I'm using a Switchpro and Bluesea 6-circuit fuse block (for wiring organization).
One request if you decide to use the same mounting holes as the Pelfreybilt tray would be to either add some gussets to the mount, or add a "leg" that supports the tray from below to prevent flexing.
You can kind of tell from this picture, but the tray does not hold itself perfectly upright and flexes with some weight on it due to the thin sheet metal that it bolts to. So far everything is still bolted in tight but time will tell how this holds up to bumps and vibrations...
Another request would be to keep the bolts exposed on TOP of the mount rather than below. The tray that i have bolts from underneath and is a huge PITA to mount since you have to reach underneath and line everything up without dropping the bolts inside the engine bay.
That's my 2-cents!
2021 Tundra TRD Pro
SOLD - 2015 4Runner SR5 4x4 Magnetic Grey ::
Build & Adventure Thread
