Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Old 03-28-2018, 11:20 AM #46
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Here's a perfect demonstration. Both vehicles have almost the same curb weight. The tire height on the Ghe-0 are taller, but it's nowhere close to high centering. They would perform very similarly if they were the same height as the H1. Now, the H1 would perform much better if it aired down further. But it also would be even better with wider tires.
Old 03-28-2018, 12:42 PM #47
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
so... is that a win for taller, narrow tires vs wider tires? confused
1jzgte is offline   Reply With QuoteReply With Quote
Old 03-28-2018, 02:02 PM #48
dweh54 dweh54 is offline
dweh54 is on a distinguished road
Depends on the situation...I had 12.7 wide tires before...they are great off road where you want to float but terrible on the road...they followed the ruts that trucks made in the road and so required constant correction.
In the video, if there was solid footing under the snow (3-4 inches underneath), the narrow tire would be best because it would dig down to the firm surface and provide better traction.
But those same 12.7 wide tires I had were horrible on the road if there was only an inch or two or it was slushy...and they were Duratracs which have the snowflake. But off road where there was 12 inches of untouched snow, they were great.
dweh54 is offline   Reply With QuoteReply With Quote
Old 03-28-2018, 03:33 PM #49
Jetboy's Avatar
Jetboy's Avatar
Win for wider tires. It's easy to see where two vehicles with the same weight differ primarily based on ground pressure. The bigger (wider) tires make all the difference.
If higher ground pressure were better - you'd run your tires at max psi because that would maximize ground pressure. I've never personally found that to increase traction. Is there a scenario where it would? Maybe. Studs in tires are basically localized high ground pressure points that have enough pressure to puncture the ice surface and create a keying effect. So it can happen in the extreme. But that's not something that is typically found off road.
Old 03-28-2018, 04:55 PM #50
2016SR5 CO 2016SR5 CO is offline
Real Name: Pete
2016SR5 CO is on a distinguished road
Real Name: Pete
255/75/17
Originally Posted by fungusbrain View Post
I had the 275/70/17 KO2's for a couple years. When I got new tires, I went with 255/75 in load range C.
The difference in ride quality is night and day! The truck feels 1000 lbs lighter and it has more grip now. The old ones still looked new with a lot of tread, but seemed laborious to drive and added a lot of drag I could really feel when I let off the gas. Also, wet traction on the road was horrible.
This has me intrigued. I've been reading that once you go above 33" (285/75/17) a re-gear really helps with power. Based on your statement about your rig feeling 1,000lbs lighter- would you even consider a regear, or would that be unnecessary?
2016SR5 CO is offline   Reply With QuoteReply With Quote
Old 03-28-2018, 08:01 PM #51
Groove1797 Groove1797 is offline
Groove1797 is on a distinguished road
Good afternoon gents!
This has been an age old debate and it will continue to be.
Tires will behave differently on dry, wet, loose, packed and ice surface types.
On dry roads, dirt and mud we want as much contact surface for grip. Wet roads, more contact patch but also tread design for removal of water.
When it comes to snow, it boils down to condition and if the tires are studded. Ice/hard pack will always be narrow and studded due to the concentration of pressure over a small surface area. A good reference to this is ice racing and winter rally.
Loose and deep snow, wider with large surface area style tread. Look at snow cats, sleds, Antarctic overland vehilces and vehicles with track conversions.
I don't think we can generalize on wider or narrower tire types without knowing the conditions.
Groove1797 is offline   Reply With QuoteReply With Quote
Old 03-28-2018, 08:04 PM #52
If we look at the snow type, it's definitely loose and deep. Wider tires will do better since a wider contact patch with prevent the H1 from sinking into the snow.
Old 03-31-2018, 10:26 AM #53
fungusbrain fungusbrain is offline
Real Name: T.J.
fungusbrain is on a distinguished road
Real Name: T.J.
Don't know...I have the 255/75/17's, which are just over 32".
2016 Limited 4x4 Magnetic Gray
fungusbrain is offline   Reply With QuoteReply With Quote
Old 04-01-2018, 11:25 AM #54
Decipher's Avatar
Decipher Decipher is offline
Real Name: B-Money
Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough
Decipher's Avatar
Real Name: B-Money
Originally Posted by damthemainstream View Post
Maybe not everyone is trying to use their vehicle as a way to compensate for "toughness."
No one is claiming they’re compensating for toughness, myself included. If I’m lifting my truck, though, I’m doing it for both aesthetics and performance, so looks do matter. This, again, is why more people don’t do this.
Great discussion here. I have looked into this sizing...there’s just not a lot of tire options I’m excited about.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
Decipher is offline   Reply With QuoteReply With Quote
Old 04-01-2018, 03:17 PM #55
flimmyflammy flimmyflammy is offline
flimmyflammy is on a distinguished road
Im in the process of selecting a new set of tires and will probably go with the 275's but these will always be something to think about
flimmyflammy is offline   Reply With QuoteReply With Quote
Old 04-01-2018, 03:43 PM #56
Capt.Canuck's Avatar
Capt.Canuck Capt.Canuck is offline
Capt.Canuck is on a distinguished road
What changes have you noticed to your gas mileage? I recently took a fairly long road trip in my 4R and the mileage was piss poor.
2015 T4R TRD Pro (Super Sexy White) - FrontRunner full-length roof rack & expedition rails - Shrockworks rock sliders - SSO hybrid front bumper - Smitty X20 synthetic winch - Gobi rear ladder - XenonDepot HID Phillips 4300K headlight kit - interior LEDs - Focal IS690TOY speaker kit
Capt.Canuck is offline   Reply With QuoteReply With Quote
Old 04-02-2018, 08:52 AM #57
damthemainstream's Avatar
damthemainstream damthemainstream is offline
damthemainstream is on a distinguished road
Except for when you said that skinny tires don't look "tough"
damthemainstream is offline   Reply With QuoteReply With Quote
Old 04-13-2018, 11:56 AM #58
Tiki Joe Tiki Joe is offline
Tiki Joe is on a distinguished road
These only come in Load "C" correct?
What PSI is everyone running?
Tiki Joe is offline   Reply With QuoteReply With Quote
Old 04-13-2018, 12:28 PM #59
RCFJ RCFJ is offline
RCFJ is on a distinguished road
Finally, narrower tires are not better on snow or ice in almost any situation. Icelandic trucks look like they do for a reason. Those who speak should do. Those who do should speak. People who favor narrow tires on snow and ice have rarely ever used them on snow and ice. People who drive on snow and ice quickly learn that wider is better.
Ya but your leaving out a big and critical point in your argument....wider tires are better if your goal is to float on top of snow and have no chance of digging down to hard ground (your YouTube video and snowshoe comment above) if you’re driving in snow and it’s not 3ft deep (aka almost all snow driving situations) a narrow tire that DOES NOT float on top but does dig town to traction WILL be better.
Edit: Nevermind read your full post from last page - laid it out pretty well. I would just emphasize that 95% of snow driving people do is on their streets or highways not offroad.
Also KOs (have only ran a KO not KO2, but probably about the same) are crap in snow regardless of size
RCFJ is offline   Reply With QuoteReply With Quote
Old 05-14-2018, 05:34 PM #60
Teephud Teephud is offline
Real Name: Dave
Teephud is on a distinguished road
Real Name: Dave
Before you use mountain bike tires as your argument, you should do your homework. Over the last few years the trend has been going to larger diameter wheels of the same width, 29" dia with 2.5" wide rules... Fat bikes, and the semi-fat bikes are just not as good.
I am very close to pulling the trigger on 255/75's
Teephud is offline   Reply With QuoteReply With Quote
Anyone running 255/80/17 Tires Pizza Cutters alexb 5th gen T4Rs 227 05-06-2020 09:41 AM
Steelies and pizza cutters Blacksunshyne 5th gen T4Rs 21 11-17-2018 10:07 AM
235/85-16, who runs pizza cutters? KAILUAZ 3rd gen T4Rs 20 06-09-2018 03:11 PM
Pizza cutters? simple06 5th gen T4Rs 5 04-06-2011 10:53 AM
Celeste Pizza Fakie Polls 11 02-18-2005 07:50 PM
