Originally Posted by RyanEJ25
I thought a WDH wasnt recommended on the 5th gen? I think I remember reading that the 4th gen V8 hitch was better suited because of the way it mounts. I think i read that in the main towing thread
No issues with a weight distribution hitch. The 5th gen hitch is bolted to the rear frame cross member in a semi-integrated fashion. Some see this as inferior to the old fashion hitches that typically bolt to the sides, or confuse them with various center mount hitches on vehicles with very low tow ratings. This does not keep me up at night, but you can always bolt on a 4th gen hitch if that is your thing.
I always defer to the manual for anything important. Unfortunately, the manual was written by engineers, lawyers, and product marketing in poorly translated engrish. It does not prohibit the use of a weight distribution hitch, p301 reminds you: "If using a weight distributing hitch when towing, return the front axle to the same weight as before the trailer connection." Gee, thanks, toyota. It also says: "If the gross trailer weight is over 2000 lb. a sway control device with sufficient capacity is required."
I've never used a "light duty" truck for towing anything beyond a 4 wheeler or utility trailer, the hitch made a world of difference for me pulling this camper. The feel is closer to that of a 1-ton, which is what I'm used to. No kick, very little pushing you all over the road.
