02-16-2017, 05:29 PM
Real Name: Dave
Real Name: Dave
5th Gen: 4WD shift lever grinding getting out of 4L
Is anyone else having this problem with their 5th Gen 4Runner?
I have a 2016 Trail Premium. For the first few months of ownership, going from H2 to H4 to L4 and back out via stopping the car, putting the automatic transmission shift lever into Neutral, then maneuvering the 4WD shift lever between H2-H4-L4 and back out was smooth and easy. All of a sudden now, it goes smoothly into L4 but trying to get it from L4 to H4, it grinds badly. Again, while the car is stopped, foot on brake, auto shift lever in Neutral. My 1999 4Runner doesn't grind either.
I took it into the dealership, still under warrant with 2200 miles on it, and the master tech there called and said it's "perfectly normal for it to grind", to which I replied and told him it wasn't because it wasn't doing that before. I told him to go test out other 4Runners on their lot and he called me back saying they all grind when going from L4 to H4. I'm willing to bet he's lying to get the car out of their hair since it's a warranty vehicle and not a paying service customer. Rotten!
I'd love to hear your experience specifically on shifting the 4WD lever from 4L to H4. Any grinding guys?
'16 4Runner Trail Premium KDSS | 4.88 | Front E-Locker | ICON Stage 7 Billet 4" Lift | SSO Hybrid front | Warn Zeon 10-S Winch w/ RI 20" LED | Hefty Fab Alu rear dual swingout | White Knuckle Offroad Sliders | Full RCI skids | Dual Battery | ARB Dual Air | sPOD SC | TRD Wheels | 35" Cooper STT Pro | Prinsu full length | KC HiLiTES Flex 40 | OEMAudio+ Reference 500 | Much More
Build Specs, YouTube, FB & IG: https://linktr.ee/FugitiveOffroad
02-16-2017, 05:35 PM
Real Name: Brandon
Real Name: Brandon
I try to pop mine into 4H once a month. Early on when I first started exercising the system when trying to get it back into 2H there was a loud noticeable thunk/thud/jolt but nothing since (this was in November). I get no grinding on the way in or out of 4H but I only pop it in when moving (normally around 35/40 mph).
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
02-16-2017, 06:01 PM
No grinding here. Maybe you should sit in with tech as he "tests" other 4runners for the grinding noise.
2016 TRD pro Quicksand
02-16-2017, 06:02 PM
500km on my 17 trd, no grinding in or out of 4H or 4L.
HIS: 17 TRD Off Road - Prinsu Full length / OME 3" lift with 885/889 Medium duty coils / 17x8.5 Method NV 305 / 285/70/r17 Cooper STT PRO / Smittybilt Overlander RTT / All-pro HD Sliders / Rago Ditch Brackets / AJC LED High/Low Beams + Yellow LED Fog SOLD
2007 SPORT 4.0L 265/70/r17 BFG Ko2 Current
HERS: 14 LE 7-Seater - 275/55/r20 Goodyear Duratracs / 6112--5100 1.5" daystar spacer / Running Board Delete SOLD
2012 Rav 4 Falken Wildpeaks A/T3, Tourin 17" Rims Current
02-16-2017, 06:05 PM
Real Name: Pat
Real Name: Pat
I've never experienced this in my 4Runner.
In my 75 and 85 Jimmy's, yes, but not the Runner.
2011 Mag Grey SR5 Build & Pics / Front: Walker Evans 2.5" C.O's, AllPro UCA's, TC Spindle Gussets / Rear: Icon 2.0 LT w full MetalTech HD Rear LT Setup, Skyjacker sway links/ Odyssey 34R-PC1500 / Cooper STT Pro LT295 70 R17 E / CountersteerX's / Baja Flat Rack, HighliftX, CVT Mt.Shasta / BudBuilt bumpouts & Aluminum Skids / 10lb PowerTank / ARB Breathers(F&Rdiff,Tcase,Trans) / Shrockworks Front Bumper / Superwinch Talon 9.5 w Viking synthetic / Radio: Yaesu FTM-400DR, Comet 2x4, SBB1,SBB5,SBB7. AND NO FRONT F*CKING SWAYBAR!!!
VE6TXS
02-16-2017, 06:19 PM
Banned
Banned
Leave it in gear to go from H2-H4 and from H4-H2. After in H4 stop, put in neutral and shift to L4 in a smooth motion without delaying with the transfer case in N
02-16-2017, 06:29 PM
Real Name: Dave
Real Name: Dave
Getting into 4L from 4H is smooth. Going from 4L to 4H it grinds, when stopped, in neutral, foot on brake. It didn't do this when I first bought the car.
02-16-2017, 06:33 PM
Banned
Banned
make sure you aren't delaying with the transfer case in neutral, don't stop there just move right through it
the main point of my post though was that you were not shifting into and out of 4hi correctly
02-16-2017, 06:36 PM
Real Name: Dave
Real Name: Dave
You're right...I do shift from H2 to H4 while moving. I should've specified just H4 to L4 and L4 to H4.
02-16-2017, 06:44 PM
You have to be in neutral in order to shift to 4lo
02-17-2017, 12:07 AM
the xp trail I test drove before purchasing my trail did this on the lot with 2 miles on it. the guy didn't really tell me what or how to do it properly. but after my trail came in a toyota supervisor came out and went in detail about all the goodies how to use them and when. most was basic information but it was good for my wife since it's hers but he said try to avoid being stopped when you put it in 4H and make sure when going into 4L that you place the transmission to N and fluidly without hesitation throw the shifter to 4L. He said the manual transfer case is slightly heavier duty and the ?syncros? I think was the wording he used where slightly different from the electric system to minimize the vibration of the transfer shifter inside the cab. I dunno if that's bs or not but it works for me and it makes since really
Sent from my SAMSUNG-SM-G890A using Tapatalk
02-17-2017, 12:19 AM
This is it right here, you cannot stop in neutral on the t case or it will grind. I try to go as fast as I can. Eventually it will get easier as everything breaks in.
-2016 7%'er---RCI aluminum skids; C4Fab sliders; Rago Fab modular storage panels; Complete 3M ceramic tint; The Ultimate Camping Mod; Xenondepot HID kit; BFG KO2's
-1967 Stephens M416 military trailer---slow build
02-17-2017, 12:40 AM
You're shifting too slowly. There is a transfer case neutral position between 4lo and 4hi.
02-17-2017, 01:14 AM
Real Name: Dave
Real Name: Dave
Hey guys, update from the dealership. The techs checked the transfer case fluid and noted that it was much darker than it should be on a car with 2000 miles. They replaced the fluid. Shifting from 4 low to 4 high, while in neutral and foot on the break, is much better now. I tested it on a 2015 TRD pro that was in for service, which was clearly offroaded a number of times and it shifted much more smoothly than mine probably because it's broken in. I think I just might need to break mine in but I have also noticed that shifting it forcefully and quickly helps a lot.
Thanks for all the feedback guys! I think we're all good!
