Old 04-30-2017, 01:32 PM #1
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
How much grease is too much in the slip yoke?
I did an oil change yesterday and decided to lube the drive shaft. The U joints went as expected but when i lived the slip yoke I seemed to take a lot of grease before the shaft moved. Now Im paranoid I over filled the shaft. How much Is too much and if it is over filled what do I do to clean out the extra grease and start new?
Soneill is offline   Reply With QuoteReply With Quote
Old 04-30-2017, 01:47 PM #2
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
the slip yoke only needs a very small amount of the moly EP2 grease. like 2 ,,,,,,,,,,,,,,,,, 1/2 pumps that's it. the reason a 1/2 pump is so it has time to flow .. when pumping do it slow and feel the pump resistance ..
if the grease gun starts to feel harder to pump then too much is in the yoke.
how to fix it is drop drive shafts and wipe off excess..
on GM trucks you have to drop drive shafts to do this greasing..
catrains is offline   Reply With QuoteReply With Quote
Old 04-30-2017, 02:39 PM #3
Soneill's Avatar
Soneill's Avatar
It was real easy to fill. I only felt resistance towards the end when the shaft moved, about 10-15 pumps. There is no grease leaking out but the wife says she "feels" the road more now and it seems there is more drag on 0 braking decal. Again maybe just paranoid but I don't want to ruin anything.
Old 04-30-2017, 07:22 PM #4
(none) (none) is offline
(none) is on a distinguished road
When you over fill it, the grease takes up the space inside the driveshaft where the yoke is supposed to slide into. Air compresses, grease doesn't (easily), so it is now acting more like a solid driveshaft.
Drop teh driveshaft off the diff or the t-case, remove teh grease zerk, then fully compress the yoke. That will force the grease out the grease zerk hole.
2016 Trail and half of an early 90s Ford Ranger
(none) is offline   Reply With QuoteReply With Quote
Old 05-01-2017, 07:40 AM #5
Soneill's Avatar
Soneill's Avatar
After. I do that do in need to regrease with with the 2-3 pumps of leave it be?
Old 05-01-2017, 08:05 AM #6
10-15 pumps that is a problem............................ .
on a GM truck you just coat the yoke with moly grease perhaps less than 1 oz.. I would drop the shafts or remove the grease fittings and with them removed run it so the excess grease blows out..
Old 05-01-2017, 08:43 AM #7
sure or just leave it as is. It'll be plenty lubed either way.
Old 05-01-2017, 08:45 AM #8
haha. I was going to suggest that as well...but that is the much more messy approach. Going to end up with grease flung everywhere under there.
Old 05-01-2017, 04:47 PM #9
good rust protection ...LOL...
Old 05-01-2017, 05:43 PM #10
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
just remove the zerk and do a couple fast stops in the driveway. wipe up the excess grease that comes out, and reinstall the zerk.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Slip Yoke Binding Fix mtbtim 3rd gen T4Rs 56 07-11-2018 04:46 PM
greasing up u joint and slip yoke.... gx470 4th Gen T4Rs 8 10-21-2016 11:31 PM
Grease Leaking into U-joint when filling Slip Yoke Mac_Gyver 3rd gen T4Rs 3 09-17-2016 10:05 PM
Is my slip yoke stuck? Slick McFavorite 4th Gen T4Rs 9 09-03-2014 10:30 AM
Slip yoke won't take any grease Execute_Method 3rd gen T4Rs 2 02-19-2011 05:44 PM
