Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 07-16-2017, 03:26 PM #1
dylan_n_00 dylan_n_00 is offline
Junior Member
dylan_n_00 is on a distinguished road
Junior Member
Upper rear control arms
Are these needed or is it just pretty? I'm gonna be installing a 3" lift and doing the lower arms as well
dylan_n_00 is offline   Reply With QuoteReply With Quote
Old 07-16-2017, 05:43 PM #2
rochmpr's Avatar
rochmpr rochmpr is offline
Senior Member
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
Senior Member
rochmpr's Avatar
Real Name: Krister
No, they are not needed. The benefit of these is when you go long travel in the rear. The heim joint allows move movement with less binding.
Sent from my SM-G920V using Tapatalk
__________________
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
Old 07-16-2017, 05:53 PM #3
Junior Member
Junior Member
Awesome. Thank you
Old 07-16-2017, 07:56 PM #4
wfo9's Avatar
wfo9 wfo9 is offline
Senior Member
wfo9 has a spectacular aura about wfo9 has a spectacular aura about
Senior Member
wfo9's Avatar
Actually... they allow you to get your pinion angle back to factory spec after a lift. Also if you want to move the axle forward or something with adjustable LCAs.. Not required though. If you get a vibration in the rear end from the U-joint.. this can fix it and reduce a little wear on that joint. I've never ran adjustable myself.. but can see a very small benefit. If you notice your rig smooth out a bit with a load... You get the idea of what they provide.. but pinion angle is always changing with load anyway. Someone also makes non adjustable that are already the right length for a lift to get the pinion angle back to spec unloaded.
__________________
2011 SR5 4x4, Magnuson Supercharger, ICON ET coil overs, MT ICON LT rear, MT offset lower links, URD Y-Pipe, TC UCAs, Baja Rack, MT Sliders, RCI Aluminum skids, 4.56 gearing with ARB lockers front and rear. 305/70 Goodyear MTRs (34") on Konig Countersteer 17x8. Addicted front bumper, Custom undercover tube protection rear. LT font or SAS going on next.
1989 Hilux - 22RE, SAS, hydro assist, Full Exo cage, dual ultimate cases, RCVs, 529s w Detroit locker rear + ARB front, Diamond Axle, bead locks, 40s.
wfo9 is offline   Reply With QuoteReply With Quote
Old 07-17-2017, 01:20 AM #5
rochmpr's Avatar
Senior Member
Real Name: Krister
Senior Member
rochmpr's Avatar
Real Name: Krister
Quote:
As WFO stated, there are some advantages, but, since I was on my phone in an airport heading on vacation, I wasn't going to go in depth, but there are plenty of knowledgeable people here to help out.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Adjustable rear upper control arms Bearded Cabbage 3rd gen T4Rs 21 06-05-2020 02:50 AM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
WTB: Cheap rear upper & lower control arms for 3rd gen Bandit Runner For Sale: Suspension/Wheels/Tires 3 01-19-2016 11:23 PM
Rear upper control arms wont line up brandon-4runner 3rd gen T4Rs 5 05-24-2015 02:00 PM
Adjustable Rear Upper Control Arms 97 _SR5 3rd gen T4Rs 15 09-11-2014 03:40 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
