2020 is off to a great start and we appreciate all the love.
We receive a lot of phone calls from customers looking to narrow down
the choice from Standard Travel (Stage 1) and Extended Travel (Stage 2).
ICON 2.5 Adjustable Coil-Over Shocks have proven strength and longevity.
These
Coilovers offer the best ride quality and handling.
ICON Standard Travel Coil-Over Shocks increase suspension travel and
dramatically increase the capabilities of your 4Runner's front suspension.
ICON Extended Travel Coil-Over Shocks offer more droop (down) travel
and are meant to be installed with an aftermarket upper control arms to
ensure the proper amount of wheel travel.
These Coil-Overs come
complete with all the hardware necessary to complete
the installation, as well as, a
sway bar relocation bracket kit to adjust the
location of the sway bar to clear the larger shock.
For some people, the added droop (+/- 1") of the Extended Travel Coilovers may
not be worth the cost of aftermarket UCA's.
For those looking to really test the limits of Off-Road and Overland, the added travel
will increase ride performance and comfort. This works for Daily Drivers as well.
Technical Specs:
- Adjustable ride height from 0" - 3.5"
- Race shock piston with flutter stack compression valving
- Kit Includes Sway bar relocation brackets
- Cad-plated threaded body / Extreme Weather Plating Option Available
- Billet aluminum upper mount
- 5/8" PTFE-lined spherical bearing
Completely Re-Buildable
- 2.5" shock diameter to prevent overheating
- Chrome-silicon spring
- 250 PSI nitrogen-charged internal reservoir
- Made in the USA
- Nitro-steel shaft will not chip or rust like chrome shafts
Recommended...
Tire Size 285/75R16
Wheel 16X8 with 5" back spacing.
Any thoughts on this from the community is greatly appreciated.
_
