Originally Posted by 4RPrototype
Sorry new at this forum stuff...
@ reidbailey
This is one of the cleanest DB setups I have seen. Can you please share all the items/parts you used?
I don't have a list of exact part numbers but I can point you in the general direction:
Shrockworks - dual battery tray, battery/winch switch + mount and ACR mount
BlueSea - Circuit breakers, fuses and holders, ACR, battery meter (To keep tabs on the house battery when the compressor is running but comes on when the hood is open)
ProWireUSA - Raychem DR-25 heat shrink, Deutsch connectors, Tefzel battery wire and primary wire, Thomas & Betts Ty-Rap cable ties and ring terminals plus other misc parts
Odyssey - 34M PC1500 Battery (will replace start battery with an Odyssey when it dies out of warranty)
Wirecare - for expandable sleeving and misc parts
Waytek- Bussman box and parts to build including Metri Pack connectors and terminals, manual resettable circuit breakers and other misc parts
SwitchPro- 8100
CTEK - MULTI 7002 charger and flush plugin
Anchor - marine terminals with heat shrink
McMaster - Bolts, screws and misc hardware
You can see a few more of the components in these pics:
Hope this helps!
