Old 03-11-2017, 05:10 PM #1
e60ral e60ral is offline
Banned
e60ral will become famous soon enough
Banned
Battery questions. What size wire for battery? 2 gauge enough?
I thought I was good to go picking a 31m battery with posts towards the edge and not centered, but I didn't notice that the polarity is opposite the stock battery so if the posts are towards the wires the polarity is wrong.
I now need a way to extend the wires to use either the SAE stud or the normal battery post which is now on the far side of the battery.
I'm not sure I like the idea of using a bus bar like I see most others use, what I think I want to do is build a small wire extension, it will be about 4" long total.
Can I use 2 gauge wire with crimped lug rings, or do i need a larger gauge? I could bolt one lug ring to the SAE threaded stud, and the other bolt to the factory wires where it is currently bolted to the factory terminal end for the battery post.
I'm just going to use 1/0 to be safe
e60ral is offline   Reply With QuoteReply With Quote
Old 03-11-2017, 05:36 PM #2
Banned
Banned
Basically something like this but a few inches long:
or like this
what gauge do i need?
Old 03-11-2017, 07:00 PM #3
Phoenix4R Phoenix4R is offline
Phoenix4R is on a distinguished road
Take a look at Vatozone, they sell a bunch of that kind of stuff. I just had to replace the battery wire on my other car last month. Might want to check Amazon too.
Phoenix4R is offline   Reply With QuoteReply With Quote
Old 03-11-2017, 07:16 PM #4
Banned
Banned
thats why i was asking about 2-gauge, i had planned on using something larger because why not but the largest the auto parts stores have is 2
Old 03-11-2017, 07:22 PM #5
ChowChilla's Avatar
ChowChilla ChowChilla is offline
ChowChilla is on a distinguished road
ChowChilla's Avatar
Smile
If you have a stereo shop, you can get 0 gauge or lower...
2017 4Runner Limited Blizzard Pearl w/3rd row
TRD Pro 17" Black wheel with 265/70/17 Goodyear MTR
TRD Shift Knob, TRD CAI, MagnaFlow cat-back exhaust, TJM 3" lift, All-Pro APEX Sliders,(waiting to install Pelfreybilt Group 31 battery cage, NorthStar Group 31m Battery, Pelfreybilt front bumper, Warn 9.5xp, Baja Design S8 30", Baja Design Squadron Sport Fog lights, Switch-Pro SP9100)
ChowChilla is offline   Reply With QuoteReply With Quote
Old 03-11-2017, 07:26 PM #6
I'm no electrical engineer, but anything over 2 seems like overkill unless you're trying to drive some sort of monster stereo system or something.
Old 03-11-2017, 09:00 PM #7
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Originally Posted by e60ral View Post
"...Can I use 2 gauge wire with crimped lug rings, or do i need a larger gauge? I could bolt one lug ring to the SAE threaded stud, and the other bolt to the factory wires where it is currently bolted to the factory terminal end for the battery post.
Hi e60ral,
There's really no point in increasing the main cable wire size unless you are increasing the whole cable and the load that runs through them. The stock cables are possibly 8ga; 4ga at the most, so adding a 2ga to a 4 or 8ga doesn't make the cable any more capable to carry current! If your truck has a stock electrical system then using 4ga is perfectly fine! If you have added a high output alternator and high draw accessories then that's when it's necessary to perform a 'BIG THREE' install but that's unnecessary in a stock electrical system. Hope this helps,
rig, cheers!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 03-11-2017, 09:10 PM #8
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
Originally Posted by rigtec View Post
Hi e60ral,
rig, cheers!
Exactly. I'm no electrical engineer (mechanical and hydraulic is my world) but it's all about the length of run that determines the gauge. If you have X gauge now then jumping up a gauge is absolutely useless for 4" especially if you still have the same load. Go buy a cable that is the same as your current gauge, cut it, put the ends on and move on.
1engineer is offline   Reply With QuoteReply With Quote
Old 03-11-2017, 11:00 PM #9
Banned
Banned
Hi e60ral,
rig, cheers!
I understand that, I just couldn't tell the size of the two wires on the positive terminal
Thanks, used 2 gauge and turned out well Battery questions. What size wire for battery? 2 gauge enough?-imag1104-jpg
(Ignore the wonky j hook and no battery tray, just like that until the new tray gets here Monday)
Sent from my HTC6525LVW using Tapatalk
Old 03-12-2017, 12:29 PM #10
Banned
Banned
Does anyone know if crimp on lugs like this exist?: I want to try to get some torque off of the current lug connection
Battery questions. What size wire for battery? 2 gauge enough?-lug-jpg
What Size Wire Gauge In A 3rd Gen 4Runner? TegoXR 3rd gen T4Rs 12 01-01-2013 06:15 PM
What size wire for dual battery set up? jmt2404 3rd gen T4Rs 17 11-29-2011 03:16 PM
+12 battery wire carlscaffidi Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-18-2006 08:37 PM
Battery Gauge (voltmeter?) 4Sport Engines / Suspension / Wheels / Tires / Audio / Accessories 5 09-01-2005 12:49 PM
How are you running your amp wire from the battery? wsudu 4th Gen T4Rs 3 04-29-2005 11:10 AM
