium
09-26-2018, 03:18 PM
#70
I don't like my Trail wheels and especially hate the looks of the Bridgestone Dueler HTs. Not enough wheel offset (I have a Toyota Boss lift so that brings in the two front wheels) so it makes it look like one of those trucks that you drive on railroad tracks and the Duelers are so boring. They seem to wear fast and I have already had one with a defect and had to replace it.
Bout to put SCS Ray10's and BFG KO2 C load on it (weight of wheel and tire with those options is only about 3 lbs more per wheel). But it aint cheap. SCS wheels have a -10 offset and a 4.30 backspacing. As far as I can tell that is the best without going overboard. Icon Rebound and Method have a 0 offset and a 4.75 backspacing. I think better than stock but still doesn't sit out enough in my opinion. I think Icon and Method were probably designed to be a good wheel compromise for stock and lifted. SCS was probably designed primarily for lifted Toyota's.
The big hassle is selling the stock wheels once I get the new wheels and tires.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
09-26-2018, 04:45 PM
#71
To answer the OP question. I would say yes. TRD wheel is Made in Thailand by the same factory that make wheels for TECHART. I think that gave it a better pedigree no?
IG @ BAJA4RN 2015 4runner TPE, Grey, 285/70/17 BFG KM3, Method 105 17x9 3.50" BS 6x139.7, Magnuson SC, FrontRunner Slimline II, ARB Summit front bumper, Bruteforce Rear, Safari Snorkel, Autohome Columbus RTT, Alu Cab Shadow Awning,Quick Pitch Ensuite, King Shocks OME 2.5", Dometic CFX 65W, REDARC Multi-Stage charger, 100W solar panel, 80ah 2nd AGM battery, BAMF sliders
09-26-2018, 05:00 PM
#72
SCS wheels are also made by that company.
09-26-2018, 05:02 PM
#73
As someone who's driven on both (I swapped by OffRoad wheels for TRD which I'm currently on).
1) Weight savings at the wheel isn't trivial. It has a number of positive effects and only a couple negatives
Firstly, a vehicle with just a few lbs heaver on each wheel can be robbed as much as 5% from HP and Torque at the wheels. This is demonstrated and confirmed (youtube search it). Rotational mass and inertia mean more power is robbed and obviously fuel economy effected.
Secondly, rotating mass also has more burden on the braking system. This matters both NOW with how the brakes perform but more importantly, how long the pads and rotors last.
Thirdly, reducing unsprung weight improves suspension characteristics. Granted, on an SUV the effect is muted, but the way a tire reacts to imperfections in the road changes based on how heavy the wheel is. The lighter the unsprung mass, the more grip and quicker harmonics to return to grip when negotiating holes and bumps at speed.
Lighter wheels DOES however transfer road imperfections more. It makes sense that big heavy wheels and tires soak up things better, so lighter wheels will help you feel everything just a little more.
Lastly, I actually preferred the styling of the OR wheels, but for what it was going to cost to have them powdercoated black, I just decided I could buy new TRD wheels and sell the OEM (and that's what I did). Metal/Stainless just doesn't go well with an all black 4Runner. Looked goofy (to me). Other color schemes I'd have probably kept them.
09-26-2018, 05:14 PM
#74
Agree on the unsprung mass. The SCS wheels are about 7 or 8 lbs lighter than stock wheels (25 SCS vs. 33 stock) and C load BFG K02 is about 8 lbs lighter than E load. Stock Duratracs are 39 lbs and C load BFG KO2 is 51 lbs. Thus only about a 3 lb gain while getting 6 plies instead of 4 and getting an aggressive off road tread. I am pretty sure the BFGs even though they would have only 6 plies will still have a reinforced sidewall.
I am sure because of the gearing was designed for smaller tires the MPG will drop some (not as much as getting 30 lbs wheels [Icon Rebound] and E load tires) but the ride should be close to the same.
How long did it take to sell your wheels and how much did you get?
09-26-2018, 05:16 PM
#75
Strap this on your Trail vs. TRD argument (Yeah I know they are ORs, but sorta the same)
2014 SR5P 4x4 - TRD OR Rims/ BFG 265 KO2s/ 3/4 Prinsu Design Rack/ Lamin-X Fog Covers/ Bilstein 5100s x 4 (.85)/ Gobi Ladder/ Driver Seat lumbar mod
