06-01-2017, 11:19 AM
Headlight replacement due to fogging/haze?
I have a 2011 that I've dealt with hazing/fogging on the headlight plastics for a few years now. I know about the documented issue but due to problems with one of my local dealers I'm not eligible for replacement under the factory program. My question is if I pay for new headlight housings do I need to worry about the replacements hazing, or can I polish them out and fix the issue? I am looking for a permanent fix and not something I have to repeat every year or so.
06-01-2017, 11:36 AM
Real Name: Lou
Real Name: Lou
The TSB covered you if you were under 36000 miles. Some people had success getting new headlights, but they ended up hazing anyway.
You could always try the "Antman Eyebrows"
2011 T4R TE "Jemima"
JEMIMA BUILD THREAD
06-01-2017, 11:50 AM
This thread, and the TSB it mentions in one of the early posts, seems to indicate that the newer headlight housings should reduce the impact of oxidation.
T-SB-0081-12 Headlamp Surface Oxidation
Time will tell ... the sun beats the heck out of anything left outside for extended periods of time.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
06-01-2017, 12:11 PM
My dealer replaced my headlights 3 yrs ago because of condensation which I never noticed. It was due to a TSB. The replacements are showing signs of hazing. They look new after every wash & wax.
2011 Black SR5: Revo3s, K&N Air + Cabin filters, Aries Bullbar, Rhino Hitchstep, AVS Bug Deflector & In-channel Ventvisors. Real mods in sight...
06-01-2017, 12:22 PM
Yeah, the headlights won't be fixed under the TSB. Short story is that I brought the issue up to the dealer, it was never documented, and they won't fix it. Called Toyota customer care and, while they took the complaint, they ultimately turned me back over to the dealer that refused service.
So the end result is I pay out of pocket. The lights have gotten pretty bad and I need to either polish them, or replace them. I'd like a permanent fix so if anyone has had their lights replaced I'd like to know if the replacements oxidize the same way.
06-01-2017, 12:28 PM
Sounds like replacements won't be a long term fix.
06-01-2017, 12:41 PM
Stop getting wax option at the gas station carwash. I believe this to be the cause.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
06-01-2017, 12:42 PM
Real Name: Joe
Real Name: Joe
I have a 2011 as well, and before I switched to the TE headlights, I used Turtle Wax polishing compound on mine and they honestly looked better than they did new. It does not take much to clean them up.
-2011 4Runner LE - ARB Deluxe Front Bumper - Apex Overland Dual Swing-Out Rear Bumper -Shrockworks Rocker Covers - RCI Sliders - Total Chaos Upper Control Arms - Dobinsons Extended Travel Front - Dobinsons Long Travel Rear - Dobinsons Adjustable Rear Control Arms and Panhard - Metaltech Extended Brake Lines - LFD Offroad Wide Engine Skid - Orangeboxx Fabrication PSD Racks - Gobi Stealth - Dobinsons Awning -17x9 Fuel Warp Wheels - 305/70/17 Kanati M/T - EIMKeith PCK - Apex Overland Auxiliary Lighting
06-01-2017, 04:32 PM
Real Name: Lou
Real Name: Lou
Hey look who was the OP on that one.
JEMIMA BUILD THREAD
06-01-2017, 06:00 PM
Thanks for the heads up, I'll give it a shot.
06-01-2017, 06:01 PM
About 4 years on my replacements and they're just beginning to become noticeable.
I've been doing a lot of desert driving so slightly hazy headlight plastic is the least of my worries. I have 1000's chips along the whole front of my truck: the hood, the plastic fascia, the headlights, even the black rubber parts are pockmarked. The plasti-dipped emblem is the only thing that has fared well.
06-01-2017, 07:07 PM
Real Name: Daniel
Real Name: Daniel
i always liked upgrading to performance or aftermarket assemblies anyways...
06-01-2017, 07:20 PM
My friend runs a PDR business. I took someone's car there for hazy plastic headlights. He wet sanded them down good, cleaned them up, then sprayed a clearcoat over the top. This was almost 10 years ago. Just saw the car a few months back and it is just now starting to haze a bit around the edges. The rest of the plastic is still very clear. Worth looking into, esp since you don't want to deal with it every year.
06-01-2017, 09:38 PM
Great idea! You don't happen to know what type of paint he used that bonded to the plastic, do you?
06-01-2017, 10:08 PM
I do not recall. He did use some spray on it that assisted with adhesion, I want to say it was called mad dog or pitbull....some type of dog, but I do recall it being some adhesion promoter. Sorry I did not mention that in my previous post.
