Old 04-02-2019, 07:04 PM #31
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Originally Posted by SD2808TR4 View Post
Worked like a charm. I was stressing out about it too haha. No longer have the rub. Sad that I took out the spacers but I'll get over it. lol
I have JBA UCA, 17x9 Venomrex rims. Now only get the front fender rub which is easily fixable. Thanx for the info. Love this forum
Where did you go for alignment? Lex Brodies in Kalihi only could get 3.8 caster
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 07:15 PM #32
Khope Khope is offline
Khope is on a distinguished road
I had my local Toyota dealer do the alignment (lifetime alignment $199) and the install of the UCA. Just to clarify the attached alignment printout in my previous post shows "Before Measurements" and "Current Measurement" The "Before" was based on the new JBA after install not the stock UCA.
Khope is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 07:25 PM #33
I have Icon UCA's.
Lex Brodies did my alignment. Before I go bug the shit out of them I wanted to see what my other options were.
I'm getting minor rubbing on the mount and want to avoid chopping if all possible.
2018 TRD OFF ROAD
My Build
Old 04-02-2019, 08:14 PM #34
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Is yours the one on the left?
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 04-02-2019, 08:43 PM #35
JohnWick's Avatar
JohnWick JohnWick is offline
JohnWick is on a distinguished road
JohnWick's Avatar
Will report back my findings...
I have icon coilovers and dk uca’s going on with Scs ray10 And wildpeak 285’s. I will report back with my rubbing issues or hopefully lack thereof. Fingers crossed!
JohnWick is offline   Reply With QuoteReply With Quote
Old 04-07-2019, 06:45 PM #36
SD2808TR4 SD2808TR4 is offline
SD2808TR4 is on a distinguished road
Yup.
SD2808TR4 is offline   Reply With QuoteReply With Quote
Old 04-07-2019, 06:53 PM #37
I didn't need that much caster...2.9 and 3.3
Scottie's by pearl ridge, go early so there's not a long line. Cost about $120-130 for me. Rub on the front fenders but only in reverse. Doesn't even bother me enough to trim yet. Took it to Ka’ena Point, no problems whatsoever. Rides like a dream. Dobinson's definitely legit.
Old 09-25-2019, 06:58 PM #38
mashalatheballa mashalatheballa is offline
mashalatheballa is on a distinguished road
Originally Posted by Josh_357 View Post
I haven’t proven this but my understanding is adding positive caster by adjusting the lower control arm moves the tire away from the body mount, adding caster with the upper control arm moves the tires closer to the body mount.
does anyone with knowledge have input on this theory?
mashalatheballa is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 07:41 PM #39
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
285-70-17 wildpeaks, 2.5-1.5 lift, trail wheels, 1.25 spacers (to clear uca's), jba uca's (caster maxed to 4).
BMC was necessary. Maybe if I had gone with a different UCA that didn't require spacers I may or may not have cleared the BM. But, I didn't realize it would be an issue and now it's chopped. Would have gone 34 if I had known I was going to rub.
DO NOT let anyone say 285's wont rub. Just because it worked out for them does not mean it will for you.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 12:07 AM #40
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Here. Using a SPC UCA.
With the SPC arm set at the 'D' setting, that is +2* castor.
If you set it to 'G' that would move the UCA to the stock 0* and forward.
3rd gen guys with BIG tires seem like the 'G' to keep the tire out of the BM.
Orange is castor.
Green is the setting.
Front passenger side. 4th gen T4R.
Mount Chop Mod Necessary?-spc-uca-d-g-setting-jpg  Mount Chop Mod Necessary?-spc-uca-castor-jpg  Mount Chop Mod Necessary?-spc-uca-d-castor-jpg  Mount Chop Mod Necessary?-spc-uca-g-castor-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 09:58 AM #41
Banned
Banned
Orange is castor.
Keep in mind you guys are talking about trading driving characteristics (which can be vastly improved over stock) in order to avoid BMC.
4 degrees of caster and the thing tracks straight as an arrow with far better wheel return out of a corner.
Old 09-26-2019, 12:31 PM #42
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Yup, i have mine all most to 5*,its like it is on rails. No more of that constant steering wheel input on the highway. Mine was a chore to drive on long trips...NO MORE!
Steering is slightly heavier and it seems to 'push' the front more in the dirt, are the only drawbacks i can see.
I was trying to show the relation the castor change at the top/UCA will actually move the tire into the BM...with more castor.
Adding castor in the cam adjusters/LCA moves the tire forward.
...and apparently i cant spell worth a damn...should be "caster"...lol almost re-misspelled.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 04-03-2020, 03:17 PM #43
brighterside brighterside is offline
brighterside is on a distinguished road
Originally Posted by Ron4RNevada View Post
Honestly guys -> 265s will go anywhere that 285s will go - - -
No need for lifts, no need for re-gearing, cv joints and boots will last forever, stock shocks will last forever, suspension alignment can actually be left stock, stock wheels actually look pretty nice. And the urban guys in Reno aren't looking to steal my truck........
265 what's?
brighterside is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 10:13 AM #44
HBadger89 HBadger89 is offline
HBadger89 is on a distinguished road
I just happen to get an alignment today after the JBA Standard UCAs were installed. I have about a 2.0-2.5" lift due to installing FJ TRD Pro suspension and a 1" spacer. They did an alignment when this was installed and said I was at 2.0 Caster and that I should probably consider UCAs. The vehicle drove fine so I just left it alone. Then about three weeks ago I put on SCS Stealth 6 custom wheels ( 17"x8.5" with -10mm offset) and KO2's 285/70/17. I had inner liner rub and front bumper rub at full lock. Easy enough fix. However after the wheel and tire install the 4R felt strange like too easy to turn and not planted. So I decided to put UCA's on after reading and re-reading comments on this board.
The vehicle drives great EXCEPT it now rubs the body mount. Very frustrating and I have no desire to do the chop. I'm going to call JBA tomorrow to see if they have any suggestions. In the meantime, all forum members are welcome to provide input
Khope, did you end up having to get a BMC or was a re alignment sufficient? I too am looking to get 7x8.5 wheels but I’m torn between 0 and -12 offset. I’d like very much not to do a bmc since the truck is BRAND NEW lol. I did buy SPC UCAs and a kings mid travel kit so that should at least give me a fighting chance lol.
Thoughts?
HBadger89 is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 10:22 AM #45
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
There’s only so much playing around you can do with the alignment. If you lift and install bigger tires and actually take it off road it is going to rub.
You will also make the situation worse by having to offset the wheels a bit to clear the upper control arms.
I see a lot of pictures on this site with trucks that look like they rub when they hit a speed bump but people are adamant that they don’t.
Because the truck does not have a dedicated platform, instead it shares it with several other vehicle designs, there’s not a lot of room upfront for lifting and bigger tires, that’s some thing the FJ cruiser community has known for years as well.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
5th gen Body Mount Chop JSparky 5th gen T4Rs 42 12-02-2020 01:08 PM
Body Mount Chop FactoryRide 5th gen T4Rs 39 02-18-2017 02:50 PM
Need body mount chop in OC Ttn333 So Cal 14 06-25-2015 06:00 PM
Body Mount chop vs LR UCA Aquabear 4th Gen T4Rs 14 10-24-2014 10:51 PM
Body Mount Chop? 01grander 4th Gen T4Rs 8 04-01-2013 01:01 AM
