Originally Posted by Mutant138
Keep in mind you guys are talking about trading driving characteristics (which can be vastly improved over stock) in order to avoid BMC.
4 degrees of caster and the thing tracks straight as an arrow with far better wheel return out of a corner.
Yup, i have mine all most to 5*,its like it is on rails. No more of that constant steering wheel input on the highway. Mine was a chore to drive on long trips...NO MORE!
Steering is slightly heavier and it seems to 'push' the front more in the dirt, are the only drawbacks i can see.
I was trying to show the relation the castor change at the top/UCA will actually move the tire into the BM...with more castor.
Adding castor in the cam adjusters/LCA moves the tire forward.
...and apparently i cant spell worth a damn...should be "caster"...lol almost re-misspelled.
