05-26-2017, 07:31 PM
How much should i look to be charged
How much should I be charged for Bilstein all around and daystar 1.5 in the rear? 4 wheel parts said it was going to be a 6hr job and around $635
2016 T4R SR5 Barcelona Red - Bilstein 5100's with Daystar 1.5 rear*Gear Alloy Manifold wheels 17" -12's*Cooper STT Pro's 285's*Rago Ditch light brackets w/ ditch light button*Rola Vortex cargo basket*Weathertech floors*Plasti dipped stuff* window vent visors* Hood bug deflector**Lamin X yellow fog light covers** (the_mrcarter instagram)
05-26-2017, 07:33 PM
Real Name: matt
Real Name: matt
For a shop that's going to be a pretty average price. Did that include alignment
Sent from my SAMSUNG-SM-G890A using Tapatalk
15 Super white TEP- SR5 hood swap/ Discoverer ATP/ 24" custom mount light bar/ lamin-x yellow fogs/ cobra CB with K40 magnet mount antenna/ 2.5" 5100/ lots of plastidip/... It really never ends
05-26-2017, 07:43 PM
Did you get ny other quotes? I would check some other shops and go from there.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
05-26-2017, 07:47 PM
Yeah it did include alignment
05-26-2017, 08:29 PM
With alignment that's a decent price.
05-26-2017, 08:38 PM
Real Name: Neal
Real Name: Neal
That sounds pretty good to me.
05-26-2017, 08:46 PM
I had 6112's installed up front, icon 2.0's in the rear with Wheeler T13's and an alignment done today for $350.
2017 TRD OR Premium // Icon 2.5 Ext trav w/ remotes and CDCV // SPC UCAs // Icon 2" rear springs // Icon 2.0 rear shocks // SCS Ray 10's // 285/70/17 Falken Wildpeak AT3W "E" Rated // RCI aluminum skids // SSO Sliders // Morimoto 4500K HIDs // LED interior // Canvasbacks //
05-26-2017, 09:15 PM
Seems to be very hit or miss depending on a lot of things.. Location.. Demand.. Experience.. etc.
There was only one local shop I felt ok doing it, and they wanted $600 + alignment.. For that price one could buy virtually every single tool they need to do the lift, from jack stands to torque wrenches.. Fortunately I have all the tools and decided to save the money and do it myself, it's pretty straightforward.
05-26-2017, 10:41 PM
Yes, but you also quoted having issues after the install in another thread. That may be why you are noticing issues.
05-27-2017, 12:06 AM
FWIW - it doesn't have to be a suspension shop. Those items are pretty straight forward bolt in parts that any repair shop could install. I'd try a local tire and brake place and see. I used to work at a tire shop and we also did a ton of suspension and brake work. IMO it's a 2 hour job max plus an alignment. I could do it easily in 2 hours in my garage without a lift. Plus an alignment. I'd say $300-350 including alignment would be what I'd expect.
05-27-2017, 10:33 AM
Real Name: Jared
Real Name: Jared
2hrs!? I must have screwed something up. I did 1.75" lift with the 5100s and it took hrs to get them reinstalled. Getting the originals out, quick and easy. But getting the LCA down enough to get the new shock in was horrendous. Is there a trick I missed because I thought for a while there there was no way I could get that shock back onto the LCA. I had to stand on the LCA and it still barely would go low enough to get it in there. I keep hearing how easy it is and it all is except that one part and I'm not sure why.
2015 SR5 Magnetic Grey, 4x4, 3rd row seats, Entune Audio. Billy 5100's, front set on 3rd ring, SAW 1.5" rear springs. Duractrac 265/70 R17's. 1.25" Spidertrax Spacers. Schrockworks custom treaded Sliders, RCI Full Aluminum Skids Front to rear, Smittybilt RTT, 2.2M Awning, 2.2M Equipt K9 Rack, Roadshower 2.0, custom drawers with Stove and storage.
05-27-2017, 12:06 PM
You should have loosened the lca's bolts, then it would have just dropped easily out of the way for a quick install.
'16 TEP. Ecotechne roof rack, BFG 285’s on Method BL's, Dobinsons 3”/2" lift, MT sliders, slimline front bumper Smittybilt winch, Expedition One rear bumper, Indel-B 50 fridge, lots more.
M416 Offroad trailer build in progress, RTT, Compact camping Concepts rack system, 275 BFG’s on FJ steelies, more coming...
05-27-2017, 01:26 PM
Real Name: Jared
Real Name: Jared
Son...of...a...monkey. It is all really easy...except that part...and now I know why 😂.
05-27-2017, 01:57 PM
I've never needed to loosen the LCA bolts (although that is an option) it always slips right in. But you do need to remove the Tie rods... Then again, I'm usually working on a vehicle with aftermarket UACs. The stock ones need the connection to the spindle all way loose....
Nobody will really get this done in 2hrs... It's always more than that, even if you know what you are doing. I've seen peoples 2hrs... turn into 6. Then they say... well 2hrs was actual time with hands on the truck.... 5hrs is fair.
05-27-2017, 02:22 PM
I paid $300 installed w/alignment.... and please dont let 4WP touch your rig
____________________________
2015 SR5 w/3rd Row
BRO'd up Grill
2.5/2 5100s F&R, Dobinsons Rear Coils. 275 KO2s (Going 285)
GOBI Stealth, RIGID Radiance, RCI Skids, Alea Leather, Safari Snorkel, ARB Dif Breather
