Old 03-24-2017, 12:28 PM #1
jb24dolphins jb24dolphins is offline
Real Name: Josh
jb24dolphins is on a distinguished road
Real Name: Josh
Bilstein 5100 kit with sotck spring, 2.5" lift up fron 1.5" daystar spacer in rear
Who is running this setup, anyone on stock tires by any chance with a picture? Have you run into any issues with UCA's? Should I do a diff drop too? I know everyone is going to say upgrade the springs too but it is just the setup I am going to be running for right now, stock springs have less than 1000 miles on them
2016 SR5 White (purchased 2/19/17)... blacked out grille, LED Interior lights, Yellow Laminix Fog Light Covers, TRD Shift Knob, black Hithchlink Factor 55 hitch receiver with recovery D-ring, Bilstein 5100s all around set to 2.5" up front with a 1.5" Daystar spacer in the rear, Fuel D546 17x9 +2 wheels, Nitto Trail Grapplers in 285/70/17, 32" light bar with Rago behind the grill mounts, Rockymounts 14er basket on factory cross rails ....many more goodies to come I just got started!!!
jb24dolphins is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 12:33 PM #2
mwray8909's Avatar
mwray8909 mwray8909 is offline
Real Name: matt
mwray8909 is on a distinguished road
mwray8909's Avatar
Real Name: matt
Stock size tires and same setup as you're talking. No issues with UCA and no diff drop.
I've been running it for a full year and have had zero issues.
Sent from my SAMSUNG-SM-G890A using Tapatalk
15 Super white TEP- SR5 hood swap/ Discoverer ATP/ 24" custom mount light bar/ lamin-x yellow fogs/ cobra CB with K40 magnet mount antenna/ 2.5" 5100/ lots of plastidip/... It really never ends
mwray8909 is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 12:38 PM #3
sampedro123's Avatar
sampedro123 sampedro123 is offline
sampedro123 is on a distinguished road
Bilstein 5100s front/rear @ 2.5 up front with 1.5 Daystars in rear
Stock UCAs, no diff drop, no problems. Stock springs and rides slightly stiffer than stock, which results in far less brake dive. Love it so far.
Bilstein 5100 kit with sotck spring, 2.5" lift up fron 1.5"  daystar spacer in rear-img_0005-jpg
2013 SR5 | '16 Trail wheels | 2.5/1.5 Bilstein/Daystar lift | Nfab steps | Trail headlights | '16 Tail lights
sampedro123 is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 01:09 PM #4
cd4pro cd4pro is offline
cd4pro is on a distinguished road
So no uca for both of you. How does it drive on the expressway same as stock? Any alignment problems?
cd4pro is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 02:16 PM #5
toku58's Avatar
toku58 toku58 is offline
toku58 is on a distinguished road
toku58's Avatar
This member has his set a t 1.75" Everyone is different.
Alignment report and question
Here's mine:
But I have UCA's.
2016 SR5 4WD W/3rd row seating, Bilstein 5100's all around, front set at .85" with 2" ToyTec spacers,and Daystar 1.5" in the rear. SPC UCA's, ToyTec Diff drop, BMC, fender liner relocated and lower bumper trim. LED's all around, Rola cross bars, Mamba M14 17x9 4.5" BS wheels, BFG KM2's 285/70R17, aftermarket MBRP stainless exhaust tip. No more mods on the runner!
toku58 is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 04:40 PM #6
I would say ever so slightly, a little more wandering on the highway, but it's all relative to the driver. Would you get a better alignment with aftermarket UCAs? Yes. All depends on you the driver, what you prefer. I'm not as particular as others, so stock UCAs work for me. If you have the funds available, most say buy once cry once. All depends on you. I didn't have any issues getting it aligned, but the alignment shop I took it too often does lifted vehicles. Just be sure you don't take it anywhere that will align to factory specs, because clearly it's not factory anymore!
Old 03-24-2017, 07:18 PM #7
keyser_soze's Avatar
keyser_soze keyser_soze is offline
keyser_soze is on a distinguished road
I have 5100s, on the 3rd setting in front (2.5" I believe) with daystar spacers in the rear. No diff drop, no UCAs. I have 285/70/17s. I'm right on the edge of "within factory spec" on alignments.
It rides so much better with the bilsteins, no more brake dive. I don't have issues with alignment and it feels fine on the freeway and higher speeds. The lift is a good height, and the 3rd setting in front evens it out nicely.
Sometimes I do consider getting springs, mostly because the 1.5" in the back is not quite enough and If I have the back loaded it can have a slight reverse rake which I don't like. I will probably get springs eventually.
2015 SR5 Premium Bilstein 5100 | Dobinsons Springs | SCS SR8 | 285 Toyo Open Country AT3 | Trail Rack | TRD Intake | Borla Side Exit Exhaust | TRS LEDs | JBA UCAs | CTH T9 | Pioneer 9605 AMP | Scanspeak tweeters, Kicker 6x9s, Dayton HO 10"
keyser_soze is offline   Reply With QuoteReply With Quote
Old 04-06-2017, 11:56 AM #8
Timberlinhvo Timberlinhvo is offline
Timberlinhvo is on a distinguished road
I just installed Bilsteins 5100 front and rear set at 2.5. I also have 1.5 daystar spacers in the rear. For those who have the same setting, do you guys notice a front rake? I was hoping that it would be more level.
2016 Super White TEP w/KDSS. TRD Pro Accents (Wheels, Garnish, Valances, and Shift Knob). BFG ko2. Bilstein 5100. SpiderTrax 1.25 Spacers. Gobi Stealth Rack
Timberlinhvo is offline   Reply With QuoteReply With Quote
Old 04-06-2017, 02:29 PM #9
PNW.T4R's Avatar
PNW.T4R PNW.T4R is offline
Real Name: MD
PNW.T4R is on a distinguished road
PNW.T4R's Avatar
Real Name: MD
I am currently running the setup on some SCS F5s with BFG A/T KO2 275-70-17. Ran with stock UCAs for about 8 months no issues, but the ride felt dodgy and I was constantly playing with the steering wheel.
I added a set of JBA UCAs 3 months ago and the drive is much smoother with the added caster.
Bilstein 5100 kit with sotck spring, 2.5" lift up fron 1.5"  daystar spacer in rear-t4r-jpg
PNW.T4R is offline   Reply With QuoteReply With Quote
Old 04-06-2017, 02:34 PM #10
Simpleman74 Simpleman74 is offline
Simpleman74 is on a distinguished road
Just what this site needed.... another 5100 thread
____________________________
2015 SR5 w/3rd Row
BRO'd up Grill
2.5/2 5100s F&R, Dobinsons Rear Coils. 275 KO2s (Going 285)
GOBI Stealth, RIGID Radiance, RCI Skids, Alea Leather, Safari Snorkel, ARB Dif Breather
Simpleman74 is offline   Reply With QuoteReply With Quote
Old 03-03-2019, 06:59 PM #11
Yota Inc.'s Avatar
Yota Inc. Yota Inc. is offline
Yota Inc. is on a distinguished road
Yota Inc.'s Avatar
I have this same model. Did you go with stock coils, or did you lift with the 5100's?
2012 TOYOTA 4RUNNER SR5 4x4
BILSTEIN 5100's FRONT & REAR | DIRT KING UCA's | OME-885 2.5" FRONT LIFT COILS | OME-889 1.5" REAR LIFT COILS | STEALTH CUSTOM SR8 MATTE DARK BRONZE 17" | BFG K02 - 275/70R17
Yota Inc. is offline   Reply With QuoteReply With Quote
Old 03-03-2019, 07:02 PM #12
Yota Inc.'s Avatar
Yota Inc.'s Avatar
How do you like the 275's? I'm installing a 2.5" Bilstein suspension lift with SR8 Matte Dark Bronze wheels, but cant decide on 285 or 275. I really like to 285 look but many are talking about body chops to prevent rubbing. Not sure I'm into doing that, hints the reason I'm asking about the 275's.
Old 03-04-2019, 12:29 AM #13
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I'm running 5100's 2.5 and Daystar 1.5 with 17x9's and KO 275's....no rub until I did a 1.25 spacer and needed the BMC. 15 minutes with a sawzall, easy.
83Mule is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 08:21 PM #14
angeldjesus23 angeldjesus23 is offline
angeldjesus23 is on a distinguished road
Lifted with Bilsetin's 5100
I want to know which springs can I use with 5100 Bilsteins?
I want to use the 2.5" setting with new front and rear springs.
I have a 2010 T4R SR5 Premium Package with 3rd row
With the 2.5" front setting can I use 1.5" rear springs? I want it leveled.
angeldjesus23 is offline   Reply With QuoteReply With Quote
FS: 4th gen. Daystar 2.5/1.5 spacer lift in california hunterD1 For Sale: Suspension/Wheels/Tires 13 08-15-2017 11:08 PM
Steve's budget lift: Tundra 5100's, stock front springs, rear daystar 1.5" spacer sjwelna 3rd gen T4Rs 20 01-31-2016 12:36 PM
WTB: Daystar 1.5" rear spring spacer for 4th Gen bob3dsf Want to Buy/Trade 5 12-25-2013 11:21 AM
Daystar 1.5" rear spacer keep spring in perch? tre9er 3rd gen T4Rs 5 06-27-2013 02:18 PM
