02-12-2017, 03:05 PM
Pumping gas with tanker present
I ran into the gas station quick and didn't see the tanker. My girlfriend started pumping, with the damn tanker adding fuel to the system. I ran out and shut it off as soon as I saw it. It was only about 3.5 gallons.
Probably nothing big to worry about, but I've heard sediment can get stirred up and end up in the gas tank. Just wondering what I should do at this point to reduce the possibility of any associated problems. Any thoughts? Thanks.
Just tires.
02-12-2017, 03:10 PM
Real Name: Jeff
Real Name: Jeff
Uh....every dispenser has a spin on canister filter - just like a big oil filter- that filters out contaminants before it goes out the nozzle.
Worry about other stuff.
HERE FISHY FISHY FISHY!
02-12-2017, 03:12 PM
This is the answer, there is more to worry about than a tanker adding fuel.
02-12-2017, 03:21 PM
Banned
Banned
water in the fuel when the tank is low can be an issue but only if there is a problem with the tank or installation
if your 4runner didn't start bucking and running terrible shortly after filling up you have nothing to worry about
02-12-2017, 03:30 PM
This myth is still around?
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
02-12-2017, 03:35 PM
Speaking of fuel...... What grade do you guys get for your 5th gen? I have been filling up with 92 but I am wondering if I am throwing money away buying the higher grade....?
02-12-2017, 03:44 PM
Real Name: Ron
Real Name: Ron
Don't sweat the tanker.
87 octane is just fine.
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles. Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road. I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
02-12-2017, 03:47 PM
I have often wondered about that, I'd figure it'd be an easy enough problem to counter with an inline filter.
02-12-2017, 03:53 PM
Real Name: Um, Phil?
You should be worried because all the sediment from the distributor goes into the tanker, and then settles in the tank truck and is circulating when he's filling the station's tanks. Bad bad bad... in a perfect world there'd be a filter in the pump, and one in your car.
Wait, your GF pumps gas when you're there, wtf?
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
02-12-2017, 04:11 PM
Banned
Banned
there is a filter on the pump, you can usually see it
02-12-2017, 04:41 PM
C'mon e60, do I gotta start using green font for you? Kid V got it, and we all know he rides the short bus.
02-12-2017, 04:55 PM
prior to alcohol fuels like we have now , the fuel tanks were made of steel. when the tanker filled the station tanks the rust would circulate and get into your fuel tank.. I had this happen to me. my 1996 sedan did not cold start good . was 3yrs old no steel tank no steel fuel lines. replaced fuel filter engine start perfect.. still have vehicle today . cut open the filter since the filter was the fix. it was loaded with rust.
5K miles later replaced filter again filter looked good but had more particles than it should have had.
this is a old issue that is true going back now , over a decade plus in the past. it is not a B/S story.
I would not worry about it now , since if the glass service station tanks had any water it would still be at the bottom of the station tank as the fuel floats on the water. also the tanks now have a closed and filtered system much better than the old days when bad gas was more of a problem due to no regulations .
02-12-2017, 05:04 PM
many new vehicles have no replaceable fuel filters its part of the fuel pump assy... due to the improved regulations on fuel suppliers fuel quality not a required maintenance item..
if you store the vehicle for a year or more , best drain out all the fuel ...
02-12-2017, 05:19 PM
Real Name: Jeff
Real Name: Jeff
There are also sensors in and around the tanks to detect for water.
You guys should worry more about the idiots filling their fuel cans in the back of their truck beds, filling with the nozzles upside down while in their car, or people driving away with the nozzle still inserted. We have people test at least 2 of our break-away hoses/month at my work...
Idiots. Worry about them.
02-12-2017, 05:34 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
This thread should have ended when
@ Antman
gave the answer. It is a myth.
Since it is not remotely tied to a 5th gen subject I was going to move it. But, since it's false I will just close it.
-mod-
