07-31-2018, 07:04 PM
#61
Just wanted to thank you dawhoo for the pictures of your vehicle.
Just bought a 2018 Super White Off Road (Canada) today and having seen your pictures, they were the inspiration for choosing the grey TRD wheels, despite going the 265/70 KO2 route (and planning a wrap that will be complemented just as well as the white). Cheers
10-09-2018, 08:28 AM
#62
Real Name: Mark the Common Sense Wizard
Originally Posted by Presa Canario
I think they look good. The height is what matters, not the width. I have the 255/75 Duratracts with a set of SpiderTrax spacers and it looks perfect. My only wish is that I would have got the 255/80's. I wanted a tire that would fully tuck up in the fender well under full articulation off-road. I also wanted the 32" height as well as a Load Range C tire. My tires only weigh 40 pounds per versus the guys running 285's at 60+ pounds per.
I actually really like that size. I may need to do that on my next set... Also, I know where that highway is (between Albuquerque and Four Corners).
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
10-18-2018, 12:10 PM
#63
He takes a bit getting to the point (he's newish to Youtubing), but makes some great points throughout about skinnies. Other youtubers have said the same.
https://www.youtube.com/watch?v=D5Rc3kGrzf0
11-12-2018, 05:21 PM
#64
Originally Posted by Beans
I’m running the 255/75R17 KMs from a stock rubicon. OME light kit and spidertrax.
What roof rack do you have on there? I like the low profile.
12-05-2018, 02:49 PM
#65
Originally Posted by Jetboy
T...
Finally, narrower tires are not better on snow or ice in almost any situation. Icelandic trucks look like they do for a reason. Those who speak should do. Those who do should speak. ....
Wow,, I see what you mean.
12-05-2018, 04:57 PM
#66
That’s a bit of a silly comparison, are you (as a general term, not actually you specifically) trying to traverse Antarctica on an exposition to the South Pole or are you trying to make it safely to work/home/your favorite ski resort during a good snow storm? One would benefit from a set of Hakkapeliitta 44s to stay on top of the frozen crust and the other would benefit from a skinner tire that sinks down and applies more pressure to the contact patch where the tote is grabbing onto the ground beneath the snow for better traction.
12-13-2018, 02:16 PM
#67
Real Name: William
Real Name: William
I have 255/75r17 ko2 on my 4runner. For people tjat do occasional off-road, I think its perfect:
Better MPG on road.
Weight less.
Less wind resistance.
And for the amount of off-roading i’m doing, its doing the job.
12-13-2018, 02:28 PM
#68
Originally Posted by ATC556
I will never understand the desire to have a smaller contact patch than stock sized tires.
Explained to me by a very seasoned off-road driver… the smaller contact patch increases grip.
I know it’s counter intuitive for some, it was for me at the time too, but after he explained smaller contact patch = more pounds per square inch of vehicle weight distributed onto it = more grip.
The only good thing fat tires are good for is flotation, which is the name of the game for snow.
I run a 255/75/17 and it is to date my favorite tire size. I will gladly go taller, but not wider.
12-13-2018, 03:07 PM
#69
Do you reduce air pressure or increase it when you go off road?
12-13-2018, 03:21 PM
#70
Obviously reduce, and I see what you are trying to get at, but that isn’t always done to increase contact patch, it's done to increase compliance over tough terrain.
Airing down allows the tire to flex, reduce the chance of puncture, increase ride comfort, and a myriad of other benefits.
Point being, apples to apples, airing down a 255 vs 285 both increase contact patch, and the smaller one will still provide more grip.
12-13-2018, 03:36 PM
#71
Real Name: Jacob
Real Name: Jacob
Im in the 255/75/17 KO2 club, been very happy with the switch. For the really rough stuff Ive been using a set of 285 KM2s, but those have a new home on my 80, so the 4R will have the 255s at all times now.
Its the perfect size for the TRD Pro wheels and their narrow width.
12-13-2018, 04:19 PM
#72
So something like a bicycle tire would be even better? That's probably why they put the really narrow tires on race cars.
12-13-2018, 04:30 PM
#73
You can't jump to extremes to make a point... it's unreasonable.
This entire thing is a balancing act… between tire diameter, fitment, rubbing, load range, vehicle weight, application, all these things vary. The 255 isn't even that skinny, but it does solve problems in our application.
Airing down an E load vs a C load of the exact same tire size, the C load will provide more compliance because it will flex and absorb more terrain than it’s stiffer counterpart. It’s the reason we air down in the first place, to make things softer.
I can only speak on my own experiences and a 255 has been treating me very well. I also dislike E load range enough to take a C load 265 over a E load 255 if it weighed less.
I do it because the truck FEELS better, less rotational mass and un-sprung weight when compared to a 275 or 285 is noticeable especially when cruising our local deserts where sand is constantly bogging me down. For the limited power we have, the reduction in weight was welcome, and from a fitment and performance standpoint has been great.
Use what you like, use what works for you.
I never said 255 was an end all be all size, but it does balance out well all things considered.
As to your race car analogy, lateral G-forces with cambered tires usually on high friction surfaces in dry conditions with sticky compounds… I did think about that at one point in time too, but when climbing onto obstacles like rocks, for some reason the physics behind it appear to be in favor of the skinner tire.
12-13-2018, 06:23 PM
#74
Real Name: William
Real Name: William
Make sense!! The only thing I dislike about this size is that not every tire shop have this size in stock if something happens. But did someone know if running the stock spare tire with 3x 255/75r17 ko2 can broke something or use thing prematurely? What should I do if I need to drive with the spare?
12-13-2018, 06:38 PM
#75
I thought it was a very common size... at least the 255/75/17 MT is a stock size for a Jeep.
You can find near new take-offs from Jeeps all the time on the forums because they want to upgrade and increase tire size just like we do from our stock tires.
I always carry a matching full size spare, and buy a new spare when I change my tires. (I rotate my spare in with tire rotations)
Even if you don't have a matching spare, it's only the diameter that matters when running in 4WD / AWD. If you were in that situation I would put the odd sized tire up front and run 2WD or get a replacement that is the correct diameter and worry about it later if it was an emergency.
I forgot what the ratio is, but you can have some mismatch, but not a lot.
All of these tires were Jeep take-offs. Granted they are all MTs which is what I wanted. Perfect 4Runner upgrade size, cheap too.
