08-02-2018, 12:18 AM
#46
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
04-08-2019, 02:19 PM
#47
does anyone know if the BPF shock guard will work with the king shock guard? I currently have the king shock guard but deciding if I should get BPF or FJ toyman.
04-17-2019, 05:00 PM
#48
I have the same question!
04-17-2019, 06:58 PM
#49
I spoke with BPF and based on the measurements he gave me it should fit so I bit the bullet and bought the skids just haven't had time to install them. I will report back on the outcome.
04-19-2019, 10:11 PM
#50
here is proof for those of you who are wondering if the BPF shock skids work with king shock guards
11-18-2019, 06:50 PM
#52
Here's how my King Shaft Guards looked after 1 run. The other side didnt break but was quite loose. Keep in mind, i made sure they were secure and free from contact with anything around it.
I would replace it if it wasn't so expensive. Looking to get the BPF's but wished they had slightly more coverage.
11-18-2019, 07:13 PM
#53
Have you reached out to them to see if they can extend the guard higher up? I'd definitely be down for a set if they could.
2023 TRD Pro Solar Octane:
2019 TRD ORP Mag Grey (sold), 2014 SR5 Mag Grey (sold), 2010 SR5 Pearl White (sold)…if you can’t tell I love 5th Gens.
11-18-2019, 09:07 PM
#54
Yes they have no plans in a new version any time soon. I thought about modifying it by making a plastic shield and taping it to the BPF shield using something like this for material.
https://www.walmart.com/ip/JAM-Plast...olors/45711060
11-18-2019, 09:18 PM
#55
Well that’s less than optimal. I’ll reach out to Rago to see if they would be willing to modify their existing design.
11-18-2019, 09:46 PM
#56
Shaft or Knuckle
Not the title to a terrible 70's porn.
You're going to need both, as there's not a product that cover both the knuckle and the shaft. My solution was a set of BPF protectors coupled with the following:
Boots!
couple seconds with a pair of scissors to cut out a quarter inch section down the middle so the back is just slightly open (let's mud n water out), couple snips here 'n there to cover the knuckle, couple of zip ties (tight around the shock, loose mid and low) and you're covered, both flexible and solid... which can be said about a lot of things in life... but seriously.. shock boots!
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
11-19-2019, 08:38 PM
#57
Subscribed.
11-19-2019, 11:11 PM
#58
Well Rago is a no-go. They won’t modify their current design. When I get some time I reach out to some more fabricating places to see if a design can be worked out.
I wonder if I could convince RCI to fab something since they are local and already have offerings for the 4Runner.
11-20-2019, 12:59 AM
#59
Shock Boots
I have been more than completely pleased with the simple fix of shock boots to protect the shaft. Slice down the back to let it breath so mud and water doesn’t collect and it is good to go.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
11-20-2019, 02:58 AM
#60
See if a local welder can sand down the powder coat and weld on a small extension?
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
