Old 03-28-2017, 10:28 AM #1
sinks88's Avatar
sinks88 sinks88 is offline
sinks88 is on a distinguished road
sinks88's Avatar
springs for added front end weight (winch/Bumper)
As of this moment I have the 5100's on top setting (and 5100/icon2" in rear)....I'm planning on a winch and bumper totaling about 150lbs. I'm not trying to raise the truck anymore than it is. Also adding 70lbs in rock sliders as well.
What springs will hold the weight in unison with the 5100's and maintain my current height?
sinks88 is offline   Reply With QuoteReply With Quote
Old 03-28-2017, 10:43 AM #2
sinks88's Avatar
sinks88's Avatar
I found this info:
OME 2884 390mm, 590lbs/in, Bar Diameter: 16.5 mm,
OME 2884 Coils designed for 0-50 lbs of additional front weight (no bumper and no winch)
OME 2885 395mm, 590lb/in, Bar Diameter 16.5mm
OME 2885 Coils designed for 70-180lbs of additional weight (with bumper or winch only)
OME 2887 400mm 590lb/in Bar Diameter 16.5mm
OME 2887 Coils designed for 250+ lbs of additional front weight (bumper & winch)
But I guess I will have to call OME to find out if I will get lift out of them...if so im going to have to get into more issues with UCAs and such
Old 03-28-2017, 10:45 AM #3
sinks88's Avatar
sinks88's Avatar
anyone use the OME 2885 395mm with 5100's that have extra weight in front?
Old 03-28-2017, 11:00 AM #4
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
http://www.toyota-4runner.org/5th-ge...s-choices.html
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 03-28-2017, 11:19 AM #5
08runnertjb's Avatar
08runnertjb 08runnertjb is offline
08runnertjb is on a distinguished road
I'm running 6112s with 2.5 in front and Toytec 3 inch superflex in rear. I have a pelfreybilt hidden winch and an XRC 9.5 synthetic. About 100 lbs of added weight total. Thst said I lost .25 inches of height in front and ride is notably harsher with stock weight springs. I'll be upgrading to OME medium springs for front soonest. Just food for thought.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2016 4Runner TE in black
Factory step/3M clear bra/Gobi Stealth&Ladder/ RIGID 40"/Weathertech/Magna Flow/285/70R17 TOYO AT IIs/FN CS Xs 17x8 Gunmetal/5100s/6112s/TTSFCs/ARB Diff BREATHER/ARB Awning/Pelfrey Hiddenwinch and XRC9.5synthenic w/Factor55
08runnertjb is offline   Reply With QuoteReply With Quote
Old 03-28-2017, 11:46 AM #6
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
Check the bottom of this post, and some further on. The additional weight springs aren't different spring rates, just taller springs (as shown in your specs). So when they have the extra weight on them, they compress to what a normal spring would without the extra weight. Hence without the extra weight these springs will add more lift than described. Also note that we're talking about GVWR +extra weight, meaning that this is when the vehicle is fully loaded plus the weight of the bumper/winch. If it's not fully loaded with bumper/winch then will get more than advertised lift. Unless you're loaded down for a week long overlanding trip you probably aren't near the GVWR +bumper/winch that would be required to get only the listed lift.
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 03-28-2017, 11:48 AM #7
V8eR_Runner's Avatar
V8eR_Runner V8eR_Runner is offline
Real Name: Kris
V8eR_Runner is on a distinguished road
Real Name: Kris
OME springs dont work with 5100's.
Instagram @Vader_Runner 2015 4Runner TRD Pro / ARC LED w/red option / Ellis Precision Shifter &Transfer Case shifter / Xenon Depot Extreme HID Low & LED DRL High Beams / ICON Stage 7 / 1.25" Spidertrax / Southern Style Offroad Slimline Bumper / Smitty Built X20 winch / Odyssey X2 deep cycle battery / Switch Pros 9100 / Rigid RS 20" light bar / Gobi Stealth Rack w/ladder / Rigid Industries Midnight Series 40 / Expedition One Rear Bumper / Baja Designs Squadron Sport / Rigid Industries SRM2 /Baja Designs Amber Fogs / Baja Designs 20" S8 behind grille / Infinite Off-Road Rocks Lights (8) RCI Rear Diff skid / RSG Angled Sliders / Cooper STT Maxx 285/70/17 / Rago Fab Rear Panels
V8eR_Runner is offline   Reply With QuoteReply With Quote
Old 03-28-2017, 12:03 PM #8
sinks88's Avatar
sinks88's Avatar
looks like the 885's or C59-314's at this point
I just want to keep my stock uppers as I don't intend to go over 2.5
Old 03-28-2017, 12:03 PM #9
sinks88's Avatar
sinks88's Avatar
why is that?
Old 03-28-2017, 01:38 PM #10
Real Name: Kris
Real Name: Kris
why is that?
Their springs are not designed to work with anything but OME. There is another thread on this topic somewhere on here.
Old 03-28-2017, 01:54 PM #11
Dark4c's Avatar
Dark4c Dark4c is offline
Dark4c is on a distinguished road
Dark4c's Avatar
I have the same exact setup and plan to add a winch and bumper next week. Installed toytec/eibach 620lb front springs today. Set bilsteins on .85(second ring up) and the coils are 1.6" of lift. Gives you about the same lift you currently have and will support the added weight.
springs for added front end weight (winch/Bumper)-img_0590-jpg  springs for added front end weight (winch/Bumper)-img_0144-jpg  springs for added front end weight (winch/Bumper)-img_0145-jpg  springs for added front end weight (winch/Bumper)-img_0146-jpg
Dark4c is offline   Reply With QuoteReply With Quote
Old 03-28-2017, 04:09 PM #12
sinks88's Avatar
sinks88's Avatar
So, all the people who are running this set up (including your signature) are not actually doing it? or they are testing fate because something is going to break?
2014 SR5 / C4Fab Slimline Bumper w/winch / Extreme LED 30" Lightbar / C4Fab Rock Sliders / Bilstien 5100's / OME 885s Front Springs / Icon 2" rear Springs / TRD Intake / TRD Skid Plate / TRD Wheels / Rally Armor Mud Flaps / General Grabber AT2s / Prinsu Roof Rack / CREE LEDs / Custom Livery
Old 03-28-2017, 04:39 PM #13
Real Name: Kris
Real Name: Kris
Looks like i need to edit my signature, those OME 2895 are on the rear.
Old 03-28-2017, 04:44 PM #14
Real Name: Kris
Real Name: Kris
I had the coils powder coated to match the original TRD suspension although the stock rear coils were black. This is the 6112's pictured with the rear OME 2895's.
springs for added front end weight (winch/Bumper)-img_3314-jpg
Old 03-28-2017, 05:07 PM #15
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Wrong. They do work with 5100's. There's an entire thread of people using OME springs with the 5100's. They work.
Another Bilstein 5100 question
I know the exact post and thread you are referring to. Reading comprehension is fundamental here and I think you missed the point. OME springs were designed and tested to be used with their in-house struts but that doesn't mean they won't work with with other shocks like the 5100's. We obviously know that they will. There is a big difference between OME springs being designed and tested for the 5100's vs whether or not they work with 5100's. The answer is they work, hundreds are using the exact combo, and there hasn't been an instance of them failing just because they used a Bilstein 5100 and an OME spring.
Bilstein 5100 and Old Man Ema Spring
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
3rd Gen OEM Front Bumper Weight reelamin 3rd gen T4Rs 12 08-15-2017 02:21 AM
How much bumper weight can 2015 TRD Pro front suspension handle? Capt.Canuck 5th gen T4Rs 3 11-12-2016 03:47 PM
What Springs for my new 2015 TEP w/ SS Hybrid Bumper & Winch?? JimJr15 5th gen T4Rs 19 10-13-2014 04:26 PM
Weight of new front bumper? savannah_4 4th Gen T4Rs 13 11-21-2013 12:11 PM
Plasti-dip added to front bumper (not just lower section), as well as more pictures! 1clean4runner 4th Gen T4Rs 19 12-29-2011 12:23 AM
