02-13-2017, 11:17 AM
Caster question for ICON UCAs
Hi all,
I use to have LR UCAs on my 2011 SR5 that was recently totaled. I am now working on building a 2016 with a full Icon stage 2 with tubular UCAs. I do not have my spec sheet from the old alignment anymore but I thought you needed to adjust the LR UCAs caster as close to 5 as possible to eliminate rubbing the frame (correct me if I am wrong). Is this the same with the tubular Icon UCAs or are they different and need to be closer to stock specs? Just trying to eliminate a bunch of alignment/adjustment back and forth. Thanks.
2016 SR5 Premium Gray - ICON extended travel COs w/remote Res., ICON UCAs w/Delta Joints, OME 889 rear springs, OME rear shocks, ARB Aluminum series roof rack with Gobi ladder, Maxtrax with Maxtrax mounting bracket with quick pins from Australia, ARB 2000 series Awning, Konig Countersteer X wheels, 285/70/17 DuraTracs, C4 Fab Low Pro bumper with eXtreme LED light bar, Baja Designs Squadron Pro ditch lights with Rago Fab brackets, Morimoto 2Stroke 2.0 headlights and Sylvania LED Fogs, High output rear back up lights (Tail to turn mod).
02-13-2017, 11:24 AM
There is no adjustment on the tubular UCAs themselves. They are fixed position. You still want as much caster as you can get.. but this is only done by adjusting the LCA cam bolts.
02-13-2017, 12:02 PM
Interesting. I wonder If I should get the LR UCA's again? May be easier to mess with.
02-13-2017, 12:35 PM
you should be able to get all the positive caster you need with the ICON tubular UCAs. (depending on how big your tires are, of course.)
i know plenty of people run the LR/SPC UCA without issue, but jeez... bushing redesign after bushing redesign ad nauseam — and then reports and photos of broken welds! no way.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
Reason: autocorrect-introduced spelling error. keep up the shit work, Apple!
02-13-2017, 12:53 PM
Very true on the bushings. I went through bushing after bushing with the old UCAs. I am going to run the same tire wheel combo I had on the 2011, 285/70/17 Duratracs on the Konig Countersteer 17/8 wheels. If I can get all the positive caster I need with the Icon's then I will stick with them.
Thanks for the input. Much appreciated.
02-13-2017, 10:26 PM
Hi all,
Unless you're trying to run 34" or 35" tires I would say 5° of Caster is on the high side for a standard 3" suspension lift (I am running 6.1° on my 4th gen, but I am also running 35's). Usually most people fin 4° to be plenty good and give them plenty of freedom. The tubular UCAs have a "built-in" Caster compensation, so they should add I believe something like 1.5°~2° of Caster to the vehicle to help bring the measurements more inline with factory after lifting.
02-14-2017, 09:28 PM
Thanks for the reply. Love the info on this forum, so helpful. I bought the new one today and cant wait to start the rebuild. Game on!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
