08-01-2018, 09:30 AM
#16
Originally Posted by delaWeb
I went thru the same scenario a couple weeks back with the same tire brand, model and size.
From my experience in the tire industry (a portion of them as a tire tech) I can tell you that regardless of weight differences 10 ply tires are always harsher to balance due to the added ply.
In a nutshell, my decision came to this - With 10 ply (load range E) you can air down safely to 15 PSI and with 6 ply (load range C) you can safely air down to 20 PSI. Being I never air down the added ply wasn't something I would benefit from so for that reason I went with 6 ply load range C.
Side Note: You can air down lower than the PSIs mentioned those numbers are just what I've been taught as being "Safe" for those noted amounts of plies. The wheel width also plays a role in determining a safe PSI.
i called nitto about this and their rep told me that both the C and E load tires are both 6 ply (at least in the 265/70 flavor). i went with C
08-01-2018, 09:31 AM
#17
Originally Posted by dlakeman
I know I’m a year late on this post but I just put 285/70 E-load rate Grapplers on my 2014 4Runner TE. My local dealer installs C-rated on their new 4Runners when they do a lift and tire swap. In NV and AZ the trails are sharp rock so I went with E-rated, also the 4Runner is not my daily driver. What tire pressure should be used on-road (Nitto spec is 80 psi max), and off-road on trails with and without rock? I drove the 4Runner home from the dealer 50 miles on the Interstate. Rode smooth and little road noise.
37 psi on road for c load
08-09-2018, 11:52 AM
#18
Per Nitto and Discount Tire websites the Ridge Grappler in 285’s are 10 ply.
09-07-2018, 10:18 AM
#19
I was ready to order the C load Ridge Grapplers but MY GOD those suckers are heavy! With a 50 lb C load BFG KO2 being an option now at 7 lbs lighter per tire, I guess my mind is made up. Kinda sucks because I love the look of the Nitto. Oh well, KO2’s have treated me well up to this point.
09-07-2018, 10:26 AM
#20
They are very heavy but man do they look good. I also like the Nitto due to newer design and newer tire chemistry. I did lose about 1mpg going from P-rated Trail to Ridge Grapplers.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
09-07-2018, 03:28 PM
#21
I debated for a long time on this as well.
The clincher was I didn't like the ride coming off 275 KO2s E-rated so I went with the C-rated 285s.
The ride is way better although there is no weight difference between the E and C load in the 285 size. It does as stated many times before, come down to your ride stiffness and outroad preference.
Very happy with the C-rated myself though.
09-07-2018, 07:14 PM
#22
You went with the BFG’s or the Nitto’s? The BFG 285 C’s shaved a lot of weight. Confused how Nitto could not shave any on their C load 285.
09-07-2018, 10:13 PM
#23
Nitto Ridge 285 C, I had 275 KO2s in 275. The ride was terrible with the KO2 E loads.
09-07-2018, 11:37 PM
#24
Yes, I have had the BFG’s in both a 275 and a 285 load E and they are definitely stiff, but also bulletproof. I am looking forward to trying out the BFG in a C. The 285/70-17 is only 50 lbs. I love that.
02-27-2019, 06:59 PM
#25
Quick question.
Anyone used the SL version of this tire which is 4 ply? I've seen a 285/70/17 (116Q SL BSW) which is lighter that I'm interested in getting due to the weight.
Anyone care to share their experiences with this load range.
Thanks in advanced.
02-27-2019, 07:29 PM
#26
I debated over this choice for a month and finally decided on the C. I got my Ridge Grapplers installed yesterday and halfway through the process realized I had somehow ended up with E-rated tires. No idea how but so far so good as far as the ride. I carry a ton of stuff and do air down some, so I guess I'll find out one way or another.
03-11-2019, 09:26 PM
#27
Real Name: B-Money
Real Name: B-Money
Nitto Ridge Grappler C & E Load Help
Originally Posted by Rpreme
Quick question.
Thanks in advanced.
I ran the P series stock size in the Falken Wildpeak AT3W and I’ll be honest...that tire was a beast. It was great on the pavement, I towed regularly and I off road more than anyone I know. I NEVER had an issue with the P series tire even aired down to 20. I shared my experience with a Jeep friend who also went P rated and he hasn’t had one issue either.
I’m currently running the KO2 285 in C load only because I have a Rubicon friend who sold me all 5 at a price I couldn’t pass. It’s nice having the peace of mind of the C load, but my worries about the P series were always only in my head. The P series never failed me in my Midwest wheeling. I’m considering going RGs next and would consider the P series from my experience. I’d probably worry about the perceived ruggedness but, again, it’s all talk. The P series is good for most people after my experience.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
03-11-2019, 10:45 PM
#28
I gotta say, switching to the E-load Ridge Grapplers after 10 months on my Terra Grapplers, the ride seems almost unchanged, minus maybe a .5 mpg drop. No harshness or sluggishness whatsoever. Pretty excited about the extra protection for my trips to the mountains this year.
03-11-2019, 11:09 PM
#29
Originally Posted by Decipher
I ran the P series stock size in the Falken Wildleak AT3W and I’ll be honest...that tire was a beast. It was great on the pavement, I towed regularly and I off road more than anyone I know. I NEVER had an issue with the P series tire even aired down to 20. I shared my experience with a Jeep friend who also went P rated and he hasn’t had one issue either.
That's very interesting, I have 1,750 off-pavement miles on my P265 70 17 Wildpeaks and I do NOT air them down. There is no need. The one time I had a sidewall burst was when I did air down. There is plenty of flex at 33 psi and comfort is great also. I also had one puncture at 33 psi but that was not as irritating.
I have had no issues in Utah, Montana or northern AZ, both problems occurred in the Sonoran Desert which is harsher.
But, yes, I like the Wildpeaks a great deal, coming from LT-D KO2/P-metric Continental AT combo (trip/town) on my previous vehicle.
I love the performance everywhere and the fact that I do not have to air down is a HUGE difference maker for me. It would take a sidewall failure at 30sh psi in a bad spot to push me into 3-ply sidewall tires again.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
03-12-2019, 04:04 AM
#30
Real Name: B-Money
Real Name: B-Money
Interesting that you had two failure on P series and you’re not deterred...
The Wildpeak IS a great tired but obsessing over these RGs right now. If I were buying today, I can’t honestly say I’d pony up the extra money for the peace of mind but I’m feeling like I might just so I’m not regretting it on the trail.
And I agree on tire pressure. I did most of my off roading at 30 with the P series. I went down to 20 in sand but the sidewall isn’t exactly getting abused there.
2010 4Runner SR5
