Originally Posted by FZRunner
Interesting stuff. I'm currently running 5100's all around on my 4th gen, with Eibach/Toytec springs front and rear. Like 'em, but since I may buy a 5th gen model soon, I was very interested in your opinions of the 6112's. I guess you're all lifting the front a bit, for leveling or whatever, but nobody mentions UCA's. Does that mean the stock ones suffice? It's always a weird one with my truck. Nobody would say yes or no, so I left them stock when I did the install. Cheers, G.
The answer is it depends...
it depends on your trucks setup
it depends on how much lift
it depends on your alignment numbers
Most people just take the lift height as a guide when it comes to making a decision on UCA.
I have a 6112 on my 4th Gen, it's one down from the highest settings. My caster is a little out of spec, I could benefit from a UCA, but the truck is still pretty well behaved and doesn't dart around from the caster... but it doesn't track as well as a stock setup.
Any higher and I would pretty much NEED a UCA to get those alignment numbers back in check. I bet if I had a UCA right now I could feel the caster improvement but i'm lazy and cheap so I left it alone.
On my 4th Gen truck, anything 2" or lower you can get away with it. Anything higher is a recommended to required depending on what you see at the alignment shop.
