Old 05-28-2017, 12:14 AM #1
mosovich mosovich is offline
mosovich is on a distinguished road
Creaking front suspension..
Ok guys.. Put in new Icon suspension and about 25 miles later it started creaking and squeaking.. I greased the upper control arms which helped alot, but then it came back. I greased them again tonight and so far so good. Anyone have any ideas on why this is happening? Long story short, the shocks were rebuilt by Icon after they both went out within 1000 miles.
Thoughts would be appreciated..
mosovich is offline   Reply With QuoteReply With Quote
Old 05-28-2017, 11:27 AM #2
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
Are you running the ICON upper arms or stock? If it's the ICONs the uniball on my old arms were always making noise until I took the cover off. Be sure to clean them and lube them.
Also you can check the lower shock mount. That was another spot of noise for me. Make sure those bearings are lubed also.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 05-28-2017, 11:06 PM #3
Seems as though it's the shock itself. As it's compressing down the cylinder, the gasket? is squeaking on the cylindar. I guess the gasket is rubber and it's dry rubber on metal.. So, looks like another rebuild.. I'm hoping ICON will just replace them and not make me go through the rebuild again..
Old 05-28-2017, 11:07 PM #4
SATSTRAIL SATSTRAIL is offline
SATSTRAIL is on a distinguished road
Try shooting a little WD-40 on the shaft of the shock to see if that takes care of the noise and for how long. Not necessarily a permanent fix but it could give you some answers.
SATSTRAIL is offline   Reply With QuoteReply With Quote
Old 11-11-2017, 05:08 PM #5
Roborunner888 Roborunner888 is offline
Roborunner888 is on a distinguished road
@mosovich , did you ever find the exact source of the noise and what your fix was? I am having the same noise since my Icon Stage 2 install. It is definitely a creaking noise in my case.
Roborunner888 is offline   Reply With QuoteReply With Quote
Old 11-11-2017, 09:28 PM #6
I got some spray lithium grease and sprayed it on the shafts up under the boots.. Seemed to work..
Old 12-02-2017, 01:31 AM #7
Thanks for the response. I will try that this weekend.
Old 12-02-2017, 12:05 PM #8
lukeskywalker's Avatar
lukeskywalker lukeskywalker is offline
lukeskywalker is on a distinguished road
are you 100% sure it's the suspension and not the hinge of the hood? This thread pops up every 2 weeks or so and it ends up always being the hinge of the front hood.
lukeskywalker is offline   Reply With QuoteReply With Quote
Old 12-02-2017, 02:32 PM #9
Mvm Mvm is offline
Mvm is on a distinguished road
Mvm Mvm is offline
Hinge or latch?
Mvm is offline   Reply With QuoteReply With Quote
Old 12-02-2017, 08:25 PM #10
Originally Posted by Mvm View Post
Hinge or latch?
Latch.
Old 12-02-2017, 10:17 PM #11
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
May be advisable to check with Icon on whether or not you should be lubing the shafts and which products they recommend. I use silicone based spray on the exterior of shock body's as a corrosion preventative but not on the actual shafts, I'd be concerned about grease developing grime and accelerating internal breakdown of the shock. Most uniballs require a teflon based lube like Triflow, but not usually right out of the box.
For relatively new parts you all shouldn't be having any major problems. There will be some noise associated with coilovers and aftermarket uca's but nothing obscene. I'd put money on uca bushings. With the truck on the ground loosen the uca nuts before greasing to make sure you're not damaging your bushings. Idk about Icon but Total Chaos recommends teflon based grease like Superlube.
JSparky is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 08:45 PM #12
Calvaryblue Calvaryblue is offline
Calvaryblue is on a distinguished road
Creek
Just installed my icon stage 2's. I hear creeking when I turn. Doesn't drive me nuts. I'd just like to know it's normal I suppose.
Calvaryblue is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 01:24 AM #13
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
If you both installed UCA’s it could also be the UCA’s weren’t packed correctly with the grease they’re supposed to have when being assembled. Where it attaches by the shock tower.
My TC lowers are super noisy because I think they weren’t packed right. Squeezed a ton of grease into the zerks and it’s quiet now.
Just another thing to check.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 12:44 PM #14
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
OP ever figure this issue out?
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Loud Creaking front end Orlyg1521 5th gen T4Rs 9 04-24-2016 12:21 AM
creaking noise up front + vibration benedict1337 3rd gen T4Rs 17 02-24-2013 09:44 PM
Creaking groaning front end when turning fishrod Classic T4Rs 12 02-09-2011 03:15 AM
Suspension Creaking DCT Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-02-2010 04:39 PM
