04-20-2019, 07:57 PM
#76
Originally Posted by KingTaco
Thanks for the new links. Should have this install done soon.
05-27-2019, 07:35 PM
#77
Uninstalled my skids and performed this procedure. Thanks for the heads up.
07-04-2019, 10:04 PM
#78
Real Name: Tom
Real Name: Tom
Pulled out the rear bolts on my new Pro. They were clean so took brass brush to threads and re-installed with never seize. Will chase threads on front next weekend. The fronts are kind of nasty looking/semi stripped. Who ever installed these at the port is a black eye to the attention to detail that the Tahara plant bestows on the 4Runner! If I was Toyota I would be upset by the shotty installs. Thanks for this thread.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
07-05-2019, 10:56 PM
#79
Originally Posted by Kistle
For whatever it's worth, I just did this on my stock 2011 SR5 and the skid plate bolts are M8x1.25x20mm. I have been changing my own oil since new, and always hated the way the threads on the stock bolts got flattened. I have always been able to get them installed and torqued, but there is no doubt that this is a weak spot.
Finally ran a chase tap through body mounted nuts, and replaced the fasteners with Grade 8.8 M8x1.25x20mm stainless bolts. Just thought I would post this for anyone with the older? bolt/nut sizes. I was surprised to find them as M8 after reading this thread.
Thanks,
JA
Where did you find the grade 8.8 bolts? Being that the Army decided to relocate me to Ms, good hardware stores are hard to find. Finding one that is stocked even harder.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
07-06-2019, 07:57 AM
#80
Thanks for the tips on this. I skipped buying the cutting oil and put a dab of anti-seize on the tap for chasing the threads. Worked just fine.
Found a floor jack padded with a rag was very helpful for lifting the TRD skid plate onto the vehicle.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
07-07-2019, 09:20 AM
#81
I got them at TruValue Hardware, if they have those where you are?
JA
07-07-2019, 12:44 PM
#82
JA
I miss waters. Nothing like it in the swamps that I have seen.
07-18-2019, 06:17 PM
#83
Anyone know the thread and pitch size of the other skid plate bolts?
Update:
Front skid plate(TRD) 10mm 1.25
Transfer case skid 8mm 1.25
07-18-2019, 07:31 PM
#84
Not sure if this helps, but I used the same tap on all the skid plate bolt holes (located in the frame).
https://www.amazon.com/dp/B0002YU26Q...iglink20350-20
07-27-2019, 02:53 PM
#85
Weird. Trying to tap the front 2 bolt holes and the tap isnt catching. I feel like I'm just grinding the threads away.
I feel like i should have drilled the hole a bit bigger first before tapping it.
Edit. Looks like i ****ed up. I needed cobalt drill bits first to drill the hole bigger. Then tap. Fml.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
07-27-2019, 05:42 PM
#86
Why would you need to drill the hole bigger? The tap is just cleaning out the existing threads so the bolts dont seize. Drilling out the hole will destroy the existing threads and require you to tap it a size larger.
If you're gonna scream, scream with me. Moments like this never last.
Raptor lights. eBay PRO grill. Pedal Commander. Plasti dip valence. Very limited edition overlanding stickers and headliner patches.
07-27-2019, 09:26 PM
#87
That's what I thought and read! Lol might be different amongst years or something, but the front 2 bolts on the trd skid plate are 10mm bolts. The current bolts are 8mm up front. So a tap isnt gonna make that hole 2mm bigger.
I bought the exact same products (tap, handle, cutting oil) as linked in the OP so i know i didnt screw up there.
Trust me, Im as confused as you are lol
07-27-2019, 09:34 PM
#88
I couldn't get the Tap started without it cutting new threads my self. Maybe an issue with Amazon or the supplier? Non issue for me as I have the plates down on the regular and added grade 8 bolts.
07-28-2019, 04:24 PM
#89
So nobody's had to drill the front 2 holes bigger?
Are you running longer 8mm bolts up front instead of the 10mm bolts that come with the trd skid plate?
07-28-2019, 07:54 PM
#90
I used the same tap for all 4 holes. I have a '17OR and replaced the stock skid with a pro skid. I used the original stock bolts, but the bolts on the rear that came with the pro skid were the same same size and pitch, just longer.
Edit...I just remembered the front bolts were already in the PRO skid with the spacers
