Hey guys like the title says I need some help on the fender liner plastic pins. I am use to the old Honda type Christmas trees. I have a set of BAJA foglights I need to install. Took off the front tire and unbolted the 10mm fasteners. Got the liner slid out of the clips without breaking any. Is there anyway to remove the fasteners (rivet style) without breaking them? If you broke them has anybody used the Christmas tree type instead of the pin rivet type? Any ideas on a simple way to remove them? Or is it chisel them out and replace? Ive done some searches and found similar other posts with sort of lots of discussion but no resolution
Thanks for any help. I don't want to turn this foglight install into an epic month long battle.
