Noticed I have a gap on both left and right (left is worse) corners where the garnish curves downward. Garnish looks kinda warped. Been this way since new, but seems a bit worse after dealing with some paint rub there. From what I've seen it mainly seems to be the Trail/Pro black garnish with the issue. Haven't seen a painted or chromed one with the gap. Anyone have any suggestions to close up the gap? I was thinking maybe heat the garnish while applying pressure. Not sure if that'd help. Or just leave it I guess. Thoughts?
16 Silver Trail w/KDSS, BFG KO2 265/70/17 on Trail rims, TRD Pro front grill, OEM 4R floor liners, TRD shift knob, always changing something, more to come...
Pix?
Sent from my SM-G930V using Tapatalk
"I bet you're one of those guys that never takes these things off road." -Some guy who liked my T4R but drives a Hummer...probably
I have noticed this recently on my trail, only have a gap on the driver side though. It causes a terrible rattle on bass heavy songs. I'm probably going to tear the rear hatch apart and see what I can do to stop the rattle/close the gap.
MGM 15' TE with KDSS - Supreme Suspensions 3" front spacer - Daystar 1.5 rear - Falken Wildpeak AT3W LT285/70/17 - KMC XD Series XD820 Grenades 17x9 4.5 BS -12 Offset - Gorilla Auto Black Spline Lug nuts - Rear Diff Breather Mod - Trimmed front bumper and fender liner
Oh and a little bit of plasti-dip here and there
I redid the whole thing with new clips, gaskets and seals the other day. Also sanded the bottom corners of the garnish and then applied 3M clear tape under it to keep it from touching the paint. Over the past couple of days the gap hasn't gotten any better but the spacing on the bottom corners seems to be closing up as and on the left side its resting firmly on the tape now. Not sure if I should leave it or take it apart again and put a was he under the two outer bolts to space it away and maybe twist the garnish up slightly to close up the gap.
