03-12-2017, 01:59 PM
Back seat side windows disable
Anyone know how to disable the up/down control of these windows only?
My dog has figured out how to make them go down. Her paw somehow seems to naturally rest on the go down button.
I am aware of the driver's side front button that will lock/unlock control. However it affects all the windows and I would like to still be able to control the front passenger and rear windows without the dog moving the rear side windows down when this button is unlocked.
TIA
2016 Silver T4R SR5P + OEM Hood protector, V1 powered @ OHC, Rigid aux back up lights, Torque Pro app and BAFX reader, B&M 70264 Super Cooler. Firestone Coil-Rite air bags, Tekonsha P2 brake controller, Worthog's always on 12v mod, Cooper AT3 265x70x17, ARB fridge, ARB slider, National Luna dual battery system, and Bilsteins 5100 @ .85 with 10mm OMU rear spacers.
03-12-2017, 02:24 PM
Banned
Banned
remove the door panel and disconnect the switch
03-12-2017, 02:26 PM
Real Name: Q
Real Name: Q
TIA
Roll your windows down to where you want them to be then lock it... Why over complicate things...
Sent from my SM-G935T using Tapatalk
2016 BLACK Trail Premium - KDSS Toytec BOSS | 275/70/r17 BF KO2s | Custom roof rack | SCS Ray 10s | Relentless Front Bumper | 4300k HID Xenon Depot low beams | Baja Designs OnX6 Hi-Power 20", Squadron Pro, Squadron Sport, S2 Pro, S2 Sport | Blackout emblems | Interior LEDs | Wet Okole Seat Covers | T4R.org Trail badges | N-fab nerf steps | Hollywood racks bike rack | Spytec A119c dash cams - front/rear | SwitchPro | ARB Single Compressor
Instagram: thatonefitguyq
03-12-2017, 02:33 PM
this....
10 minutes and you are done
1994 4Runner AKA: Project Recycle
@503dropzone on IG
03-12-2017, 02:55 PM
Child window lock ? WHAT
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
03-12-2017, 02:56 PM
Excellent idea! Now if you could point me to a how to source, I would be most appreciative.
03-12-2017, 03:05 PM
Thanks for your thoughtful and informative post, however what part did you not understand........
Like many here, my vehicle operates in constantly changing environments, terrains and speeds thus the need to have control as I have indicated.
03-12-2017, 04:20 PM
Banned
Banned
if you are asking if there is some off-the-shelf or quick solution to your problem the answer is no
if disconnecting the switches is too permanent, you could put a relay in line with the switch to lock them individually but there is no walk through or youtube video for how to do it.
03-12-2017, 04:49 PM
Actually I was asking for a "how to remove the door panel" but in the meantime I located a utube video that answered my removal question.
https://www.youtube.com/watch?v=0xfjJBh_KzM
I have one door panel off as I type and I have reached in and unplugged/ disconnected the switch.
I still have full up/down control function from the drivers switch but of course the rear door switch no longer works. This condition is perfect for me and if/when I ever have a passenger or dog who might want the window down or up, they will have to tell me.
Now to button it back up and do the other side.
Thanks much for your help.
03-12-2017, 04:53 PM
I would try disconnecting the connectors to the rear switches and not the motors. That way you should be able to still operate them from the front. Failing that, perhaps covering the switches somehow would work. You may find the info required to remove the door panels in threads covering door lock motor replacement. The door lock/unlock motors seem to be a high failure item.
Oops guess you beat me to it.
Reason: more info to add.
